6000-1 rockola legend juke box 60th ed.
The lights turn on but there is no power to the cd section.
3 Suggested Answers
  • 38 Answers
SOURCE: juke box will take coins but won't play record
WHAT IS THE POSITION OF THE GRIPPER ARM(CALLED GRIPPER ARM THAT GRABS RECORD?)
OVER THE TOP OF THE 50 RECORDS? NEAR THE TURN TABLE?
IS THE OPERATE SWITCH IN PLAY POSITION ? OFF POSITION ?
DOCTOR FIX.
Posted on Jun 30, 2009
  • 38 Answers
SOURCE: juke box (seeburg 480 serieswill take coins but won't play record
YOU ARE SAYING THE MOTOR DOES NOT SPIN. TRY TO SPIN THE DRIVE SHAFT ON TOP OF MOTOR . DOES THE SHAFT TURN EASY. IF NO THEN YOU HAVE A MOTOR OR LUBRICATION.
PROBLEM.
DOES THE SCAN SWITCH, WHEN PUSHED TO SCAN DOES IT SCAN. IF IT SCANS BACK, AND FORTH 2 TIMES, YOU THEN HAVE A COIN CREDIT PROBLEM (MOST LIKELY )
ANSWER THE TWO QUESTION, OR STATEMENT. TO GET A MORE INTELLIGENT REPLY.
YOU HAVE OVER 2000 PARTS IN THAT MACHINE. YOU HAVE GIVEN A (WHY DONT IT WORK
QUESTION.)( there is no answer to the question. because of limited problem info)
DOCTOR FIX
IN-HOME JUKEBOX REPAIR
6362273300
Posted on Jul 08, 2009
Is there a way to install a aux input on a crosley cr-9 juke box radio? Thanks
You would have to break into the cassette player's audio output section. By finding where the audio joins the main amp of the unit. You couldn't do it via the record input section as that uses a different pre-amp which would not be compatible with CD. Once you find the point where the cassette audio joins the pre-amp section of the main amp, you should be able to take a link, from a pair of phono sockets that you will have to mount somewhere on the unit. If you don't use the cassette anymore than you can disconnect it. If you do want to use the cassette then the best bet is to also install a switch that will switch between the two. You will not be able to have both cassette and CD wires linked to the same pre-amp input. As one will vastly reduce the volume of the other. Which is why you would have to install a switch between the two.
May 02, 2017 | Crosley Audio Players & Recorders
Where can I hire a repairman to fix my Whirlitzer juke box?
go google and type in--- service agents for wurlitzer juke box ---
find and agent closest to you and call him on the phone
Dec 23, 2016 | Audio Players & Recorders
How do I adjust the record speed on a rockola juke box
Check the turntable rubber grommets first, these when worn or perished will give a rumbling sound through the speakers but will also change the speed as they will allow the motor to drop down which will use the other size on the motor shaft
Nov 22, 2014 | Audio Players & Recorders
My Rock Ola 100cd "Nostalgia" Juke Box has a problem: the cd will not turn at all when it is placed on the 'turn table' by the arm. I cleaned the piston on the grabber arm which was not picking up the cd....
Check that all the voltage indicator lights are lit on the power supply, and check the connectors going to the player to be sure they are tight. Otherwise may be a bad player.
Aug 31, 2013 | Computers & Internet
Rockola Model 490 2 Super Sound Juke Box wont power on
(1) Make sure the wall outlet has power. (2)Make sure the power switch is "on" (3) check the fuses. If you discover a blown fuse, be sure to replace the fuse with the correct value. If it blows again, you may have a more serious problem.
May 26, 2013 | Audio Players & Recorders
Juke box will take coins but won't play record
DOCTOR FIX.
May 09, 2009 | Audio Players & Recorders
Rowe juke box
Put in service mode, type 55, then hold reset down while toggling 9 to cut on or off.
Should say free play on display.
Aug 13, 2008 | Wurlitzer Jukebox CD Player
74 people viewed this question
 Grubhead
Grubhead
