Question about Motorsports
Yz250 01 fork oil amount
ollie reece
  • 1167 Answers
SOURCE: fork oil capacity
medium fork oil - 150 mls in each leg
Posted on Nov 01, 2009
pugwash814
  • 377 Answers
SOURCE: what is the fork oil amount for a 2002 klx 300 per
The owners manual says to do the following if you don't want to remove the forks:
*raise the front wheel
*remove the fender, meter cable & unit, headlight, handle bar, fork protectors
*loosen the fork upper clamp bolts
*remove the caps from the top of the fork tube
*fully compress the fork tube so the dust cover touches the bottom and place a stand to hold it
*remove the springs
*set the oil level 68mm (standard) or 60 - 90 mm (adjustable) from the top of the tube
It may be easier to remove the tubes and you could replace the leaky seal at the same time. I did this recently and put in new springs too. It was my first time working on forks. With help from TT members and the service manual it was fairly easy. I didn't buy an oil gauge, seal driver, or spring holder. I used a ruler to measure the oil and a medicine dropper to remove any excess. For a seal driver I used a piece of PVC pipe cut in half then secured around the lower tube to drive the seal. Try a search on replacing fork seals for more info. 5w oil is standard but i have heard that 7 works well Good luck.
Posted on Dec 20, 2009
SOURCE: Yamaha xj 900 s Front fork oil amount in cm
The forks hold 286ml or 9.67 US OZ of oil, best would be to use hydraulic oil.
Good Luck.
Posted on Jan 28, 2010
  • 67 Answers
SOURCE: amount of oil in forks
The forks have to be bled correctly, then oil filled to the correct level by oil level (height) measurement. You need the service manual for your model if you are not familiar with the procedure. Since you asked the "amount" instead of "level" in millimeters - I assume you need the manual.
Posted on Feb 16, 2010
wd4ity
  • 4565 Answers
SOURCE: Frount fork oil amount in a HD XL1200C
"wet" = 9.0 ounces
"dry" = 10.2 ounces
If you simply drain the oil then readd the oil, it is considered a "wet" oil change.
If you disassemble and clean all the components and then add oil, it is considered a "dry" oil change.
Information source, Clymer's manual
Good Luck. Steve
Posted on May 06, 2010
How much fork oil do I put in
Dave, I usually measure the amount of fork oil that drains out of each fork and replace with that same amount. In my experience this is not necessarily a critical spec. All bikes are different, however. Many owners and mechanics will experiment with differing amounts and weights of oil. You may consult your dealership and try to get within a couple ounces of spec. Herb.
Apr 24, 2015 | 1998 Suzuki GSF 1200 Bandit S
Standard amount of fork oil for Honda xrm 125, what is best 2t or fork oil, my front fork is so bumpy
The fork oil does not have anything to do with the kind of engine do you have, 2t or 4t. Doesn't matter.
You need to replace the fork oil, you need to know the year of the fork. means, you need to know if it's a bladder or non bladder fork.
oil height of the bladder fork is approx. 70mm, non bladder forks run about 100mm oil level.
oil amount is about 530-600cc per leg
Dec 11, 2014 | 2014 Honda CRF 125F
How much oil in the front forks
2004 Touring Fork Oil Requirements
FORK MODEL TYPE and AMOUNT in OZ. ML IN. MM
Left FORK - All models except Road KingCartridge10.0 oz 295ML 4.21INCH 107mm
Road King Conventional 11.1oz 328ml 5.24inch 133mm
Right All modelsConventional11.1 oz 328ml 5.24inch 133mm
WARNING
Fork oil level in cartridge type forks is carefully measured from top of tube after pumping damper rod. Anydeviation from instructions can result in incorrect amount of fork oil. Incorrect amount of fork oil can adversely affect handling and lead to loss of vehicle control, which could result in death or serious injury.
Apr 14, 2014 | 2004 Harley Davidson FLHTCUI Electra Glide...
GPZ-1100 1995. Changing oil in engine and fork. How much fork oil to use? And what oil is better to use in engine? Thank you.
level of fork oil is more important than the amount...it should be 120mm from the fork top when fully compressed without the springs.
But if you want an amount then you're looking at 470cc although this will depend on wether the fork internals were stripped and dry before refilling. That's why using level is a better guide.
Engine oil for the 11 is 10w40
Jun 05, 2011 | 1995 kawasaki GPZ 1100
How much fork oil is required in the front forks of a 2000 suzuki 800 intruder and how do you measure if you put too much in. The guy at cycle gear where I bought the fork oil said to top it off or fill...
Hi, all model VS 800 from1992-2000 take the same amount of oil in the front forks, using 10 weight fork oil measure into a clean measuring device or mark the side of the oil bottle 413 mls, pour this caerfully into 1 fork, and the same amount into the other fork, 413/413 cm (3)
May 09, 2011 | 2000 Suzuki VS 800 Intruder
The front forks go down to far on my fxst 2004 nightrain
If you are saying that your front suspension is too soft, you can change the fork oil in the front forks to a heavier viscosity. I think Harley recommends Type E fork oil. I've found that PJB 30 wt. fork oil works best for me.
Since I'm not familiar with the newer forks, I'll have to recommend that you ask the dealer how to drain and refill the forks and how much oil to put back in them. There are usually two amounts of oil to put in the forks. One amount is a "dry" amount to add when you disassemble the forks and then refill them. The "wet" amount is for when you simply drain the forks and then refill them. Naturally, the "wet" amount will be less than the "dry" amount.
Sorry I couldn't give you more information but my expertise is the earlier model Harley bikes.
Good Luck
Steve
Jan 05, 2011 | 2004 Harley Davidson FXSTB - FXSTBI Night...
Volume of fork oil needed per fork for a 1986 VF 400 nc 13
Well, when you take off the fork make sure you empty it first before anything else then make sure that the fork pressure spring is released before changing the seals. The fork oil amount should be no more than 200 cc or no less than 190 cc
Jun 24, 2010 | 1986 Honda VF 400 F
Replacing fork seals and need to know amount of oil for outer fork on a twin cartridge tpye fork rm250 2005
Outer cartridge on the twin chamber Showa fork for an RM250 uses 350ml of 5W oil.
May 14, 2010 | 2005 Suzuki RM 250
What is Honda VTR 1000F fork oil level?
If you want to change your fork oil, best way is to drain a fork leg into a container, and measure the amount that comes out. You can make your forks softer or harder by varying the amount of oil.
Apr 17, 2010 | 2000 Honda VTR 1000 F Firestorm
Good Luck.
Jan 27, 2010 | 2000 Yamaha XJ 900 S Diversion
Motorsports Logo
117 people viewed this question
Top Motorsports Experts
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Steve P
Steve P
Are you a Motorsport Expert? Answer questions, earn points and help others
