Question about Garden
Honda hhh25 hedgetrimmer
Hi i have not had my honda hhh25 4 stroke hedge trimmer long and it blows alot of blue smoke out and the motor dies down until it stops, would this mean it has not got enough or to much oil? regards jeremy
  • 398 Answers
SOURCE: Craftsman gas hedge trimmer
yes the throttle isnt giving enough gas. there should be two screws side by side somewere near the trigger next to the cable that moves when you pull the trigger. play around withthose screw a few hours youll get it.
Posted on Feb 26, 2009
  • 154 Answers
SOURCE: Craftsman 22 in. Electric Hedge Trimmer- blade stopped moving
oil them or loosen bolts and try
Posted on Aug 03, 2009
  • 28 Answers
SOURCE: Husquarna petrol hedge trimmer starting problem
it could be extremely flooded with way to much fuel. in the motor.take out the sparkplug turn the ignition switch OFF and pull the starter rope...if there is a lot of fuel blowing out of the cylinder...thats your problem.....buy a new sparkplug and try starting it with no choke and full throttle with the new sparkplug fitted....see how you go.....or its warn out and has no compression to fire up the fuel.....in this case ..its time to upgrade
Posted on Aug 06, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Remington Axcess hedge trimmer wont run at all.
Check your fuel lines. It is probably getting air into the system. Also check inside the gas tank to make sure the fuel pick up line is still attached.
If you need more assistance please provide an exact model number and I can better help you.
Kelly
Posted on May 03, 2010
  • 5 Answers
SOURCE: My Black and Decker hedge trimmer's blades won't
Your blades are stuck together.
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
Posted on Jun 09, 2010
Hi should my 2014 450 sxf blow a black ish kind of smoke when revved an on down rev a bluey black smoke think its called blow by? And what should I do to fix it? Could it just be a spark plug? Thanks
is yours the 2 stroke model or 4 stroke model ? 2 stroke model they do burn oil so it would be blue/black smoke, 4 stroke should be gray/blue color, if 4 stroke model it could be the timing is out a bit or the spark plug is not set right. or weak dispak. it can also be the fuel to air mix is out of alignment.
Jan 29, 2017 | Cars & Trucks
How to replace the motor and where do I buy a motor for the trimmer?
ebay,and bing search, How to replace the motor hedgetrimmers
Jul 13, 2015 | Garden
Why does husqvarna 123hd60 bogs on revs
Mix up some "carburetor & fuel injector cleaner" in a batch of fuel, Nathan, at the rate specified on the bottle of cleaner. Run it through the hedge trimmer just like normal fuel. For right NOW, you can use the choke to keep the trimmer running. As the cleaner works, you should need less & less choke to keep it going.
It may take a while.
Next time you store that trimmer for winter, drain it fully and run it until it dies from lack of fuel. Then it won't form varnish on the carburetor jets over the winter - that varnish is what's causing your problems now.
Aug 04, 2014 | Husqvarna 123hd60 Handheld Dual Sided...
What do need to do? My trimmer is starting to smoke. Do I oil it or what?
If its smoking reom the exhaust the no, its smoking because its probably running too rich or there is too much oil in the fuel (incorrect mixture)
Jul 31, 2013 | Remington RM4022H 22-Inch Dual Action 4...
I have a weedeater brand hedge trimmers 18 inches long. I rebuilt the carb and replaced fuel lines and filter. The unit ran fine until the last two times that I have tried to use it. It will run and...
have you checked the fuel plate thats in the bottom of carb? they tend to dry up and because rubber the 2 stroke fuel makes it dry and shrink, then it no longer pumps fuen into cylinder
Mar 01, 2011 | Weedeater Gas Powered Hedgetrimmer...
What is the petrol / OIL MIX FOR MCCULLOCH M542P hedgetrimmer
Most newer 2 stroke engines run on 1 part oil to 50 parts gas.
Use a high quality 2 stroke oil mixed into the gas.
Sep 04, 2009 | McCulloch Garden
Gears on my Mcculloch Chester 510 Hedgetrimmer may
The problem was with a stripped gear on a mcculloch hedge trimmer. I chucked it on the scrap heap and am borrowing my father-in-law's machine until I have time to shop for a new trimmer. Problem solved, but sadly not owing to your service this time.
Jun 16, 2009 | ECHO, Inc. 20 In. Double Sided Hedge...
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
