Question about Rinnai Water Heaters
Rinnai v1200 no water at all from hot taps. any ideas or common faults?
I've gas and water pressure to the unit. no water from unit. could it be water flow control device fault or water flow sensor fault? or something else? any ideas?
    Sergeant:
    Champion:
  • 282 Answers
Check for lyme buildup in the pipes also check for a stuck water shutoff valve.
Good luck,
Marty
Posted on May 13, 2014
  • wa2yyx May 21, 2014
    Having a water softener all but eliminates the build up of lyme deposits. Depending on how hard your water supply is then if it is hard the more lyme deposits will form and clog your pipes with lyme. Take a look and see if you can see any chalky white deposits. If so then you need to have a good quality water softener installed. Just remember that water softeners also need service mainly filling the brine container with saly crystals. Good luck,
CRTN
  • 716 Answers
SOURCE: No water flow from hot water tap with a rinnai tankless water hea
Its A Possibility The Left Over Water In The Hot Is Frozen. If Your Line Is Exposed Outside Somewhere It Can Easily Freeze Up. Turn On The Hot Water Everywhere In The House And If Accessible Check The Lines To See Where The Warmth Ends. You Can Leave One Off Over Night In Hopes That It Will Eventually Defrost.
Posted on Jan 16, 2009
  • 234 Answers
SOURCE: I have a Rinnai system. Good cold water pressure, little hot.
What type of pipes are install on this heater?
Posted on Mar 13, 2009
  • 234 Answers
SOURCE: My Rinnai R94 LSi stops sending hot water
II would think that the unit is going out on hil imit because there is not enough psi on the water coming in.Is this unit on well water or city?If it on well water you have run some cleaner in it every six months.L on the side of the heat or inside and there a toll free number to call talk to a tech.
Posted on Mar 15, 2009
SOURCE: Dip switch settings for Rinnai V1200 & V1500
curios to find out if you had any help on this subjuct at all?
Posted on Aug 01, 2010
senor8
  • 73 Answers
SOURCE: Rinnai Infinity 26 hot water system set to 55
If you aren't getting any error codes, then the heater is probably doing its job. Your problem is probably somewhere in your plumbing system. The most common reason you get this sort of problem is due to cold water mixing in the hot water system. There are a number of causes for a "cross connection" :
-Faulty check valve
-Missing check valve on reciculation return line
-Faulty shower cartridge
-Thermostatic mixing valve set too low
-Faulty thermostatic mixing valve
-Faulty anti-scald valve
The easiest way to confirm a cross connection is to: 1) shutoff the cold water entering the tankless heater 2) open hot water valves around the house. If you still have water flowing at your hot water fixtures, then you have a cross connection.
The rinnai 20 Infinity is perfect but have recently noted a problem. I found the basin hot water tap in the bathroom begin dripping only when the kitchen hot water tap is turned on. I don't know how...
Some taps are designed to release excess pressure but it could just be a dodgy tap washer that leaks when the pressure of hot water in pipe work builds. Change the tap washer in your tap, see if it fixes it, if not it's just the design.
Jul 02, 2011 | Water Heaters
I have had my Rinnai tankless for about 8 years without problems. Recently I am noticing that the water temperature is fluctuating from the set temperature to a cooler temp and then back up to the set...
The Rinnai will shut off it can't maintain the temperature you have set to within +/- 3 degs so I'd guess that might be the problem. The cause can be a few options. Check water flow first; any filters you have in tapware, main water flow etc. get cleaned. The Rinnai has a water line filter in the incoming supply, middle pipe under the heater just after the isolating valve. Gas supply could be the other option mainly being a possible intermittent fault in the gas regulator. Hard to check this one short of just changing it. Final option is some sort of electronic malfunction, pretty rare. I'd start with the water flow issue as you can do this yourself. Checking the gas will need a good technician with digital gas pressure guage to check incoming and working gas pressures; it might just need to be recalibrated. Just hasd a thought about the heat exchanger being scaled up if you are in an arera where water scale is a problem but this would normally take far less than 8 years to be a problem. Sorry can't be of more help; hard when it might be a few different causes.
May 28, 2011 | Rinnai Water Heaters
Same problem with rinnai V1200.starts ok and as soon as you want to ajust cold water,the hot water line gets cold.**** all design
These units need water flow/pressure to work. If you use a mixer to get the right temperature as soon as you try to increase cold to make the water colder you unfortunately reduce the hot flow. Fairly complicated fault to explain, all continuous flow units have the same flaw. Solution is to try and increase flow and the best way is to take any water filters or restrictors out of your tapware. Most taps have the located in the end of the spout. Unscrew the end and remove any restrictors. Shower roses are a bit more tricky to find. This fixes 99% of these problems.
Dec 22, 2010 | Rinnai Water Heaters
Rinnai gas water temperature keep alternating from hot to cold
A fault often found with these units is due to insufficient water flow. Usually this causes specifically the shower to run hot and cold. Try turning on more than one hot supply; if this fixxes the fault you will need to try and increase water flow. Most new tapware/showerware have water flow restictors built in. These are the cause of many problems with continous flow heaters such as the Rinnai. In taps they are usually located in the spout if it unscrews. In showers try the shower hose. Find them and take them out. Also make sure your mains supply to the house is on full.
There are more technical faults but this is something you can easily try first.
Aug 23, 2010 | Bosch & Tankless LP Hot Water Heater
Hi there, I have a rinnai 20 ,the water heats up
Usually this type of fault is down to poor water flow. Basically you are asking the unit to work at a level below it's minimum output. Easy thing to try is to check any filters or water flow limiters in your tapware. Usually these are in the nozzle of the tap. I often take these out. The inifinty reduces water flow anyway and there is no reason to have water limiters. Try turning on two taps at once. If this stops the fault then you definately need to increase your water flow. Make sure the mains water is turned on full. Aslo you can check the cold water filter on the infinity. It's just above the cold water isolation tap (middle pipe as you look at it), turn that off first, the filter is a round plastic nut, unscreww it and clean the filter. Reconnect, turn you mains water back on.
There are other faults but this is by far the most common.
Aug 14, 2010 | Rinnai Digital Remote Water Heater Control...
I have a Rinnai tankless gas water heater and this things beeping and flashing 12 everytime we turn on the hot water the water will get hot but you have to wait for it to stop beeping
Error 12 is failed ignition - this can be caused by many things, but normally a low gas pressure, or no gas pressure upon ignition.
Try turning the hot tap on very slowly till till the control shows burner is lit. Then turn it on faster. If it stays going with no error, you might have a faulty regulator, not opening fast enough to meet demand. Especially common with lpg models,a lot rarer on natural gas.
Oct 27, 2009 | Rinnai Water Heaters
Aug 24, 2009 | Rinnai Water Heaters
Mar 13, 2009 | Water Heaters
Jan 16, 2009 | Rinnai Webstone The isolator EXP tankless...
Water Heaters Logo
172 people viewed this question
Top Rinnai Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
