Question about Nikon D50 Digital Camera with 18-55mm Lens
Shutter I have had a Nikon D50 for a year and half it recently when trying to take a photo came up with ERR and I had to press the button to get it to release the shutter, Is this just a case of a sticky shutter or a complete shutter failure??
I had the same problem but replaced the lens with a different lens and it worked just fine.
Posted on Dec 31, 2007
Err on top of display on camera
Unfortunately, this probably won't be a good situation. Most of the time the ERR(or) message you're getting shows when there's an internal problem, and most likely a shutter error. Not an uncommon problem with the older consumer models like D40, D50, etc.
Dec 27, 2013 | Nikon D50 Digital Camera
I get "Err" on the
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at and discuss the problem them before contacting an authorized service center.
Jan 25, 2011 | Nikon D50 Digital Camera
I have a Nikon D50 with a Err message and I can't take pictures anymore. What would be the cause for this? Eric
"err" is a cmara malfunction. If the camera has a hardware reset button, give that a try. If that does not work, then examination by an authorized Nikon Service Center is advised.
Nov 01, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Hi i have dropped my d50 and err comes up
There is a motor/gear assembly inside the camera that moves the lens in and out and covers the lens when it is retracted. When it dropped, you most likely cracked or shifted something out of place. A broken tooth does not stop function, but shudders when it hits the gap. A shifted gear, slips and similarly may cause this effect. If it doesn't open the shudder, you get no picture.
You will need to open it up and attempt to repair the mechanics that drive the lens.
May 05, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Flashes Err and clicks
This screen shows areas of the photo that are overexposed slightly.
It flashes them to help you.
You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady.
If you get any other screen in future you may have accidently pressed the arrow again.
Just cycle thru the displays to get back to steady.
thank u
rate me!!
Jul 27, 2009 | Nikon D50 Digital Camera
My Nikon D50 is suddenly underexposing the lower half of each photo. Does anyone know what is wrong?
Are these flash photos? If so, make sure you don't have the lens hood on. Also make sure the shutter speed is slower than the sync speed.
Otherwise, is this happening at a variety of shutter speeds? With fresh batteries?
Mar 04, 2009 | Nikon D50 Digital Camera
Shutter is not workin properly
Just clean propely with genuine cotton cloth ,it may work fine .
Nov 08, 2008 | Nikon D50 Digital Camera
If this only happens when using the flash - then it is a problem of flash synchronisation.
If it happens all the time - then one of the shutter curtains may be sticking.
Either way, you should get the camera looked at by a repairer.
May 07, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50
Replace the button battery 1.5 voltsX2 your auto function will work properly.
Dec 29, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Digital Camera with 18-55mm Lens Logo
188 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
