Question about Thane Q-BBQ Grill
I have this bbq
This bbq caught on fire when we were camping last week my boyfriend all most got bun in the face it blew up in his face and the buned up i like this bbq please e-mail me emilieskyler@aol.com my name is mary patton my number is 541-810-1436 please call or e-mail me.
We replaced my ge gas oven ignightor but the gas is building up and when its heating to the right temp the door blosw open
sounds like the gas valve is leaking un plug the range and use a soapy water to find the leak
Jun 26, 2014 | GE Ovens
Our cabana CNA480 Grill caught on fire. where can we find a new?
Try the bbq center in Calagry they are on line they may stock what you need .
Aug 28, 2011 | Cabana Kitchens CNA480 (NG) Grill
Have a bbq grill with a XINDA ignitor that fires on all three burners at the same time. Replaced the battery and can hear a faint "squeal" when I press the button, but no spark.
The battery may be facing the wrong position. Generally, the Positive (+) end should be facing you when you insert it into the holder. If you did that correctly, check the spark ignitors at each burner. If they are covered with grease they will not fire.
Mar 27, 2011 | Grilling
Compresorul nu primeste curent. sigurante bune, comutator bun. Care este problema?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 09, 2010 | Refrigerators
My air cond is blowing the 20 amp breaker when camping but runs just fine for the dealer. It blew 11 times in 48 hours last weekend.
Ifr you are plugging into a external source for power, they or whereever you are camping has the wiring issues, to small of wire
Jun 17, 2010 | Dometic Rooftop RV Air Conditioner
My whirlpool duet washer caught on fire have you had this happen to any other whirlpool Duet washers
My LG washer caught on fire last week, but it was due to a lightning strike which took out a garage door opener and a couple of GFI outlets. Did you have any storms in the area?
May 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Buning smell whenever I use my vacuum
If it's a rubbery burning smell, check the belt for the beater, it could be rubbing on the sides or even broken.
Jun 22, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Thane Q-BBQ Grill Logo
26 people viewed this question
Top Thane Grilling Experts
Paul Carew
sureshd2008
David Payne
David Payne
Are you a Thane Grilling Expert? Answer questions, earn points and help others
