Question about Samsung HLR5087W 50" Rear Projection HDTV
Color replacement wheel - Samsung HLR5087W 50" Rear Projection HDTV
Optoma gt700 is all green after replacing color wheel
we mainly retail or distribute color wheel, light tunnel ect sparet parts for projector or TV, so we have experience on that problem you faced.
perhaps you ordered a compatible color wheel,but it is not big trouble. compared with your old wheel, you will find a black tape, just make it as the same position as your old wheel, it will be ok.
Jun 25, 2014 | Optoma Office Equipment & Supplies
I have a Philips dlp60pl...the picture flickers and the color turn red to green then back to normal color, could this be the bulb.
No.Do the tv pictures colors back ground flashes black and white when this problems happen?Ur tv now make any humming sound or motor noises?Yes,than the tv colors wheel it is the causes and the problems.The tv colors wheel it is dying and starting to be worn out.The tv colors wheel itself it is starting to come out of the spinning motor axis.The tv colors wheel have to be replace to fix this problems.The tv colors wheel sit way back of the tv,must have to take out many mechanical parts before u can even come to the tv colors wheel itself to replace it.If u have no mechanical skills don't tries to replace the tv colors wheel ur self.Hire a tv Tech. to replace the tv colors wheel it is ur best bet.
Sep 24, 2011 | Philips 60PL9200D Projection Televisions
I am thinking about buying a Samsung 72" DLP (Hlt7288wx/xaa) for $500. The seller says a tv repairman says it needs a color wheel replacement. Do you think this is something that would be difficult to...
Yes,tvs with a colors wheels design into it are more prone to brake down and more quickly than tvs without colors wheels design into it.The colors wheel in the tv spins at 12000 RPM at every cycles to make and let the tv Light Engine shine a beam of light into a colors wheel to make and have a colors spectrums to make it to works for the tv.No projection tv with a colors wheel are not easily to be replaced have go through alot of trouble to replace a colors wheel itself.The tv colors sit way back of the tv have to take out many tv mechanical tv frames bulk heads even than can come to the tv colors wheel itself to replace it.Take ur $500 buck buy a "40 LCD tv less worry less head aches.
Aug 22, 2011 | Samsung HLT7288W 72" HDTV
After watching tv for a while I loose the color??
This tv have a colors wheel.The colors wheel effects is dying or dead are make loud squiling noises,motors noises and loose colors and flashes or flashes black&white with the picture.The colors wheel,must be replaced to solved this problems.The colors wheel is pretty hard to replace,because u require take many machanical parts out.Before u can even replaced the colors wheel itself.So hire the tv Tech. to replaced the colors wheel.
Nov 24, 2010 | Samsung DLP HL-P5663W 56" TV
I have a samsung hln5065wx/axx it has a black and white pitcher some times it will freez up a look like a xray pitcher
This tv have a colors wheel,it dead.Make loud motor noises,high pitch squiling noises,have pictures flashes black&white with the pictures.All these are the causes of the colors wheel.The colors wheel is dying and dead is spinning off of it motor axis.The colors wheel,must be replaced.Hire a tv Tech. to do the job.Because it not easy to replaced the colors wheel,u must take out alots of machanical parts even can come to the colors wheel to replaced the colors wheel it self.
Oct 23, 2010 | Samsung HLN5065W 50" Rear Projection...
Replacin the color wheel in HLN5065
U machanically incline?Not hire a tv tech. to this,because,u have to take out many machanical parts,before even can take out the Colors wheel to replaced.Try website like You Tube Type in Samsung colors wheel replacing.U will get a tutoring by some one doing or trying to replaced the colors wheel.
Jul 12, 2010 | Samsung HLN5065W 50" Rear Projection...
62HM95 lamp will not work after color wheel motor replacement
I have the same tv 62HM95 can u tell me what is the color wheel
Jun 18, 2009 | Toshiba 62HM95 62" HDTV
Color wheel replacement.
Here is photo step by step replacement of color wheel.
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
Hope this helps
Oct 05, 2008 | Samsung HL-R5078W 50" HDTV
Color Wheel problem
Replacing the color wheel can sometimes switch Red With Blue. If you remove the jumper it could fix the problem.
Here's an article on it's replacement.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Aug 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W Color Wheel
 The color wheel that goes in an HLP4663WX/XAA is:
  BP96-00674A
 This is the correct color wheel.
Oct 20, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLR5087W 50" Rear Projection HDTV Logo
19 people viewed this question
Jerry Greenberg
Jerry Greenberg
