Question about Measuring Tools & Sensors
Cam sensor location on chevy ecotec 2.2 eng - Measuring Tools & Sensors
  • 32 Answers
SOURCE: cam shaft sensor
it should be on the back of the head opposite the drive pulleys and belts. it should have four bolts holding it on. It looks square in shape.
Posted on Feb 11, 2009
dttech
  • 4803 Answers
SOURCE: where is the bank 2 sensor 1 located.
Oxygen sensors are always numbered like this:
Bank 1 sensor 1
Bank 2 sensor 1
Bank 1 sensor 2
Bank 2 sensor 2
some manufacturers use a kind of shorthand that reads different, but means the same thing:
Sensor 1/1 or O2s 1/1
Sensor 2/1 or O2s 2/1
Sensor 1/2 or O2s 1/2
Sensor 2/2 or O2s 2/2
Bank 1 is always the side of the engine where cylinder number 1 is located and, of coarse, Bank 2 is the opposite side.
On a 4 cylinder engine, there is only 1 bank and it is always referred to as Bank 1.
Sensor 1 is always the upstream sensor (The one located BEFORE the catalytic converter)
Sensor 2 is always the downstream sensor (the one that is located AFTER the catalytic converter.
Most GM engines have #1 cylinder located on the left bank, (or Driver's Side) of the engine,
So, the answer to your question would be that you are looking for the sensor located before the catalytic converter on the right (or Passenger Side) of the truck.
Posted on Oct 17, 2009
  • 14036 Answers
SOURCE: where is the coolant temperature sensor located on
its is located near the thermostat housing.
Posted on Nov 17, 2009
  • 7 Answers
SOURCE: hi i have a code p161 shown bank 2 sensor 2 is
bank 2 is passenger side, sensor 2 is Post cat (After) more and likely the sensor is extremly dirty, or failing (Either one requires a replacement, they are not cleanable)
Posted on Mar 24, 2010
  • 23 Answers
Change the sensor.
Posted on Jun 15, 2010
Where is the MAP sensor located on a 2004 Chevy Cavalier 2.2 ecotec dohc?
On your intake manifold, #3 in diagram. My info showed two wires, one is gray, the other is orange with black tracer.
Nov 11, 2014 | 2004 Chevrolet Cavalier
Where is cam sensor located on 1994 Chevrolet 6.5 diesel?
Go to advance auto parts or a smimlar store and ask for the Hayes or Chiltons (not sure I spelled that correctly) for that make/model/year and look in the section on Engine/Timing. Or try and figure out what kind of engine it is, and google that (For example, instead of looking for "Firing sequence for a Chevy cobalt 2005" one might google "Firing sequence for Ecotec 2.2L L4) and you might get better results. I know this doesnt answer your question, but it gives you an idea of some new places to look.
Mar 13, 2014 | Cars & Trucks
Cam sensor location
im sure the timing cover at front of the engine
http://www.importecwarehouse.com/Mercedes-Cam-Camshaft-Position-Sensor-Front-of-Eng-p/mb0021539528.htm
Mar 11, 2014 | Cars & Trucks
I have a chevy s-10 truck, no spark to coil, help
Check crank sensor (at front of eng. underneath) and/or cam sensor (located in the distributor).
Oct 11, 2013 | 1999 Chevrolet Silverado 1500
Hi i have a code p161 shown bank 2 sensor 2 is this located on passenger side behind the cat i have a 96 chevy 1500 2wd with a 5.7 eng
Mar 24, 2010 | 1996 Chevrolet K1500
Does my 2003 pontiac sunfire ecotec motor have a cam sensor? Where is it? If it starts as soon as u give it gas it cuts out. I've replaced: fuel pump, fuel filter, coil pk, spark plugs, crank sensor,...
there is still more to check. like the mass air flow sensor, the whole fuel line cleanout, and if its an auto it does have a camshaft sensor. its located into the transmission.
Jan 04, 2010 | 2003 Pontiac Sunfire
2001 dodge ram 1500 5.9 camshaft position sensor location?
CAMSHAFT POSITION SENSOR 2001 Dodge Truck RAM 1500 1/2 ton 2WD 5.9L SFI 8cyl The Camshaft Position Sensor is located: Under hood, center, upper engine area, rear of intake manifold, mounted in distributor
If this is helpful.Please leave ositive Feedback. Thanks, SnugglePants
Oct 21, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Measuring Tools & Sensors Logo
209 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
