Question about Sewing Machines
Riccar 9700 sewing machine electronic
Im having trouble finding the right tension for hemming a dress that has a sheer material. the thread just keeps getting gnarled, and then breaks without even making a stitch. or could it be my bobbin and is it maybe threaded wrong?
bargainbox
  • 1388 Answers
SOURCE: I have a janome 10001,
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FINISHING UP & GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at
Posted on May 09, 2008
  • 8 Answers
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
Posted on May 20, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
  • 1116 Answers
SOURCE: Bobbin thread will not stitch.
Have you had the machine serviced since you purchased it? This is something that should be done at least once a year.
Take the machine to a certified Singer dealer and explain what is happening. There may or may not be something that needs to be adjusted.
Your warranty is still in effect, but is now limited. Attempting to repair it yourself or having someone who is not a Singer dealer repair it will invalidate the remaining warranty.
Posted on Apr 16, 2010
chrismyers67
  • 53 Answers
SOURCE: top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
Posted on Jun 07, 2010
I have a white speedylock 1300DE. Can't seem to get the tension right while trying to serge a hem in a dress. The thread keeps breaking although I have tried many times and tensions.
Try cleaning the tension disks by running some plain (unwaxed) dental floss back and forth between them. Do this with the pressure foot up to release the tension on the disks. If that doesn't help, you can change out the needle(s). The eye could have developed a rough edge that is causing the thread to break.
Aug 21, 2017 | Sewing Machines
Sewing a hem on a sheer (rayon ?) curtain and it puckered slightly along the seamline Used sz 11 ballpoint needle with 40wt rayon thread. Tried tiny stitches then longer ones. Any suggestions??
well aside from trying all the normal things like thread tension adjustments and such , another neet little method is to use a flat piece of thin tissue paper (sew right thru it ) layed over fabric , this will add the stiffness to fabric u may need to complete this task, then very slow and carefull tear the paper away from it to leave the threads behind!! if you think you can get away with it use tissue paper on back side and leave it there , hey holds a hem and pleats real nice !!
Dec 21, 2016 | Sewing Machines
Material keeps getting pulling into bobbin, and thread in bobbin compartment jamming
Two things to check:
1. the bobbin tension. Is it too tight? It should pull out without a ton of resistance but should have just a bit.
2. Is the material sheer or thin? If you can drop the dogfeed a bit you might want to do that or you can sew through tissue paper (on the bottom side) to keep the material from being pulled down.
If those things don't help you might try lengthening the stitch just a tad and make sure the needle you're using is the right size for the fabric.
Apr 08, 2011 | Brother Sewing Machines
Riccor model 939FA thread keeps breaking, not shure if it is threaded correctly, manual lost years ago, thread has been nesting on bottom of material, now just breaking.
Try looking for a manual for your machine here.
http://www.riccar.com/help/manuals/
If your model number isn't listed try looking for a similar model or the number nearest to your machine.
Usually, sewing machines of the same brand thread in the same way. Hope this helps!
Sep 11, 2010 | Riccar R651 Mechanical Sewing Machine
I can't get the tension on my sewing machine adjusted correctly. Right now the upper tension is turned as high as it will go and I've loosened the lower tension but I still have the upper thread looped...
It is possible that you threaded the machine with the presser foot down.
This creates loopy stitching because the thead never entered the tension control. Foot down = closed tension.
Put the settings back to their normal settings.
Raise the presser foot and re thread the machine.
Feb 21, 2010 | Kenmore 12912
Jersey fabric pulls
on the spool case is a little screw turn it. it might be the spool tension to tight for uper feed thread.
Mar 26, 2009 | PfaFF Creative 7570
JONES SEWING MACHINE PROBLEMS
We have a very old Jones Sewing Machine (1960's) we are having trouble with the thread at the moment. When we sew the thread gathers up underneath the material that we are trying to sew. Any suggestions to overcome this problem?
Feb 21, 2009 | Sewing Machines
Having trouble with my bobbin thread
Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine. Good Luck!
Aug 28, 2008 | Brother LS-1520 Mechanical Sewing Machine
Can see alot of thread at the seam
Sounds like your needle threads are not tight enough.
Do some samples using different colored threads, if necessary, to see which needle thread is not doing the job. Then tighten in increments till you get the right tension settings.
It helps if you make notes of the correct settings on that material for the next time. Start a sample notebook, for the different materials you might use with tension settings for each, and if you do any fancy stuff with your serger, like pintucking, puffing, elastic application, ruffling and such.
Aug 12, 2008 | White Sewing Speedylock 1600 Mechanical...
Problems when sewing over heavy jean hems
Are you using the correct type of needle? have a word with your needle supplier and explain the problem. Different threads and different thickness material need different top and bottom tension adjustments.
Can I suggest sew one thickness material at a time with tension adjustments for that thickness. Then change the tensions and do a batch of thicker material.
Mar 29, 2008 | Juki DDL-8700
Sewing Machines Logo
71 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
