SOURCE: I have a Deere LX188 mower, while mowing the
you need to check the seat switch first then have the park brake switch looked at.is there power to the starter relay?
SOURCE: John Deere LX188 lawn tractor battery discharge light remaining o
Check the brown wire feeding your voltage regulator,its between batt and steering wheel behind left side of frame.LX100 series machines had a problem with brown wire not fully contacting terminal in regulator.You will know you had bad contact if plastic is discolored.
SOURCE: John Deere 165 will not
"One click" tells me it's a connection issue. Remove and wire brush the ground and battery cable connections at the battery, chassis, starter and starter solenoid.
SOURCE: scotts by john deere riding
Very high likelihood you have fuel line problems. Disconnect primary fuel line from bottom of fuel filter and blow compressed air back up the fuel line to the gas tank. This will clear the line of any trash. Reconnect fuel line to filter. Then remove spark plug and spray a couple of sprays of WD-40 into the cylinder.. Re-install spark plug and then restart. WD-4- will act as a starter fuel and will start the engine for enough rounds to get fuel pump to working to normal run.. Good luck.
