TOSHIBA 55" INCH .. COLORFUL LINES ON THE SIDE
Need to.know how i can get those colorful lines gone ... its a toshiba 55" flat screen
    New Friend:
Looks like a problem with the cable or screen. i would call an electrition or get a new tv.
Posted on Jul 14, 2013
  • 280 Answers
SOURCE: fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Posted on Jan 30, 2009
ripleymojica
  • 643 Answers
SOURCE: Multi colored lines running from top of screen to bottom
panel is cracked the cost of the repair is usually about 90 percent of the cost of the tv when purchased new. panel and labor. not worth if panel is cracked.
Posted on Jun 02, 2009
SOURCE: Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Posted on Sep 21, 2009
  • 7 Answers
SOURCE: Red color is completely gone out of the LCD flat screen
You can try performing a factory reset of the TV. Go into the service menu (Press, then release the INPUT button on the remote, then key in 2580). Scroll down to "Other Settings", then go to "EEPROM Init", then press enter, select YES and press enter. This will reset the TV to the factory defaults. Good luck!
Posted on Jan 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a Flat screen
Are the lines all the way across the screen? or just a few? Solid black - or trannslucent?
Like this??
Horizontal drive has either data, voltage, or control problem from the pixel registry circuit......get it serviced before the problem spreads causing further damage.
However, in all likelyhood, the panel itself is bad. The Bravia line has had a bad rap about the faulty displays, and at $1800 replacement (plus labor) - it may be time to call SONY direct to complain!
Thanks!!
nc
Posted on Apr 02, 2010
My toshiba 50 inch plasma tv model 50hp66 powers on but has no sound or picture
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 18, 2015 | Toshiba 50HP66 50 in. Plasma Television
WHY I HAVE GOT HARITONZAL LINES ON TOP OF SCREEN ON TOSHIBA LCD 37RV635D
sounds like the same problem as with most screens. it could well be the screen as gone
Apr 26, 2014 | Toshiba 37RV635DB Regza 37-inch Widescreen...
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Jul 24, 2011 | Toshiba REGZA 52RV530U LCD TV
My Toshiba Satellite P105-S6147 PC Notebook - has two problems - The screen has thin colored lines running vertically in about 4 places on the monitor and a 3 inch wide "ghost" band on the right...
Sounds like your display panel needs to be replaced.As far as your speakers they sound to have gone bad if it plays sound externally but not on the onboard ones.
Feb 04, 2011 | Toshiba Satellite P105-S6147 Notebook
Fine color vertical lines in right and left side of screen
Jan 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My colors all of a sudden went out of wack
Is there an advanced convergence setup anywhere in the menu where the screen displays a grid? If so, you might want to get into that and move along the grid to each section that looks off. Adjust until the color falls behind the gridline, and move on to the next. It can be a time-consuming process, but should take care of your convergence issues.
Jan 20, 2009 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 COLOR PROBLEMS
turn your red screen voltage down till you get grey, your convergence out puts will need replacing
also the limiting resistors usually a low resistance, cheers parts from global look for stk -*.*
Oct 08, 2008 | Toshiba 55H70 55" Rear Projection...
Green line on each side of the plasma display.
Anybody knows how to reapair about vertical color- stripped lines appeared on screens and some trace of greenish images exist after each images changing, my TV is Toshiba Plasma Color 42HP83, I appreciate , thanks
Jun 05, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
