Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
Shaded area on tv
The Bulb was changed less than a year ago the screen to the left is darker and not square it is an area about 1 1/2 inches from the bottom about 8-9 inches to the top left side.
CHECK THE OPTICAL ENGINE. THEN AGAIN THE LG BRANDS BELONG TO GARBAGE TIP
Posted on Oct 25, 2007
SOURCE:
My tv has a darker shaded area in the middle of the screen ,,is this an easy fix?
No it isn't an easy or cheap repair. It is usually caused by the screen having some type of damage to it. Usually cheaper to buy a new TV.
Dec 14, 2015 | Televison & Video
Dark Band on Samsung projection TV
most likely optical engine issue----bad light engine.
Aug 27, 2012 | Samsung BP96-01073A E-Series Replacement...
I have an akai 50 inch tv. I have a darker area on the left side of the screen about 3 inches wide. I replaced the bulb but the problem is still there. Any idea how to fix it. Its a projection tv.
Convergence is dead.Replaced the 2 convergence ICS,should solved this problems.Try website Tv repair World.com to buy a Whole convergence board to replaced.Samsung/Akai use the same convergence board.
Feb 26, 2010 | Akai PT4298HD Rear Projection Television
42 inch samsung lcd tv darker on one side
Its one of two things, bad lamps in the panel or bad Tcon board
Dec 24, 2017 | Televison & Video
I have a Westinghouse 47 inch flatscreen LCD TV. The top two inches of the screen are darker than everything else. The picture still shows up in that area, its just darker. I have tried to adjust the...
-Have you try frame Shape...? If not then try frame Shape.
What it is...? It's a shape like rectangle, square and taller area or wider picture.
On the remote control should have a button label " P. Size"
-Try this button . it will change the shape of the picture. If it's still not help then a new TV.
Good luck
Mai
Jan 25, 2018 | Westinghouse TX-47F430S 47 in. LCD TV
My JVC 56G787 is dark and bright is turned all the way up
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | JVC HD-56G787 Television
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
I have have this TV for almost 3 yrs..now have a shaded area on the left side
The dark side of the screen causes of the lamp alignment or prism glass alignment. This is critical you have to consult your LG technician to do this. But if you have any background o repair consult the service manual. Please careful not to touch the prism quarts so that you maintained the clarity of picture and brightness on the screen.
Aug 27, 2007 | LG RU-52SZ51D 52" Rear Projection...
Losing image
i have a very simliar problem, i found a way around it by changing a seeting in the advanced options. somehow, my horizontral position was changed from wahtever the default was to 88, which set it too far to the left. set it back to 50 and while the image was good, the menu is still in the oddly placed area....oh well....hopefully it's not the bulb, i just changed the damn thing less than a year ago
May 12, 2007 | InFocus ScreenPlay 4805 Multimedia...
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Ekse
