Question about Waterway Twm Above Ground Pool Pump and Sand Filter System No 520 1610
Multiport valve backwash
I have a waterway filer system on a above ground pool. The 7 way value was leaking out backwash port. Changed the spider gasket still leaked. Purchased new 7 way value system and begins to leak after 10 minutes. Of run time. Help?
    Top Expert:
  • Waterway Master
  • 4,292 Answers
Put a shut off at backwash outlet
Posted on May 01, 2016
john224
  • 1378 Answers
SOURCE: 1.5 hp waterway champion pool pump issue
Be sure you have connected the motor to the line leads correctly and that the motor is set for the proper line voltage.
A somewhat common problem is that most motors are dual voltage (can be ran on 115 or 230 volt) and come factory set for 230 volts. If you connect it to a 115 volt circuit it will run for a while and then overheat and shut off.
Posted on Jul 28, 2009
Coastsider
  • 331 Answers
SOURCE: can i buy just the impeller for the 1 1/2 hp waterway 2 speed pum
Yes, you can obtain the impeller separately. Feel free to contact us, or look online for your specific impeller part number.
Posted on Apr 14, 2010
  • 11800 Answers
SOURCE: I have a Waterway SVL56
That means that the connection between the motor and the actual centrifugal pump is broken. This is terminal: replacing the broken part will cost you more than the price for a brand new pump. Just cut your losses and replace it.
Posted on Dec 18, 2010
jharwell668
  • 640 Answers
SOURCE: I have a Waterway 48-Frame 2HP 115v pool pump for
Check to see that the pool pumps mounting is secure. Loose mounting could cause the motor to run loudly. It could be bearings rubbing or a bent shaft. If it is new, this should not have happened. If you check the mounting and feel that it is secure, I would return the pump to an authorized Waterway service agent and let them look to see if the bearings or shaft are damaged. I would do this quickly while you can still return the pump if its defective.
Posted on Apr 26, 2011
johnjnail
  • 1702 Answers
SOURCE: We just bought a used 22 inch waterway pump, when
you need to vacuum on waste, when the vacuum sucks down on the pool liner it will cause a high vacuum in the filter that will mix up the sand causing some of it to get washed back into the pool. if you vacuum on waste you will avoide this problem also if you have algie in the pool this will remove the algie from the filter system rather then alowing it to grow in the filter.....good luck
Posted on Jul 07, 2011
How do I get into the filter to check backwash valve?
you shouldnt have to go inside the filter that is done in the multiport
turn system off turn multiport to backwash till water comes out clean shut off then turn lever to rinse for about 30 seconds turn off pump again turn lever to filter you should see more water pressure coming out of pool return
Sep 10, 2013 | Hayward Pro Series 18" Above Ground Pool...
Sand filter leaking
Sand is old or multiport valve has gone bad
May 17, 2013 | Waterway Twm Above Ground Pool Pump and...
Replacing handle on multiport valve head
drive out pin and put new handle on then put pin back in
Jul 07, 2012 | Waterway 1.5hp Hi Flo Above Ground Pool...
I have a brand new filter..im leaking lots of water from my backwash when on my filter setting
Your multiport spider gasket is bad. Just replace it by removing the top assembly. Remove the 6 phillips screws on the valve cover and the whole assembly will come off. This is easiest done when the valve is first put on the "Winter" position
Jul 21, 2011 | Hayward Pro Series 18" Above Ground Pool...
When turning pump on sand shoots into pool app. two seconds.replaced diverter and lateral coponents. still does the same thing. twm 19 inch p/n 520-1910
If you don't have a manual you can download one here:
http://www.waterwayplastics.com/manuals/810-0092H.0209.pdf
Are you sure you didn't damage laterals when adding sand. Best to have 1/4 water in filter as you add sand. Be sure o ring is in place in multiport valve that fits on downtube.Be sure down pipe is not too low to enter multiport valve. The pipe should fit snugly into the multiport valve o ring. Be sure you have correct sand (pool filter sand only) IF all this is ok, try backwashing till glass is clear. Run on rinse position for a few min. THen go back to filter and see if it still pumps in sand.
Aug 16, 2010 | Waterway Twm Above Ground Pool Pump and...
Sand and murky water being discharged into pool after backwash
You posted this question in Alarm category. but sounds like either your filter laterals, or the backwash valve are bad. I'd need to know what type of filter, and backwash valve you have. is the backwash valve a multiport, or push/pull slide valve, etc... If it's a push/pull valve then the o-rings, or pucks can be bad, or the piston can be broken. if it's a multiport valve, then the spider gasket may need to be replaced. if it's a top mount multiport valve, then it can be broken inside the filter.
Aug 16, 2010 | Pentair Pool & Spa
Wicor high rate sand filter P20. When I have it on "filter" there seems to be some water starting to leak from "backwash" hose.I only let it run maybe 30 seconds. Not looking for it to blow out any seals...
If it has a multiport valve, most likely the spider gasket inside has damage or has come out of place. A broken stem spring can also cause water to bypass out the backwash due to not having enough force to seat the seal. Take the multiport apart and check the spider gasket and spring.
Aug 15, 2010 | Hayward SAND FILTER, PRO SERIES
After vacuuming and backwashing, the dirt recycles back into the pool PSI is only 8 - what is wrong?
Assure that the o ring is positioned onto the multi-port throat correctly. That could cause dirt to recycle into the pool water.It could also be issues with the multiport valve in the pool filters.
Jul 28, 2010 | Waterway Clear Water 22" Sand Filter...
My filter and pump will not retain the prime after turning off. Its a pantera sand filter. I can hear an air hissing sound coming from the multi valve port
Either you have a bad spider gasket inside the multiport valve or a bad threaded fitting going into it. Check for leaks around the multiport and backwash line. You'll have to take apart the multiport valve to make sure the spider gasket is not damaged or out of place. Make sure to install the multiport valve in the same position. You can get a replacement gasket at most pool supply stores or online.
Oct 29, 2009 | Hayward Pool Products HAYWARD HEAT PUMP...
Waterway Twm Above Ground Pool Pump and Sand Filter System No 520  1610 Logo
26 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
