Question about Poulan 2025 2050 2055 2975 2150 2155 2175 On/off Lever
Fuel line diagram
Need a fuel line diagram for poulan 2050 pioneer chainsaw
SOURCE: gas line diagram for poulan 2050 2.0 CI '97
Gas line diagram for poulan 2050 .
Posted on Oct 25, 2009
  • 518 Answers
SOURCE: What type of oil does the poulan 2050 chainsaw use
2 cycle oil.
Posted on Jun 09, 2010
  • 4088 Answers
SOURCE: where can i find the diagram for the fuel sysetem for a poulan
If the old lines are still attached, just replace one at a time. If everything is lying in a heap, then you will need to do a little sleuthing. Assuming the worst, begin with the line in the tank back end that holds the fuel filter (if it is old too--replace it). Be sure to use original rubber lines, not plastic. To connect the tank side of the line, you will need long hemostats or pliers to reach the tank fitting and the line must be long enough to allow the filter to be replaced from the opening. On the top side of the fitting, the line goes to the upper connection on the carburetor, but first run it to the primer bulb (which should be in good condition as well). Hook it either port, and attempt pumping fuel from the tank. If the correct port, it will draw fuel from the filter into the primer and expel it out the other port after about 3-6 pumps. If nothing, move the line to the other port and try pumping again. Once you get fuel to pump, then run a line from the open port into the tank for the return line. Remove the fuel line from the other port and attach it to the upper carburetor port. Run another line from the lower carburetor port over to the open primer port. Attempt pumping fuel again, this time pulling it through the carburetor into the primer bulb and expelling it back into the tank. All connections are just push-on and no cement required. Don't use more length than required for any section. Hope this helps!
Posted on Jun 14, 2010
  • 16 Answers
SOURCE: what is the petrol/oil ratio for the poulan
The fuel must be mixed 40:1. Also, the manual is here: http://www.mccullochpower.com/node4043.aspx
Just click on the first link. Good luck!
Posted on Jun 27, 2010
  • 144 Answers
SOURCE: Looking for the tool to
Check out Poulan item #530035560. It might be just the tool for you.
Posted on Aug 31, 2011
Poulan chain saw 2050 2.0CL
The Poulan Chainsaw 2050 is a 36cc model with a 14" bar and chain.
Sep 02, 2014 | Poulan Garden
Install fuel line for Poulan 2050 chain saw
What i normally do is slice the hose up the middle to approx 2" take away on half, the hose is now only half the diameter at one end, push this into the top of the tank, take a pair of long nose pliers through the open fuel filler hole, grab the end of the hose and pull it through, trim the end and re fit the fuel filter.
Oct 26, 2011 | Poulan Pro Chain Saw 46cc 20"
Diagram of fuel lines from tank to primer to carb and back to tank for a poulan 2050 chainsaw.
clip_image002.gifFuel components are onthe "Engine Assembly" & "Handle, Chassis, & BarAssembly" detail pages.
Replacement fuel lines can be found at yourlocal chainsaw seller/mechanic. They are different diameters.
Fuel Line Replacement
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Feb 21, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
What is the petrol/oil ratio for the poulan pioneer 2050 chainsaw?
Jun 27, 2010 | Poulan Pro Chain Saw 46cc 20"
Where can i find the diagram for the fuel sysetem for a poulan
Jun 08, 2010 | Poulan 14" Chainsaw
I need a repair diagram for a poulan 2050 that shows just where each gasline goes. Anyone know where to go?
the bottom fuel line that goes to carb lower port also goes to the fuel tank look inside fuel tank threw gas cap hole to find the fuel filter hose is picking up the fuel and bringing the gas to the lower fuel port into carb (the upper from carb goes to prime or return to tank)
May 09, 2009 | Poulan Pro Chain Saw 46cc 20"
I need an operating manual for the poulan pioneer 2050 chain saw please
Go to Poulanpro.com and on the right side of site type in model 2050 appaarantly there might be a type number associated with this but I looked at the number 5 and viewed a manual for this saw. It is 18 pages long. Good luck and if I have helped would you please rate this information accordingly. Thank you
Apr 19, 2009 | Poulan Garden
Poulan 2025 2050 2055 2975 2150 2155 2175 On/off Lever Logo
74 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
