We just got beachcomber jacuzzi. Model 321. We plug it in and nothing happens. No power but the outlet works with others things so we know its not the outlet. Any advice on what to do?
djSilver
  • 10 Answers
SOURCE: BOSE 321
Have u tryed other disc ? if so your Bose system my have read a corrupted disc u may want to change out your IDE cable and if that doesn't work then corrupted files has made its way to one of your main broads.
Posted on Apr 24, 2008
  • 9 Answers
SOURCE: Won't turn on
try the fuse in the plug
Posted on Apr 26, 2008
  • 234 Answers
SOURCE: Craftsman air compressor will not start
I am assuming that there is no air in the machine now. Otherwise it will not turn on if there is enough pressure in the tank.
If it will not start at all, the on/off switch on the pressure switch may not be turned on or it is defective.
You can also check the reset switch on the motor (red button).
These are very simple setups and it shouldn't take too long to troubleshoot.
Posted on Apr 18, 2009
SOURCE: Brother intellifax 770 No Power? LCD is blank
I have the same problem: no LCD. Determined that the outlet was fine, but the machine did not respond when unplugging/plugging it in. Support said I needed to take it in for repair. Unplugged it, unscrewed the bottom plate, and found a blown fuse on the circuit board connected to the power cord (needed to gently lift it from its cradle).
Posted on Aug 25, 2009
SOURCE: olevia 242-t11 will not power up
replaced all caps on power supply FSP 271-4F02 module.Some caps were bulging @ top some were not but replaced them anyway.Total cost( 10 Electrolytic Caps) from Brantley Elec. fay NC was about $33.00.Took about an hour to remove and solder back.
Posted on Aug 07, 2010
No power to samsung dish washer?
Most outlets are attached to a gfi protected outlet, make sure that your gfi protected outlets are working properly by clicking the test and reset buttons. Sometimes a gfi in another room can be on that circuit, so don't forget to check others.
Don't forget the easy way to check the outlet is by plugging in something you know works.
Sep 17, 2017 | Samsung Computers & Internet
WE have a 2.5 year old Jacuzzi J-210 hot tub that plugs into an outside outlet that is a GFI; power has been shutting down; when we tap the plug and reinsert it, the spa power returns. Why is this?
shut power down and replace outlet, GFIC only last so long, and if they have been tripped a lot they wear out, again shut off the power to the outlet before doing any work.
Apr 03, 2017 | Jacuzzi Pool & Spa
BEACHCOMBER HOT TUB NO DISPLAY
This could be failure of the display, the controller, or both.
Dec 12, 2013 | Jacuzzi Pool & Spa
While running in a screw to install a new electrical outlet cover, the outlet made a small pop and the lights flickered but immediately came back on. I plugged in the unit to see if it worked and nothing...
You say the unit is 220 volt, but the plug you installed has a white wire which is normally on a 120 volt outlet. A 220 volt outlet would have 2 black wires and ground. If you do have 220 there, and the reset does no good, I've seen those resets(they are basically built in GFI) blow out and had to bypass/put different chord on. there are fuses on the control board but I would check that last
Jun 24, 2011 | Frigidaire FAS257S2A WallWindow Air...
Hooked everything up per directions. I plugged it in to the closest electrical outlet and nothing happened. The lights did not light up, the connected wall control and sensors leds do not light up. It...
Dear Davehibshman,
Firstly; dismantle the plug and replace the fuse with the same rating as the one you have just taken out. Replace the plug cover, put the plug into the socket and try again. If this doesnt work, there may be a problem with the internal fuse (if one is fitted). Two choices here, either refer this unit to a qualified service personnel/ the place where you got it from, or do the job yourself (which will save you a whole bunch of cash). In your circumstances, I would take it back to the place you got it and ask them to put the fault right, or replace the unit completely; if it is past its warranty or guarantee time, then get back to me with a make and model number of the unit, and I will give you step-by-step instructions on how to solve this.
Yours sincerely
Oz
Feb 27, 2011 | Vacuums
We have a 1997 or 1998 beachcomber hot tub, digital 3000 and the control panel seems to be locked on economy and we just can't get it unlocked. We've tried following the steps the instructions give us but...
I have a 1997 beachcomber tub w/ digital 3000 which was locked in economy and temp said 80*. i check solded joints and they were ok, i replaced the main board and it work fine now.
Jun 01, 2010 | Jacuzzi Pool & Spa
Recently purchaced a house with jacuzzi tub. Filled tub with water and pushed on button. nothing happened. There is power to outlet.
Two things come to mind; First check to see if there is a GFCI on the box or the power cord and be sure it is not tripped. Also be sure that the covers are all as their are quite often magnet switches on the doors that will kill all the power if the doors are open. Good luck.
Apr 01, 2010 | Garden
NOTHING TURNS ON, PLUG IS OK SAID ELECTRICAN
If you have plugged the tub into another outlet and the jets work fine, it is not a control module problem. The tub should be plugged into a gfci outlet. If it is, there may be a reset switch on the plug it is plugged into, or there may be a switch somewhere else in your bathroom that has the reset switch on it. You can buy a tester for about $3 or $4 that plugs into your outlet to test if it has power. Hope this helps.
Nov 19, 2009 | Jacuzzi EH85-959 Real Whirlpool Bath 6...
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
I have a GE small unit that is 5 to 6 years will not start up
About the only thing can suggest is see if a lamp or other will work in the outlet that you have the AC unit plugged into.
May 07, 2009 | GE AJCQ08ACB Air Conditioner
jasbo
jasbo
