Question about Sewing Machines
Janome 415 stuck in reverse - Sewing Machines
My Janome JL250 is stuck in reverse
Probably the reverse mechanism has stuck. Only suggestion may be working the lever manually to see if it frees up. Other than that, it would need service or replacement.
Jul 15, 2016 | Sewing Machines
Are older models such as the Janome New Home s650 supposed to stitch in reverse?
Your machine is most likely stuck in reverse if that is the only direction it sews.
Feb 11, 2016 | Janome Sewing Machines
Model 18w. Why won't it reverse?
If you read a little over halfway down the web page below, you will find another Janome with the same problem. Perhaps it will help:
Repairing Janome or New Home Sewing Machine
Janome New Home mx3123 reverse button not working
Dec 17, 2015 | Janome Sewing Machines
Why is my janome jr1012 stuck in reverse
Yo need a tech for this, as something inside is jammed.
Jan 13, 2015 | Janome Sewing Machines
How do i reverse stitch on janome 415
usually by depressing the reverse button .
Jan 05, 2015 | Janome Sewing Machines
What is my Janome 415 feeding the fabric backwards? How do I fix it?
You have the reverser in the back stitch setting. When you do an over lock stitch you change the feed direction. It should be a lever. Some have a screw lock to keep it in place.
Aug 19, 2014 | Sewing Machines
Why is my Janome Mystyle 20 stuck on reverse?
It may be in the buttonhole mode, change the stitch selector to straight stitch.
Jul 16, 2014 | Janome Sewing Machines
Where does the spool of thread go on a Janome sewing machine model 415
look for a plastic thread holder about the size and shape of a match stick with a base. It goes on the top of the machine. You see where it is if you google images for your machine
Jan 04, 2010 | Janome Memory Craft 5700
How to thread bobbin in a Janome 415?
Here is a link to the manual that shows how to thread the bobbin. :)
http://www.janome.com/documents/File/ManualFile/415_Instr_book.pdf
Mar 31, 2009 | Janome Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
