Question about Dryers
Ge dcvh680. Why can't temperature setting be changed?
How do you work temp control on GE Profile top freezer
The ACTUAL TEMP light will come on and the display will show the actual temperature. To change the temperature, tap either the REFRIGERATOR or FREEZER pad until the desired temperature is displayed. To turn OFF cooling system, access SETTINGS from the HOME screen. Page over and tap COOLING SYSTEM ON.
Sep 22, 2017 | GE Refrigerators
Manual for GE profile pfss5njw/pfsf5njw for setting temp.controls.
Most GE appliance manuals are available through their support site: http://www.geappliances.com/ge/service-and-support/literature.htm. The manuals for the PFSS5NJW and PFSF5NJW are here: http://products.geappliances.com/appliance/gea-literature-search?Ntt=pfss5njw&x=0&y=0 . The direct link to the Use and Care Manual is currently http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60489-2.pdf .
To change the temperature setting for the refrigerator, press and release the appropriate Warmer or Colder touch pad. Press several times to reach the desired temperature setting. (The freezer control is on the left.) Note: As you cycle through the temperature settings, it is possible to set the cooling to OFF. See page 4 of the manual to see these directions.
I hope this helps.
May 23, 2017 | GE Refrigerators
Override thermostat temperature setting on ge rak1481d
To override the temperature limits, simply remove the thermostat cover, and then carefully replace it again, making sure the pins line up correctly. That's it! You can now set the thermostat as low as 60° and turn fan to "On."
Mar 16, 2013 | GE RAK147D1
GE GSS25LGMFWW side by side. Freezer will run till iced up then defrost everything in the freezer compartment. Why is it doing this?
hi, have you try adjusting the temperature:
To change the temperature, press and release the
WARMER or COLDER pad. The SET light will come
on and the display will show the set temperature.
WARMER or COLDER pad until the desired
temperature is displayed. The
freezer temperatures can be adjusted between
–6°F and +6°F.
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I just conveted my ge gas range model #JGBP85CEJ2CC. how do i calibrate the oven
I assume you mean converted.  Changing the gas supply from natural to LP or vice versa should not change the temperature calibration settings. Most manuals have a compensation method for their units within them, should you suspect your temperature dial is out of range.  Get a small oven thermometer, put it in the oven, run at a known setting...say 350 and read what the gauge says after 15 minutes.
Your manual can be found on the GE site under http://www.geappliances.com/service_and_support/literature/
Nov 26, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Dryers Logo
22 people viewed this question
Top Dryers Experts
