Question about Irons
Perfection steam iron sprayer
I've never had a problem with the iron until the last couple of time I've used it. All of a sudden it is not shutting off . I used it the other morning and turned it off and was gone all day. Later in the evening I went to put it away and realized it was still hot . I checked to see if I had turned the knob completely around and I had.mtonight I ironed again and when I finished again I turned the knob completely around just as I always have in the past. I went down for an hour and when I came back again it was still hot. Should I get rid of it? Is this something that is not fixable? I've had the iron for at least 7 or 8 years. I only used the steam mechanism once or twice but I know my daughter used the iron a few days ago to iron some labels in clothing and she put water in because she thought she needed to steam and to make it work and when it didnt heat up she called me and I told her she didn't need to steam, that she could dump out the water but that she had to turn the knob under the handle to turn the heat on. Since then for some reson it hasn't worked. She used it and put it away when she was done when it had cooled off, so I know it had shut off for her. That was the last time it sht off. So what do you think is the problem?
5 Suggested Answers
geox29
  • 65 Answers
SOURCE: Why isn't my Iron heating up?
I do believe the thermostat is defective.All the iron have a small thermastat top control the temperature and is working like a switch.If the switch don`t work get stuck on the same position.Unfortunatly sometimes is better get a new one themn fix an old one but this is The Market and nothing i can do personally.Also make sure the thermostat knob is working properly.If you hear a click when you turn is ok.
Good Luck
Posted on Jun 19, 2008
DiYerTech
  • 70 Answers
SOURCE: steam escaping around the cap
If new parts are needed, and I am in California, I use the website below for DG-980 parts:
California Electric Service
(925) 827-1011
1170-G Burnett Avenue
Concord, CA 94520
http://www.californiaelectricservice.com/
Hope this helps, good luck and keep in touch.
Posted on Jul 11, 2008
farr64
  • 121 Answers
SOURCE: Iron stopped working suddenly
perhaps the thermostat is sticking.as irons are cheap to replace i would try cleaning /soaking the tank to remove lime scale. or strip the iron down checking thermostat and conections.
Posted on May 01, 2009
DiYerTech
  • 70 Answers
SOURCE: Rowenta Iron DG-980 problem
Very odd to have brown (rust from household pipes) as your DG980 has brass, stainless and aluminum, so deposits would be white. Make sure you flush and clean steamer tank and reservoir with clear filtered or drinking water only. When final ironing job is at or near completion, pull the reservoir and hold the burst of steam button several times to purge the system of water until no more steam when red light comes on telling you it is out of water. Let cool for couple hours, and unscrew tank plug cover and screw...bring over to kitchen sink. I have a filtered water faucet that I fill and swish around in the tank and then shake out several times as dry as possible. I leave the cover off, the blue reservoir empty, so last bits of water evaporate out. Put it all back together, ready for next use. After 3 or 4 cycles of this use, clean, store routine the iron should be clean. This is painless and costs nothing but a little care. Do not use vinegar or anything else and you should be fine. The deposits will slowly be purged if you use clear filtered water only.
Posted on Jun 13, 2010
What could be stopping the water in the holding tank not going in the steam tank on my Perfect Care Iron ?
most likely is mineral build up. drain out the water and replace with white vinegar, warm up the iron and allow it to sit until you see steam (several minutes to half an hour) if no steam, replace the iron.
Jun 18, 2014 | Irons
Lost steam pressure
see this causes and fix it.God bless you
Inspect the steam vents from the outside, and use a pipe cleaner or other small utensil to remove any excess buildup that is blocking the vents. Be careful not to let the buildup fall down into the steam vents.
  • 3 Clean the steam iron's directional spray tip. Minerals and other debris can build up on the nozzle over time and will greatly hinder the use of your steam iron.
  • 4 Pour equal parts vinegar and water into the steam iron's water supply tank. Put the steam iron above an empty pot, and turn the iron on. Let it steam the solution until all the water/vinegar solution is gone
    Sep 23, 2012 | Tefal UltraGlide Easycord FV4256 Iron
    SAND LIKE SUBSTANCE COMING OUT OF IRON
    Yes, there is a "Solution" you could use in the reservoir to remove the crud. First of all, STOP using tap water. What you have is mineral deposits inside your iron from using tap water. Use ONLY steam distilled water. I usually find this at my grocery store.
    To clean out your iron, use white vinegar in your iron instead of water. This is to CLEAN the iron ONLY! Do NOT use to press cloths! And make sure the steam and/or water flow very clear (free from "sand", dirty water/steam or any other contaminates BEFORE using iron to press your cloths. You may need to flush the iron with water (remember, steam distilled ONLY) more than once to get all of the vinegar out.
    Hope this helps...
    Jun 29, 2012 | Rowenta Perfect Iron
    How can I demineralize my rowenta iron? I use carbon filtered water in it. The last time I used it white stuff came out of the steam ports and it sounded like there was sediment inside when I moved the...
    Fill the resevoir with a 25% vinegar to water solution & turn on the iron until it steams. Allow to cool and empty resevoir then rinse with clean water. Fill up resevoir and & turn on the iron until it steams again. Cool, empty & rinse again. DONE!
    Only use distilled or reverse osmosis water in your iron. This will reduce mineral build up.
    Nov 13, 2010 | Rowenta Irons
    How to empty water form iron when finished
    Unless you are not going to use the iron for a long time, especially if you use distilled water to fill your steam iron, I would really not bother.
    However, if you do want to empty the iron after using it, you have a couple options:
    - With the iron still hot, very carefully, use the cleaning function or the 'shot' of steam until no more steam is generated above the sink preferrably.
    - With the iron unplug/NO electricty: very carefully tip the water out from whe filling hole above the sink - be aware that the water will remain extremely hot for a long time so avoid splashing water on yourrsel!
    Hope the information is useful.
    Sep 23, 2010 | Black & Decker D2030 Iron
    Simac Stirelli 9000 steam iron spews rusty steam and smells like burnt apples
    Your steam iron has been filled with 'tap' water that may have been contaminated (thus the smell). Rust develops more rapidely in Steam Iron chambers when distilled water is not used: to clean the 'enclosure' of the steam iron from rust and smell, over a sink or outdoor, fill 'cold iron' with a 50/50 water/vinegar and a teaspoon of bicarb, let it stand for about 10 mins, then turn the iron on and let it steam the mixture out while shaking the iron gently (DO NOT BURN YOURSELF! STEAM IS HOTER THAN BOILED WATER!). Refill and Steam flush again with Clean water (distilled preferred). Repeat the steps until the rust has been completely dissolved (check by steam ironing on clean pieces of disposible kitchen paper towel. Use the Power steam or Flush function of the Iron if available. Hope it helps!
    Dec 17, 2009 | Irons
    Suddenly began leaking and overheating, such as too hot for demin but only set of min. Last time this happened I bought a new iron. The new one has been dropped - last year but nothing recently and this...
    The iron started leaking from front and back. took iron back to Wal Mart and got another iron and it did the same thing. I cannot use the iron because it is hard to hold the steam almost burn your hands because it leaks a lot all over my cloths . I was so disgusted with the iron until I just put it in the corner and bought another iron from wal mart. I did not know if they would take the iron back , because I had it for a bout (3) months.
    Aug 06, 2009 | Rowenta DG-920 Iron
    Mold
    First with the iron cold fill the reservoir with white vinegar.  I would let this sit for a few hours and then pour the vinegar out of the iron. I would do this a couple of times until you see the mold is removed from reservoir. Next fill again with vinegar and run the iron on the steam setting, steaming a clean rag or towel until all of the vinegar is steamed out of the reservoir.  The vinegar will also remove any mineral deposits built up in the iron.
    Next rinse the reservoir by filling it with water and emptying it completely a few times.  Follow this by filling it completely with water again and setting the iron to steam setting.  Use another clean rag or towel and steam it until all of the water has been steamed out of the reservoir.
    In the future make sure to completely empty your iron after every use to prevent mineral build up and mold growth
    Aug 04, 2008 | Rowenta Perfect Iron
    Rowenta Steam Iron Leak
    I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
    Jul 14, 2008 | Rowenta Perfect Iron
    Irons Logo
    75 people viewed this question
    Top Irons Experts
    Are you an Iron Expert? Answer questions, earn points and help others
