How much resolution does the Akai LCT 2070 tv have?
I have an Akai LCT 2070 TV, which works fine. I recently got a new computer and I want to use the tv for my computer monitor. There is a jack for a VGA cable on the tv, to run the monitor cable from the computer. The problem is, the tv doesn't have enough resolution for Windows 8 to run. The monitor has maximum 800 x 600 resolution, and Windows 8 needs something like 1024. Is there a way I can increase the resolution on the Akai so it will work with Windows 8?
  • 298 Answers
SOURCE: Olevia LT23HVX screen resolution
It says 1024X 768 s in pc mode are you connecting
in tv mode or pc mode
Posted on Nov 29, 2007
SOURCE: Insignia LCD TV won't recognize computer input...
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
Posted on Oct 27, 2008
SOURCE: Akai LCT 26AE Universal remote codes for RCA remote
i cannot find the model # to my akai tv/dvd combo where is it? AND ALSO I DO NOT HAVE THE REMOTE TO IT LOST IT DURING MY MOVE. HOW CAN I PURCHASE I NEW REMOTE OR WHICE UNIVERSAL ONE SHOULD I BUY! PLEASE HELP
Posted on Nov 12, 2008
  • 2318 Answers
SOURCE: akai lct 2070 tv switch does not turn on tv-no sound-no tv
Most failures on this TV are due to defective power supplies. If the TV does not turn ON, you should replace the power supply.
Check this website to buy the power supply adapter and hopefully that should fix the TV.
Posted on Jan 21, 2009
  • 4 Answers
SOURCE: I connected my laptop to my LCD TV using VGA
Easy way:
Press and hold Fn key, and then look at the F1-F10 keys.. Most likely it is F7, and has a picture like a computer screen.
So, press and hold Fn key, and then press F7 (or whatever key it is for your laptop). This will change your "presentation" settings, and thus switch back and forth from laptop screen, laptop screen + external screen (TV), just external screen (TV).
If this doesn't work as you expect, just try:
Instructions for Windows XP:
Open the Display Properties window by:
Start -> Run -> %windir%\system32\control.exe desk.cpl,@0,3
(this is the same window where you can change screen resolution).
There you will see two or more "screens", labeled: 1, 2, 3.
Click on "1", and you'll see:
[X] Use this device as the primary monitor
[X[ Extent Windows desktop onto this monitor
Click on "2", this is your TV.. Mark
[X] Extent Windows desktop onto this monitor
Then change the resolution to 800x600.
Click Apply
=> now your TV should start showing you a picture.
You can move your mouse between the laptop screen and the TV screen.
If you want just the TV, you can make "2" to be your primary monitor, by clicking on [X] Use this device as the primary monitor.
Posted on Nov 04, 2009
AKAI LCT 2060 was working well as a TV. Just hooked it up to my PC and the message on screen reads "No Signal" Checked monitor cable and it's good. checked old monitor and it works well. Why...
The display settings on your computer need to be turned down. Set it to 800x600 and move up from there, if the resolution is too high - the TV won't display it.
Feb 28, 2011 | Akai LCT2060 Television
Problem with akai lct 2016
you can buy the new power supply on ebay for less then $20
Aug 28, 2009 | Akai LCT2060 Television
Akai LCT 328STA,Comes on Akai screen appears then goes off.
Akai LCT 3285TA (notice the "FIVE") uses the MLT169A Power supply. This is available from shopjimmy.com for about $100.
Jul 22, 2009 | Akai LCT3201AD 32 in. LCD Television
Akai lct 2070 tv switch does not turn on tv-no sound-no tv
Jan 21, 2009 | Akai LCT2070 20 in. EDTV-Ready LCD...
Power supply adapter inoperable
Click here to find the power adapter for your TV or here as well.
Jan 04, 2009 | Akai LCT2715 27 in. LCD Television
My akai lct 2070 screen has two issues one is that about a month ago the screen went black only viewable with a light next to it and now when the tv is turned on it stays on for about 30 seconds before it...
Inverter
power suply
CCFL assembly
One of these boards are causing this problem, we have them in stock if you need them. the tv is programmed to shut down if all circuits are not functioning properly.
Dec 25, 2008 | Akai LCT2060 Television
Nov 02, 2008 | Akai LCT2715 27 in. LCD Television
NEED AN OWNERS MANUAL FOR AKAI LCT2060 My Tv.not have power
hola nesecito el modelo del boar el tv es akai lct 2060
Jun 07, 2008 | Akai LCT2060 Television
.ct 2070 display not clear
Are all the fonts unclear?
Even when you open a document such as word and notepad?
If the answer is yes, it might be that you've got a problem with your windows setting. maybe you should try adjusting as follows:
>click on properties on your desktop
>click on the appearance tab
>click on effects button
>check the box "Use the following method to smooth edges of screen fonts"
>click on ClearType
Jan 13, 2008 | Microsoft VIEW ERA 19 V191HD LCD 500:1 .29...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
