POWER ON GREEN LIGHT FOR FEW SECONDS THEN OFF
HOW DO I FIX THIS PROBLEM
    Champion:
  • 247 Answers
Check the bulb if it doesnt light up the bulb needs replacement if the bulb comes on the color wheel needs replacement
Posted on Jul 14, 2013
5 Suggested Answers
techman007
  • 1112 Answers
SOURCE: push power button and lold it in green light
Hi:
You are in HV shutdown mode, Have the Horizontal output transistor replaced as well as the Horizontal output transformer. These are the most common failure for this problem, The three blinks indicates Delfection problem, and these parts are part of the main High Voltage Deflection circuits.
Posted on Dec 27, 2009
  • 13 Answers
SOURCE: When power on, the green power light comes on for
on off sensor sounds like its bad
Posted on Feb 26, 2010
  • 608 Answers
SOURCE: TV won't turn on. Press the power button and the
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Posted on Dec 15, 2010
  • 608 Answers
SOURCE: Problem with the RCA HD52W56
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
Posted on Dec 17, 2010
Have a Wireless logitech mouse. Replaced battery. Green light comes on, but then goes off. What next?
From Logitech's website, "This is normal behavior of the mouse.
The green battery light of your ]logitech] mouse will come on for a few seconds to indicate the battery condition and then go out. This will occur when you power on your mouse and when you replace the batteries. The battery light goes out after a few seconds to conserve battery power."
Nov 27, 2017 | Logitech Computers & Internet
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Wd-52525 flashing green light reset does ot fix. have to unplug for a few seconds to fix. Is this a conputer probem inthe TV?
Ur DM power supply board have problems.U know how to solders?Capacitors bulb up or pop open.Replaced this capacitors will fix ur Flashing power.Tries website Tv repair World.com to buy these capacitors to replaced.
Apr 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
No picture, but power is on...
How many times does the POWER led blink per sec? (dont worry about the OPC)
2x = power supply (not as expensive to fix)
3x = Main board (expensive to fix)
Oct 20, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
