Question about Dryers
I have a frigidaire gas dryer model #fgr641fso and it will not spin how do I fix this?
2 Suggested Answers
WonderTech
  • 268 Answers
SOURCE: Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Posted on Aug 12, 2009
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
How to fix dryer that will spin but not dry
STOPS MID CYCLE AS IF AROUND 20-30 MINUTES? IF SO U MAY HAVE BAD MOTOR WINDINGS? OH OH, CAN CHECK HEATING ELEMENT AND THERMOSTAS WITH A MULTIMETER FIRST
May 12, 2014 | Frigidaire AGQ6700F / AGQ6700FE Gas Dryer
My front load washer wont go into final spin and clothes are soaked
What is the model number of the unit?
Try running it in a different cycle to see if it does the final high speed spin.
Post back the results.
Nov 08, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire aeq7000eg0 motor doesn't run
Most of your fuses for a Frigidaire dryer are upper right hand side of the rear bulkhead. Here is a westinghouse dryer video I made In the video I look for failed components and show the various parts, explain their function, and location.
Frigidaire service manual
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
Jul 23, 2012 | Frigidaire Dryers
Dryer spins but no heat how do i fix that
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 30, 2010 | Frigidaire GLEQ332A Electric Dryer
Squeaky 4-yr old Frigidaire gas dryer
it's most likely the rear bearing that the drum rides on in the rear of dryer,you'll need the model number located around the door opening to order the right part.
Apr 25, 2010 | Frigidaire Dryers
Dryer spins but does not heat up on frgidare model GLER331AS21
If you have a gas dryer..
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 13, 2010 | Frigidaire GLER642A Electric Dryer
My frigidaire dryer glgr331as4 is not spinning
Hi there
i read your report. OK try this tip. Open your dryer and spin it with your hand and its spins freely with no resistance then it's your belt is bad. Try this and let me know how it goes. Ty for writing to fix ya.
Best Regards Richard
Dec 03, 2009 | Frigidaire GLGR331A Gas Dryer
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer drum spins but no heat
These units have a limit switch is located near the burner compartment. It is about the size of a dime or penny with 2 wires going to it. In between the wires, there is a small button that you can depress firmly. This should reset the limit. If it trips again, you will need to replace the limit switch. Hope this helps.
Apr 11, 2009 | Frigidaire Dryers
Dryers Logo
51 people viewed this question
Top Dryers Experts
