SOURCE: My dishwasher runs for bour 10 minutes. Then stops, and flashes PF?
Mine does the same thing. I'm confident that the problem lies in the "computer" which is essentially the buttons for selecting the various wash cycles. That strip is basically a thick band with adhesive on the back by which it is glued to the top of the dishwasher door. There are wires connected to it. The wires run down into the door and connect to a terminal that is built into the door. The inside door panel must be removed to install a new button strip or "computer." Mine was replaced twice in the first year. Now it is three years old and needs to be replaced again. I'm going to look around on the net to see if I can find one.
Davey
SOURCE: Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
SOURCE: PF signal comes on, and dishwasher stops running
PF = Power Failure, did you make sure outlet is ok and not a loose plug? Any short in outlet will do that, OR a loose wire at the motor to the dishwasher. UNPLUG unit and look under it for a gray box that the plug leads from. One or 2 screws will remove that box and verify all wires are connected properly.. MAKE sure unit is UNPLUGGED
SOURCE: Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
SOURCE: Bosch SHU3306UC dishwasher stopped
Make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Hello babe_dog01 - PF typically appears in window when dishwasher is first installed, or when power has been interrupted. HI-TEMP WASH, SANITIZE and START/CANCEL backlighting will also flash. To clear, touch START/CANCEL pad or resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Since you have already done so and it was ineffective contact a professional to move forward accurately. Dishwasher could possibly be experiencing a communication error, wiring failure or faulty control board.
