Question about Garden
Craftsman hp pressure washer Model No. 580.752300
Haven't used it in a couple of years. there is no indication that it is even attemnpting to start.
  • 14 Answers
SOURCE: craftsman 4 hp 2150 psi pressure washer wont start
Go to www.karcher.com ,click on your region and then click international. Enter the model of the machine or the type number . That is is the first 8 digits of the number under the barcode. This will take you to the parts listing for your machine.
Posted on Mar 11, 2009
  • 10865 Answers
SOURCE: honda powered gx160 model pressure washer wont start
Buy a new plug, drain out all of the old gas and put in new gas, and take a look at the air cleaner. If the air cleaner is dirty replace it. There you now have a good spark, good fuel and good air. The engine should start. If it doesn't get some carberator cleaner spray and some starting fluid spray.
Posted on Apr 12, 2009
  • 174 Answers
SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Posted on Aug 26, 2009
  • 691 Answers
SOURCE: Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Posted on Sep 24, 2009
  • 420 Answers
SOURCE: Craftsman Pressure Washer 2.3 GPM 2550PSi
if there is a fuel filter running completely out of fuel sometimes allows all of the bad stuff in the fuel tank to plug the fuel filter (if it has one). press the primer bulb until you can hear fuel, then it should start.
Posted on Jun 02, 2010
HOW DO I DRAIN THE WATER FROM MY HP WASHER FOR WINTER
What I've always done is just disconnect the water hose then start the washer and pull the trigger till no more water comes out. You don't want to run it very long at all after there's no more water though, you can quickly overheat the pump if it is ran without a water supply for too long. I've been doing this for the past 3 years with one of my washers and haven't had any problems with the pump.
Oct 05, 2012 | Powerboss 020309 3000 psi 2.5...
I've got this white powder stuff in my fuel filter
its from using old fuel only use fresh gas 30days or newer
Aug 03, 2012 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Wiring diagram for garage opener
Wiring diagrams haven't been available for openers in years. If you are having a problem why don't you post it along with the make and model number and we will help you fix it.
Dec 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
Oops! I put my son's weed-eater gas in the pressure washer. Now, I can't get it to start. I have emptied out the mixed, put in new... still no luck. is there a way I can prime it?
take out the spark plug and put just a couple drops of gas in the cyllinder head, and maybe one drop of oil, it will smoke a bit, but should **** new fuel in to carb
Aug 22, 2011 | Craftsman 2500 PSI Briggs & Stratton...
New 75219 Power Washer is missing owners manual.
Any luck finding someone to give you a copy of the manual for this model? I bought one on clearance and it doesn't have the manual and I'm scared to even start it up without reading the manual as I don't want to mess anything up upon first start. If I ever do find one, I will post a copy of it for you. Good Luck! Thanks
Jim
May 27, 2010 | Craftsman 2500 PSI Briggs Stratton...
Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | Briggs & Stratton Garden
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
