Question about Home
Jacuzzi toilet bk84000d
Where can I order a Fill Valve for Jacuzzi toilet model BK84000D?
tbirdfan1
  • 3051 Answers
SOURCE: tank won't fill unless I push down on flush valve inside toilet
Hello there
ok first when the valve inside of the tank is wearing out or is dirty this will happen you can take a washrag and clean the underside of themechanism really good and also the part that it rests on providing that you can get to it
if there are no screws to adjust the water reg valve see if it will turn clockwise to shorten the arm making it turn off or if needed turn it counter clock wise i have had to also slightly bend the arm down in some units to make the water stop after the tank is full so you may want to try that too ok
hope that this helps
best regards michael
Posted on Sep 13, 2009
  • 81 Answers
SOURCE: We bought the Jacuzzi Perfecta toilet 1 year ago
The complication here is that Jacuzzi does not make toilets anymore than Sears makes refrigerators. In Sear's case their Kenmore refrigerators are from Whirlpool with the Kenmore name.
It is my understanding that Eljer was the manufacturer of the toilets with the Jacuzzi name typically sold at box stores. With that as a starting point, surf the web for any Eljer toilet tank replacement parts and see if you can find a similiar flusher
Posted on Jun 02, 2010
  • 349 Answers
SOURCE: Need a flush valve / float assembly for my one
1-800-891-0896 http://www.efaucets.com/f/jacuzzi-ez33-959.shtml
Check this web site out I hope it will help.
Posted on Jun 05, 2010
  • 349 Answers
SOURCE: I have a Jacuzzi Perfecta toilet (bought Aug. 21,
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Posted on Jun 10, 2010
Testimonial: "I took the valve apart. It is working like it is supposed to. That sure is a tiny hole for the fill water to shoot through. that is why it is so slow. It still whistles when filling. Tnx Walter Neaves"
SOURCE: replacing flush valve jacuzzi toilet
I am having the same problem. Looks like we'll need to order directly from the manufacturer.
Posted on Jul 19, 2010
My Jacuzzi toilet is making a foghorn sound after flushing. I read in FAQ to close the fill valve slightly but I don't know how to do this. Please help.
IF there is a valve on the water line in the toilet close this off it should turn clockwise to slow down the pressure
Jul 12, 2017 | Jacuzzi Home
Why would the jacuzzi perfecta toilet handle comes off and now won't fill, just keeps running
Handle retaining nut either came loose or broke off. Check the flapper valve, if its not completely closed water will keep running out, and fill valve will stay open trying to fill the tank.
Aug 30, 2014 | Jacuzzi Perfecta White Round 2-Piece...
Have a Jacuzzi toilet... trying to replace fill valve... easy enough, however. i can not get the white plastic bolt loose where it connects to the fill valve and hose loose. cant get enough leaverage from...
If you mean the nut on the outside bottom of the tank it should be only hand tight. but I would suggest either a channel lock pliers or perhaps a basin wrench. If you are replacing it you may tru just cutting it with a small hacksaw.
Aug 11, 2011 | Jacuzzi Bath Perfecta EZ33 959 White round...
I am looking for replacement parts for my jacuzzi one piece toilet. Nothing in the tank seems to be standard and I am having difficulty locating a replacement douglas valve and gasket.
Any place like lowe's that sell the Jacuzze brand should be able to order the parts you need or you can go to the Jacuzzi web site and find a dealer there or order the parts from them.
http://www.jacuzzi.com/baths/pages/toilets-sinks
Feb 06, 2011 | Jacuzzi Toilet Onepiece Donnieli ...
My jacuzzi toilet doesnt fill with enought water in the bowl to remove waste from porcilin when flushing
Hi, W/D here.
Check the water level in the tank. The force to flush waste comes from there. Normally the fill line is cast into the back of the tank, but sometimes it is on the overflow tube. Raise the level if it is low.
Also, make sure that the tubing from the fill valve is connected to the over flow tube (the tall tube).
Best regards, --W/D--
Jan 29, 2011 | Jacuzzi Bath Era BK37 959 White toilet...
Toilet does not stop filling, water keeps running
Replace your toilet fill valve with a fluidmaster 400A
Click here
http://411plumb.com/how-to-replace-your-toilet-fill-valve-with-a-fluidmaster-400a
heatman101
Jan 16, 2011 | Jacuzzi Home
My jacuzzi toilet won't quit filling, I have adjusted the fill valve and that hasn't worked. I read a post about a small metal clip below the fill valve, mine is red plastic but it fell off when I...
You gonna have to replace the whole fill valve mechanism. Go to the hardware store and get the Korky brand, because they work like a champ and they are super quiet. Don't buy Fluid Master because they clog easily and are junk. Learned that the hard way after having to 3/4 of them on a 42 unit apartment complex.
Sep 13, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Replacing flush valve jacuzzi toilet
A fluid master should be universal and as long as it will allow the water to reach set mark on overflow pipe.
May 16, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Home Logo
46 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
