Question about Golden Technologies Liteway 3/4 Wheel Travel Scooter
Battery wireing for litway gl-100
Need the battery cable hookup for a liteway scooter gl-100
3 Suggested Answers
  • 692 Answers
SOURCE: Our Liteway scooter has been
terry, did you replace both batteries? If you did check your wiring connections on the batteries. Make sure that the polarity of the wiring is correct( red to positive and black to negative) and if you replaced just one battery then you have to replace the other one also. Once you have 2 new batteries installed and have made sure the wiring is correct. Turn on the scooter and see if you still get the flashing lights look at your manual and see that the 3 flashes mean a short between the batteries and the motor. If you continue to get the error you will have to contact your local provider or a service company to check the scooter.. Hope this helps
Posted on Sep 28, 2010
wcdoc1953
  • 280 Answers
SOURCE: I need to replace the
This scooter requires (2) 12 volt 15 Ah batteries. Typically you would open the case and replace the two batteries inside not the entire case and batteries.
Locate the screws that hold the case together and open it. Make a diagram of the how the batteries are connected. Obtain the new batteries locally or on-line, install and fully charge.
Hope this helps.
Posted on Apr 24, 2011
I,m told i need 2 batteries but i only have a black box type
Hello Val,
The battery pack is not broken out in any of your FACTORY technical publications... www.goldentech.com is PERFECTLY USELESS (only offers to direct you to "LOCAL DEALER"
They only call them Gel-cells.
Looking on AMAZON... opportunities abound...
(personally... there no way I'd buy from ANYTHING
Without taking to a HUMAN... on how to open that battery box)
The case seems to be an important part of your units portability...
So as to not compromise your MOBILITY...
I am SUGGESTING you should contact ...
(to not VOID WARRANTEES)
Golden Technologies
401 Bridge Street
Old Forge, Pa 18518
or CALL TOLL FREE
1-800-624-6374
or use the URL (link) below to go to
their web-site
Home Welcome To Golden Technologies
live chat (was dead&gone when I tried)
http://www.gruberpower.com/search/node/liteway%203/4
Aug 07, 2016 | Golden Technologies Liteway 3/4 Wheel...
I'm trying to find out the battery hookup for a Merits S549 Scooter; had to replace the batteries and want to make sure I hooked them up correctly
there should be two sets of cables, 1 set per battery, do not put one cable on one battery and one on another. Black is - and Red is +. the each cable plugs into its connector into the scooter system.
http://www.meritsusa.com/UploadFile/common/file/20160125/20160125064145_5387.pdf
Apr 22, 2016 | Electric Mobility Merits Electric...
Liteway 4 scooter
hi John, i can't remember what the coupler looked like, so lets recap, your mechanic has fitted to a new gearbox to the existing motor right using the existing coupler ??? , grease or no grease do they connect okay ???
Regards
Rob
www.facebook.com/gewizrepairs
May 26, 2014 | Health & Beauty
Mobility diagram
Hi, send me a picture of the case contectors and i 'll show you how to wire it up ?
Regards
www.gewizrepairs.com/fixya
Oct 31, 2013 | Golden Technologies Golden Liteway...
I need to replace the battery case for my Golden tech liteway scooter. Or i need to see a wiring diagram. Can you help?
Hope this helps.
Apr 24, 2011 | Golden Technologies Golden Liteway...
Our Liteway scooter has been unused for a couple of years. We purchased a new battery and charged it up but it won't run. The freewheel device is in place and we've done all the troubleshooting we know per...
Sep 28, 2010 | Golden Technologies Health & Beauty
Scooter battery shows full charge but scooter does not move ! red led light flashes 8 times !
Plamont unfortunately that flash code usually means a controller error. The controller is the brains of your scooter. Take the seat off and remove the rear shroud that covers the batteries and motor/gearbox assembly. Check all the wiring connectors for damage or loose connections. After checking the connectors turn the scooter on and see if you still get 8 flashes.
Did Medicare purchase the scooter? If so they will pay for most of the repair costs. You can contact your provider that sold you the scooter or a repair service Repair Xpress@ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Sep 12, 2010 | Golden Technologies Liteway 3/4 Wheel...
I was going up steep hill and it shut off. Won't go on at all.
This is highly unusual, so I would like you to check a few things first:
Thermal overload. Most scooters when pressed too hard will overheat and trip the breaker. This is to protect the scooter. If this happens, you wait 5 minutes and reset the breaker.
Otherwise:
Reinstall the battery pack.
Turn on the unit.
Does an L.E.D. start flashing on the dashboard?
If so, what sequence?
If not, when was the last time the batteries were charged?
Fully charge the batteries.
If none of this helps, contact the dealer you purchased this from or Golden Technologies technical service department. 1-800-624-6374 Ext 501
Aug 08, 2010 | Golden Technologies Liteway 3/4 Wheel...
Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
Golden Technologies Liteway 3/4 Wheel Travel Scooter Logo
127 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
