Question about Cell Phones
Unlock codes for casio gzone commando
Contract is up. I would like to switch my Casio GZone Commando to AT&T. How do I do this?
    New Friend:
  • 3 Answers
Net banking problems solution
Posted on Jul 14, 2013
SOURCE: need to change digitizer on casio commando
For those of you that need tear down instructions for the Casio G'zone Commando:
We figured these out through trial and error. Hopefully, they will keep someone else from making the same mistakes we did.
Before you start, you will need a tri-wing screw driver. You can make due with a tiny straight way, but it will mess up the screw heads and make the process a little more difficult.
First, power off the phone and remove the back cover and battery.
Next, take out the four screws on the front of the phone. The black trim will snap off in two sections. Turn the phone over and repeat the process on the back.
Next, remove the gray trim on the sides of the phone. It is glued on and will pull off without too much effort. By doing this you will also have to remove all of the buttons and covers. I would suggest keeping each side separate to make reassembly easier. It is not necessary to remove the trim on the ends of the phone.
Next, remove the four screws (two on each side) found under the side trim. This will allow you to unsnap the front section of the phone. This does take some effort and will also remove the waterproof seal.
Now you are ready to start replacing the digitizer if that is your purpose.
The first step is to remove the existing digitizer. The digitizer should be glued in place. If it is not already broken (mine was), there is a good chance that it will break. Do not remove the glue that is left after taking off the digitizer. You will need it to hold the new one in place. Now you see why the phone has to be disassembled to this level, so that you are able to unplug the old digitizer and plug in the new one. Once that is done you are ready to start reassembling the phone.
This is not an easy process and will take several hours to complete. I believe it took us 3 - 4 hours to complete the process.
We were able to take the phone apart, replace the digitizer and get it put back together. Unfortunately, it was not fully operational once reassembled. For the most part it worked; the top speaker did not, as well as the dialer button and the menu key. The rest of the screen was functional, though. As I said, this process was a lot of trial and error on our part so it is possible that we damaged something.
Posted on Sep 09, 2012
SOURCE: casio gzone
i set my boulder to nam2 on accident and my code didnt work after searchin for like 4 months on the internet i found this code ##7764726 (PROGRAM), SEND. SPC Enter 000000 after u enter it go to the nam settings select nam2 go to the second one its like MDN or somethin like that the last four digits should unlock it but u might have to take it to the store to get it programmed again but ull have ur phone back without losin any info u mightve saved on it
Posted on Dec 01, 2009
SOURCE: My Casio Gzone Boulder has stopped recording numbers called
I had the same problem. No caller ID for incoming or outgoing or missed. Then it froze up. I took the battery out to restart it. A day or 2 later I had to get it replaced. No caller ID at all. I got a new Boulder from verizon. It started not receiving calls randomly. I would get some, but friends complained that they called and I did not anser. No voice mail was there or them. Then IT Froeze on the Verizon Wireless wording. Cant do a thing now. 3rd phone onits way. THESE ARE JUNK!!!! I got my first in sept, 2nd oct, 3rd on its way for dec 5. SEND IT BACK FOR A REPLACEMENT.
Posted on Dec 03, 2009
SOURCE: delete apps on my casio commando phone
If they are the crapware apps installed by your service provider, you would have to "root" your phone. However, rooting may void your warranty.
Posted on Dec 12, 2011
SOURCE: how can i reset my gzone commando when its locked?
I went to the store and they did it for me, but you turn the phone off then while it is turning back on, hold the camera and power button down when the LED on the side rurns red, and it should prompt you to do a hard reset, or it might self-initiate, I can't remember. But it's something along those lines, if not take it to the store and they can do it. Hope this helps.
Posted on Jun 14, 2012
My Casio gzone commando c811 says it's fully charged so I unplug it and start using it and it all of a sudden dies why?
probably a memory problem in the battery
if they are continuously being recharged when not close to 5% then they develope a memory level and will not charge past that point
the fix is a new battery
Mar 21, 2016 | Casio Cell Phones
How can reset my gzone to factory settings
  1. From a home screen, tap the Apps tab apps_tab.gif (located at the bottom).
  2. Tap Settings.
  3. Tap Privacy.
    linote.gif To determine if an issue is caused by a third-party app, uncheck Automatic Restore.
  4. From the Personal data section, tap Factory data reset.
  5. If presented, tap OK.
  6. Tap Reset phone.
    linote.gif If presented, enter the current passcode or draw the unlock pattern.
  7. Tap Erase everything.
    linote.gif Allow several minutes for the factory data reset and reboot processes to complete.
    linote.gif To setup the device after completing the factory data reset, refer to Initial Activation and Setup.
Jul 06, 2014 | Casio Cell Phones
Need unlock code!!! :(
I believe it's 0000 (four zeroes).
Aug 28, 2013 | Supertooth Casio GzOne Commando 4G LTE...
Cell Phones Logo
764 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
