Question about Aquabot Turbo In Ground Pool Cleaner
Power supply works but cleaner does not move.
Moters are not working at all.
    Top Expert:
  • Aquabot Master
  • 6,498 Answers
See if voltage to motors if no voltage bad board if voltage to motors bad motors
Posted on Dec 07, 2017
Wher are the power moters lokaded
The "power moters?" Um....
What are you talking about?
Jul 19, 2014 | 2003 Ford Expedition
I have a Prowler 720 pool cleaner. While the light comes on the device does not move, the fan on top is not spinning. I'm assuming that the drive motor is not working. Since the mechanism is basically...
The problem may be simpler than you think, Patrick. The robot's power cord must be plugged into the power supply port in a particular way. The male prongs on the robot's power cord are numbered, 1 through 4. Each of these male prongs must be plugged into the power supply port's corresponding number (e.g., 1 must be plugged into 1, 2 into 2, etc.). Do anything else and you get a motionless robot. I hope this helps.
Oct 20, 2013 | Pentair Prowler 720 Pool Cleaner
I have a dolphin cleaner that is not working. The power supply voltage drops from 37 VDC to about 4 VDC when the cleaner is plugged in. It previously had a severed power cable that was repaired. I saw a...
The new PCB you purchased should take care of it. If you need assistance connecting the new part or the unit continues to give you trouble please contact us directly or add a comment here.
John
Jan 24, 2011 | Smart Pool Inc Dolphin Diagnostic...
Im trying to install power windows in my 2004 ford f150 its a stx modle single cab i went to a junk yard and found the door panels and the switches and i also got all the cables and moters and installed it...
I am looking at a wiring diagram for the power window circuits for that vehicle , it shows no relays involved at all . Here is web site for free wiring diagrams . http://www.bbbind.com/free_tsb.html Enter your vehicle info. Year , make , model an engine size . Under system click on body & accessories , then under subsystem click power windows . Click the search button an three links will pop up , click on them one at a time .
( just run power to the switches and that it might work that way but it didnt so then i ) Where did you get the power supply from ? Hot at all times , key on etc.... An did you supply a ground circuit ?
Apr 18, 2017 | 2004 Ford F150
My dyson turns on only when in the tilted
it sounds like the wires attached 2 the moter are lose need hex drive 2 take a part moters verry fidley stripped quiet a few moters were gone
Oct 20, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
1990 buick century All power windows will not move fuses on fuse block (locaated in back of glove box door )checked ok with ohm meter T.I.A. ****
Well I was wrong, the window on pass side worked from the switch on the pass door !! So now that I know this I took apart the driver side door switch controll panel ( ie. 4 windows switch up/down & 4 door lock / unlock switch) I found 12 volts to the door lock section but NO 12 volts to the window section ( with key on) !! ratheer then trying to trace out this wire (oange) I took 12 volts from the door & jumpered it to the window 12 volt supply { now I know the door wire is thicker ( more amps) then the window supply but I dont't think I'll be useing all 4 window moters at once...} oh well what the hell it's almost 20 years old has three sets of seats & gets close to 28 MPG....
Oct 16, 2009 | Buick Century Cars & Trucks
My dolphin diagnostic cleaner for my below ground pool, just stopped after years. I went to turn it on yesterday and there is power to the power box as the light goes on, but the unit is not moving. I am...
If your unit has a fuse it will be on the back side of the power supply. If the light on the power supply switch is on, it will not be the fuse though.
Try turning the cleaner upside down on the deck and connect it as you otherwise would. Power it up and it should go through a self test process that takes about 40 seconds to complete. If it turns the tracks in both direction with and without the impeller turning, it is fine and will likley start working in the pool again.
If not, contact us through www.arrowpools.net and click on the FAQ and then Dolphin cleaner catagory. You can also use the Dolphin Serice button for information about sending it in for repair.
Jul 03, 2009 | Dolphin Maytronics Advantage
Circuit board inside power supply is bad. I need a replacement
You'll need a replacement board. You'll need model and serial numbers off of the cleaner itslef to help identify which power supply and therefore what PCB is needed to replace yours. Try contacting our service center at www.arrowmotor.net and click the contact button in the upper right corner.
Jun 13, 2009 | Smart Pool Inc Dolphin Diagnostic...
Aquabot Turbo In Ground Pool Cleaner Logo
Top Aquabot Pool & Spa Experts
Robco Water
Robco Water
The Cover Guy
The Cover Guy
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
