Question about Jacuzzi Home
Jacuzzi BK84000D Flush Valve
I need a flush valve for a Jacuzzi BK84000D toilet tank. Where can I buy this and for how much?
snap101
  • 117 Answers
SOURCE: Flush valve drops before bowl completes flush
is the flapper weighted? if it is it will cause it to shut prematurely. one thing you can do is increase the water in the tank. you might have to buy a pvc cuppler to put on the over flow to allow it to fill up more. korky makes a nice flapper thats not weighted
Posted on Aug 01, 2009
tbirdfan1
  • 3051 Answers
SOURCE: tank won't fill unless I push down on flush valve inside toilet
Hello there
ok first when the valve inside of the tank is wearing out or is dirty this will happen you can take a washrag and clean the underside of themechanism really good and also the part that it rests on providing that you can get to it
if there are no screws to adjust the water reg valve see if it will turn clockwise to shorten the arm making it turn off or if needed turn it counter clock wise i have had to also slightly bend the arm down in some units to make the water stop after the tank is full so you may want to try that too ok
hope that this helps
best regards michael
Posted on Sep 13, 2009
  • 349 Answers
SOURCE: Need a flush valve / float assembly for my one
1-800-891-0896 http://www.efaucets.com/f/jacuzzi-ez33-959.shtml
Check this web site out I hope it will help.
Posted on Jun 05, 2010
SOURCE: replacing flush valve jacuzzi toilet
I am having the same problem. Looks like we'll need to order directly from the manufacturer.
Posted on Jul 19, 2010
  • 7 Answers
SOURCE: Flapper valve closes too quickly
Try shortening the chain from the flush handle to the flapper. If it's too long, the suction can pull the flapper back before the toilet flushes.
Posted on Apr 29, 2012
Why won't my jacuzzi toilet flush
You just check the chain inside the water closet where the one end is connected into the flush handle,and the other end is connected to the flush valve (it is the rubber cap which is covering the outlet of the water passing into the toilet bowl itsef)..most common problem is the chain is cut,or sometimes it is just need to udjust shorter thats why it can tug the flush valve when you pull the flush handle.
Sep 12, 2014 | Home
Hi all, I have a Jacuzzi SWP-1 Perfecto Dual
Hi, Go to amazon and look for replacement parts.... here:
Jacuzzi SWP2959 Perfecta Dual Flush Two Piece Elongated Comfort Height... I hope this was helpful.
Mike
Aug 15, 2013 | Jacuzzi Home
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
Water is seeping past flush valve causing tank fill valve to refill tank
Replace the flapper unit and if needed the lower unit it drops into, one or the other is causing this and Flapper is the most common.
Dec 13, 2012 | Jacuzzi Bath Perfecta EZ33 959 White round...
OCCASIONALLY HEAR SMALL LEAK COMING FROM BOTTOM OF TOILET...WATER BILL UNUSUALLY HIGH...(FAINT HISSING SOUND)
either the fill valve is running and water is draining into the bowl via the overflow tube in the tank or the flapper is bad (or foreign matter) and it is allowing water to escape into the bowl through the flush valve slowly...causing the tank to drain and the fill valve to run every few minutes or so. start by inspecting/cleaning or replacing the flapper and hopefully that will do it because a one piece toilet flush valve needs a special wrench,to remove it, that you use with a ratchet. If you buy a new flush valve, it comes with the wrench (glorified piece of plastic) and is not too difficult to get the flush valve out. you can get a replacement at http://www.plumbingpartsdepot.com/ They do mail order, too. All you need is the toilet type - a four digit number embossed in the tank starting with a 2. hope this helps but if you need anything else just ask:)
Jul 29, 2011 | Porcher VENETO II One-Piece Toilet -...
I flush the toilet, tank fills up and cuts off, but the water leaks out, then the tank cuts back on to fill up and this is a vicious cycle.
Go to the hardware store and get a new flush valve flap made by Korky and install it. Your flush valve flap has worn out and allowing water to leak through.
Oct 12, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
I have a Jacuzzi Perfecta toilet (bought Aug. 21, 2008) at Lowe's. I have the sales ticket. The toilet works fine. The tank fills very slowly (2 minutes) before it shuts off. It also makes a whistling...
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Jun 10, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Replacing flush valve jacuzzi toilet
A fluid master should be universal and as long as it will allow the water to reach set mark on overflow pipe.
May 16, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Seal between tank and toilet are leaking
Purchase a new flush valve at hardware store.
You'll need cresent wrench, locking pliers, small pipe wrench, small pail, towels, putty knife.
turn off water supply, flush toilet to remove water from tank, soak up remaining water with towel in tank, remove supply line from valve on botton of tank (you may have to hold valve with pliers inside the tank to keep from turning.) Clean area inside tank with putty knife where new valve will seat. Install new valve, attach supply line, connect overflow tube. turn on water.
Check for leaks.
Repeat if necessary. :-)
Oct 27, 2009 | Jacuzzi Home
Home Logo
61 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
