Question about Lux Programmable Thermostat Atx500e
How do I get fan to shut down auto with no G wire in new thermostat
  • Lux Master
  • 17,326 Answers
We need make and model numbers from the unit and the thermostat.
Posted on Jul 18, 2013
I have a honeywell thermostat, It keeps blowing even when I try to turn it off. Could you please tell me what is wrong with it? And can I fix it myself?
Do the easy stuff first! Is this a new install or has it been working well for a time and now it is not? Is the entire unit continuing to run or just the fan? Thermostats generally turn the unit on and off when the desired temp is reached but the fan itself (not the compressor or heat strips) typically operates in 3 modes, off, on or auto. check the fan setting.
Nov 15, 2014 | Honeywell TH5110D1022 Focus PRO 5000...
Honeywell ct87n wiring schematic
These are color codes wires for terminals that control fan relay,start,stop, temp-up/down ect. Also you can trace out those wires, Where they are going and what terminal on the wiring schematic they control.
Jun 27, 2014 | Honeywell Ct87n "the Round" Heat/cool...
Water heater
Guessing that you have 240Volt residential non-simultaneous electric water heater? And that you have 30 amp breaker and 10 gauge wire. And that water heater is located within 100 feet of breaker box. And there are no leaks running hot water out of tank. And that you installed fully brand NEW elements of same wattage as old elements. And that fully brand new thermostats were installed, and wiring exactly duplicates wiring that was present before. And that factory-insulation was re-installed over elements and thermostats.
1) Guessing the 'hot water shut off' means the ECO red reset button located on upper thermostat keeps tripping and cutting off electric power to water heater?
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
http://waterheatertimer.org/How-to-test-water-heater-wires.html
2) If the ECO is tripping, then water is getting too hot, or there is shorted wire located near the upper thermostat, .
Typically replacing both thermostats and replacing elements will solve this problem .... assuming that new thermostats and elements are good, and wiring correct.
Double-Check your wiring on upper and lower thermostats.
Test wires for short.
Make sure factory-insulation is re-installed over thermostats so cool room temperature will not affect temperature reading.
Check that thermostats sit flat against steel tank.
Many short draws hot water can also cause stacking event that will trip circuit breaker.
3) Add comment and say what you find using checklist above.
Be careful to explain findings fully, using same words found on links above, so illuminated diagnosis can be made.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 28, 2012 | Water Heaters
I have a Rheems Criterion Furnace and the main blower does not kick on any more. The ignitor coil glows, the burners kick on along with the venting fan and stays on for roughly 1 minute. The main blower...
Yeah i would change out that board .Should be a 3 amp fuse so maybe as simple as that but if not a cycling blower motor is a tell tale sign of curcuit board
Nov 21, 2010 | Water Heaters
Rheem tankless shuts down on it's own.
Check to make sure wire is solid copper thermostat wire and not stranded
Aug 15, 2009 | Rheem Tankless Hot Water Heater...
Gas heater shuts off after about 3minutes and have clean filter rinnai rce-329h gas heater
I have a problem with what you are asking,, the numbers you have are for a fan convection ROOM heater,, does the fan come on within this 3 minutes of running, if not it could be over heating and shutting down on a safety, if it does the thermostat could be bad and it is reaching the desired temp and shutting off like it shoud,, check the thermostat to make sure it is working properly,, set it at it's lowest temp turn on the unit have a themometer infront of the air flow see if the temp is the same as the setting,, how old is this unit, it may just be time to change with new,, if the controls are bad this unit sells for about 600 and to replace these parts is about 400, go to there web site,, write back and let me know how it goes,, good luck
Jun 22, 2009 | Water Heaters
Lux Programmable Thermostat Atx500e Logo
42 people viewed this question
Top Lux Water Heaters Experts
Gene Haynes
Bill
Level 1 Expert
Are you a Lux Water Heater Expert? Answer questions, earn points and help others
