My standby light blinks 5 times and then shuts tv off can this be fixed without remote
I can wait a minute and power it back up and it will run for another few minutes and then power goes off and standby will flash 5 times a few times in a row can this be fixed without a remote
    Top Expert:
  • Televison & ... Master
  • 74,106 Answers
No. It can't be fixed with its remote control. These blinks are fault indications, inside its circuit, and are called 'blinking codes'. From the number of blinks occur at one time switch ON, you can get an idea about the damaged circuit section, and this will make troubleshooting easy. If you wish to know more about blinking codes, check the site linked here. It has details to these of many brand TVs. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Posted on Jul 14, 2013
  • 4234 Answers
SOURCE: TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Posted on Jul 07, 2008
SOURCE: Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I think I have the solution for you. I have the same tv and it does the same thing when you turn on the power button on the remote when the tv turns on you hear a click then the red light flashes about 5 to 6 times then the tv comes on. on the remote there should be two buttons on top of the remote one says power and the other one says system hit the power button to turn on the tv when you hear the click and see the red light flashing then hit the system button which will turn off the tv then hit the power button again and it will turn the tv on without the red light flashing it should work
Posted on Jan 10, 2009
SOURCE: The tv keeps shutting off just after minutes of turning it on. We can wait about 5-10 min before turning it on again but then it only stays on for a few minutes.
This sounds like a heat related problem, which could be a faulty chip or a cold (bad) solder joint on one of the PCBs (printed circuit boards). Due to the lethal voltages present inside a CRT type television, it is strongly advised to have this repaired by a qualified technician. however, if you or someone you know is technically inclined, you can try to fix this yourself. Cold solder joints can often be spotted by visible cracks in the solder joints. a through inspection of all the boards could easily identify the problem which can be resolved with a quick tap with a soldering iron and perhaps a little extra solder added to the joint. if that yields nothing, another method is heat/cold stressing the boards while the TV is running. With the TV on, spray small areas of the PCBs with cold spray (or a can of compressed air duster turned upside down) until the tv shuts off. then heat the last sprayed part with a hot air gun (or a hair dryer) until you can get the problem to repeat regularly. inspect the area causing the problem and you will probably find the culprit.
Posted on May 26, 2009
SOURCE: TV will not turn on
Sounds like the power supply needs replacing.
TV repair is best done by a pro unless one has significant experience with it.
Charlie
Posted on Aug 15, 2009
JOHNSONELECT
  • 113 Answers
SOURCE: Sony TV standby blinks 5 times picture comes and goes
TRY TO TURN SCREEN CONTROL UP OR DOWN
Posted on Aug 26, 2009
KV-24FS100 TV shutting off
How many times the standby light flashes in between switch ON and going OFF?
For more details about this fault, visit this site, and call older posts.
Type in this link address, [without brackets] either to Google Search Box or into the Address Bar to your browser and press Enter. It has all the details about blinking codes of Sony Sets.
electronicshelponline(.)blogspot(.)com
In name [Electro-Help]
Apr 16, 2012 | Sony FD Trinitron KV-32HV600 32" TV
While watching my sony KDL-46NX810 TV its suddenly shut off and starts blinking 3 times red standby light. Please have me inform, what this error means and how to repair or what to replace on my...
Hi Gerard,
3 flashes of the led light on most KDL series is a power supply malfunction. To confirm the error code, lets access the self diagnostic screen by following the steps below.
Unplug the unit from the outlet for 30 minutes and then plug it back in and check if the symptoms remain the same. Wait until the led light stops from flashing and then press in rapid sequence the "Display", "Channel 5", "Volume (-)", "Power" button key on the remote control. Self diagnostic screen will be display. Let me know the result.
Jdvillanueva
Nov 09, 2011 | Sony KDL-46NX810 46 in. 3D LCD TV
I own a Sony KP-51WS520 that has been down in the basement unused (unplugged) for 2 years. I decided to set up my "man cave" and went to turn on the TV. It started right up but after shutting...
Hi Hank,
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. There is no user replaceable Lamp in KP51WS520 TV.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 16, 2011 | Sony Televison & Video
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
The stand by light keeps blinking, this has happened before but then the TV came on. What to do as it has been blinking for a long time now.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
  1. Turn off the television. IMPORTANT: For a projection TV that uses an internal lamp, wait 5 minutes after turning off the TV to allow the lamp to cool before continuing with the following steps.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps,service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Nov 15, 2010 | Sony Televison & Video
Picture stays on black
I had this same exact issue yesterday. I own the same TV model and here is what SONY had me do to get the picture back. Ultimately the picture comes back, but it will be very dim and needs repair. Most likely a power supply issue. Try these steps:
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 03, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Standby Light Blinking
Standby light is a signal indicating a voltage trouble on your system . It could mean a compoment is defective or a power regulator needs replacement worse is a system IC replacing. you better bring your stuff to a Sony service center and do a check on your TV system.
Apr 09, 2008 | Sony KP-53HS10 TV
Troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
May 17, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
