Question about Epson LQ Office Equipment & Supplies
50 inch i have only one page to print. after print that page, printer rolls more paper along with the first page.. Then i need to roll blank paper to back side after every print. please help me
  • 45 Answers
You must clear the sensors,
Posted on Jul 15, 2013
5 Suggested Answers
ohms
  • 1879 Answers
SOURCE: Epson u220b printer
service for that unit - call the manufacturers tech line and they'll give u service center nfo - it it's still under 2 years - repair will be free of charge
Posted on Jun 14, 2008
SOURCE: HP 1320 duplex printing paper jam
Managed to solve this myself: I disassembled the printer and noticed there was a paper jammed in the duplex tray. Rolls were all ok, but the paper blocked the use of the duplex pathway. For disassembly help check the HP 1320 service manual, which you can find on the net as a PDF.
Posted on Jul 15, 2008
  • 25 Answers
SOURCE: printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Posted on Aug 14, 2008
  • 10 Answers
SOURCE: HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Posted on Jan 29, 2010
How do you replace the thermal roll to get it to print
Make sure you are using thermal paper which is 57mm wide.
Open the printer cover. Lift the paper holder lever on top of the printer. Remove the old tube from the last roll if it is still in the bottom of the printer. Drop the new roll into the roll holder in the bottom of the printer. Make sure the paper is coming from the bottom of the roll rather than off the top as it unwinds. Pull the paper out the front of the printer and close the paper holder lever down onto the paper. The shiny side of the paper should be facing you as it comes out of the printer. If not, the paper will feed out blank during printing. If you are replacing the journal roll, slip the end of the paper into the slit in the takeup spool (black reel) and wind over a couple of times before dropping into place. Replace the printer cover and make sure the receipt comes out of the cut out in the cover.
Good luck.
Jul 11, 2015 | Casio PCR-T2000 Cash Register
Stop Ejection of printing paper roll after printing in dot matrix printer
I assume you are printing on roll paper, but printer acts like it is printing on cut sheet paper. When finish the page, it ejects it, but it is not a page, it is a roll and the paper keeps unrolling, right? There have to be a lever that swithes between cut sheet paper and roll paper. Turn it to the oposite direction and the problem should be fixed.
May 18, 2015 | Matrix Office Equipment & Supplies
Print sounds but blank paper
Try a few print head deep cleanings if that does not help then you could try soaking the print head in a shallow plate of hot distilled water. Soak the tip of the print head only in no more than 1/8th to 1/4 inch of water.OR
Still Having Canon Printer Problems Then follow Us On: Canon Printer Support
Jan 29, 2014 | Canon PRINTER CANON IPF8000S PRINTER...
Blank paper coming out
Could paper be upside down? The rolls may be wound wrong. Thermal paper only is sensitive one side. Rolls might be defective.
Apr 26, 2010 | Sony UP DR100 Thermal Photo Printer
At college we have a w7200, how can we print across the paper rather than down it, for example a panoramic image across the width of the paper and say 20cm high
Try selecting LANDSCAPE as opposed to PORTRAIT by using the proper print menu in your application rather than the simple print icon from most tool-bars.
You can usually find it in the FILE menus
Apr 20, 2010 | Canon imagePROGRAF W7200 InkJet Printer
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
Paper feeds as if normal but no printing appears on paper
If it is now printing blank and was working before the paper roll change then you need to flip the roll over and print on the other side of the paper. This is assuming you have the correct thermal paper roll.
Dec 09, 2008 | Office Equipment & Supplies
Changed roll of labels, now it won't print...
Warren
one side of the paper will be sensitive to heat and the other side won't be. If it is thermal paper run a pen without the actual ink part sticking out of the pen or use a key from your key ring in your pocket over the paper the friction should leave marks on the thermal side of the paper.
you may have the paper in with the non thermal side facing the heat printing part of the paper. Or you have the wrong paper.
http://www.microtrade.com.au/zebra-printer-ribbon-suits-tlp2824-plus-label-printer/?gclid=Cj0KEQiAuonGBRCaotXoycysvIMBEiQAcxV0nOLqC5Do2fiZih4Z19jw389fNmbkQXNwgUfYVzkqdSgaAhbc8P8HAQ
ld4028-10a or ld21084 may be the label ? not sure its 40 mm wide not 55 mm or 2.2 inch
Mar 10, 2017 | Zebra LP 2824 (clp2)
Printing Borderless at 42" width?
Set the roll size to 44 inch, set your left margin to 0 (in your preprint software), experiment. With margins set at 0, using Onyx Productionhouse 7.3, the 9800 will print approx 41.8 inch image on 42 inch roll 43.8 on 44, etc. This is considered borderless printing. No matter what size roll you tell the printer it has in it, it will print to about an eighth to a sixteenth of an inch short of the paper's actual edge (that's the left side of the roll paper coming out of the printer - the right side of the print). If you load, for example, a 36 inch roll, tell the printer its a 44 inch roll, and send a 40 inch wide print, with a left margin of 0 it will print around 35.8 inches, cutting off the image just before it would overprint and get ink on the machine (1/8 - 1/16inch before the edge of your 36 inch stock). It is possible that these tollerances will be different depending on what software you send your images with... hope this helps!
May 08, 2008 | Epson Stylus Pro 9800 InkJet Printer
144 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
