Question about GE JVM1650 1000 Watts Microwave Oven
Model GE JVM1631CJ01
My microwave keeps beeping and the screen says "F3". I looked it up and found it is a shorted touch pad panel. What is involved in fixing this?
  • GE Master
  • 9,174 Answers
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Essentially you unplug the oven, remove the grille, remove the control panel, unplug the keypad, peel it off, then stick the new one on. This is of course an oversimplificaton and is not intended as a substitute for proper safety and disassembly information.
Posted on Sep 23, 2007
SOURCE:
My GE Microwave JES1344SK is showing the code -F3- on the digital screen and it beep three times every 30 second, the microwave won't start and any of the fuctions is working I need some help on t
An F3 code means that the touch pad has a short. The touch pad needs to be replaced. If you purchased the microwave new, get your receipt and the unit serial number and contact GE for the repair (1-800-GE-CARES). See http://repair.geappliances.com/ to find a repair center near you. There is a one-year parts and labor warranty on this part. You will need to get the unit to the GE Repair center at your own expense. (I'm assuming that the unit wasn't shorted by a lightning strike or other disaster.)
I hope this helps.
Jan 02, 2012 | GE JES1344SK Microwave Oven
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE microwave and F3 has just come up on the display screen???
F3 Shorted key panel (touch pad).
1. Will occur if a shorted key panel is detected continuously over 60 seconds.
2. Replace key panel (touch pad).
What you can first try before replacing the keypad is first unplugging the microwave. Then you can get access to the panel by first removing the top grill and then unscrew the top of the control panel. There is a strip that looks like tape which attaches to the control panel which you need to wipe off and then blow dry. may not work the first time but be patient. also clean the bottom of the door and the latches to make sure the connection is clean. After that is should hopefully work without replacing the touch pad.
Let me know how this works out for you.
Benjamin
Apr 26, 2010 | GE Profile Spacemaker Over-the-Range...
Am getting an F3 message on the screen
Code F3 indicates a shorted key panel, (Touch Pad). The fix is to replace it. It is part # AP3205165. You can get it here. http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=24266225&&model_id=5211940#d24266225
Feb 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
While cleaning it the vent began to open and close and the microwave would not shut the vent down when the keypad was used to end the cycle. Now it only shows F3 on its screen when we try to set it up...
The "F3" error code means "Shorted key panel (touch pad)". The correction is to replace the key panel aka a membrane switch or a touch pad. The control panel in that case is just a plastic frame.
please rate this help to keep us online
Aug 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
F3 error
HI, the Key panel (touch pad) is shorted.
Jun 16, 2009 | GE Advantium SCA1001SS Convection /...
GE microwave f3 code
You have a shorted touch pad.. here is a link for a replacement.. http://www.pcappliancerepair.com/model-display.php
If you open up everything and examine the touch pad, you may see something that is causing the short and fix it, oherwise, you'll have to remove and replace it.. Hope this helps..
Sep 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Micro beeps 3 times with "F3" flashing on LCD screen. Nothing works.
If it's a GE model, F3 will mean a shorted key panel.
(If it's not a GE, please reply back with your brand and model number so we can help you).
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
BUT If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Jun 24, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave malfunction
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
[email protected]
May 29, 2006 | GE JVM1861SF Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
236 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
