Question about Oster 76076-010 Hair Trimmer
Brand new oster 76 overheating first time using, what might the cause of this?
  • 193 Answers
Might be a 110 Volt clipper? If they are old blades it could be a build up of rust!
Posted on Feb 12, 2014
SOURCE: oster 76
There can also be a problem with the switch, which can be gotten to by unscrewing the the 2 screws at the end of the clipper . . .you must then test (with the thing unplugged!!!!!!!!!) to see if the switch wires are good or if the switch is broken by flipping the switch and or the toggle and then checking the wires with an ohm meter (easily available from radio shack or ?? for under 10 bucks or any kid who's into electronics. If the switch is good, when its turned on resistance goes to 0, if bad th switch shoes infinite resistance on or off . . .
If it hums and the motor is turning, but the blades don't move you need to replace the gear and or lever . . see this diagram
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
Posted on Mar 11, 2008
  • 22 Answers
SOURCE: replacing a cord on an oster 76
Very simple task. The part is under $3. The schematic and parts list is located in the link.
http://www.clipperrepair.com/parts.htm?mid=106
Posted on Feb 02, 2009
SOURCE: Oster 76 overheating
The most likely cause of the condition you describe is that the motor is trying to run with too little current reaching it. ( Note: Voltage is the pressure pushing the electricity down the wires. Current is the amount of electricity being pushed. An easy analogy would be gallons-per-minute of flow through a garden hose. That flow is the current that is being delivered. )
If there is a built-up coating of black residue/gunk on the commutator ( the part the brushes ride against inside ), you're probably not getting the full amount of current flow needed to run the motor. Any motor will run slow, overheat, and eventually burn out if operated on current flow that is less than that required by the unit. Too small a cord, too long an extension, dirty contacts, any of these things can restrict current flow.
Pull the brushes out and look down inside. If the armature is covered in black residue, the only fix is to clean, polish, and undercut the armature, or simply replace it.
These are well-built machines, and designed to be servicable. That said, I must caution you not to attempt this repair/replacement if you have no experience in this area. It's all too easy to end up with a unit that doesn't work at all. Even worse, a unit that goes POOF and generates a cloud of acrid smoke !
Time to turn to your local repairman. It isn't a difficult or especially time-consuming job, and should be quite affordable.
Posted on Mar 15, 2009
SOURCE: put new switch oster 76 forgot how to wire it back
middle wire goes to incoming power an the other two wires get connected to the terminale that sets against motor,was wondering where you bought the switch
Posted on Aug 18, 2009
  • 8 Answers
SOURCE: my oster 76 number 2 blade pulls. i have lubed,
The teeth of the blade are not set correctly; look at the top blade and you will see where the bottom blade's teeth are supposed to match up. You can adjust the blade by unscrewing the two screws on the front of the blade and moving that bottom blade back into position.
Posted on Mar 05, 2010
Want to use plastic attachment. What blade do I need to use with theses?
Oster 76 clippers can be used with a variety of blade sizes and combs. shaveroutlet.com has many in stock. When using comb attachments, you should use one of the following size blades; 000, 0000, 1, 10, 15, 30
ShaverOutlet com Search results for oster 76
Feb 25, 2016 | Oster Classic 76 Clipper w/ Detachable...
What blade do I use with attachments?
In general, Oster 76 clipper combs are compatible with blade sizes 10, 15, 30, 00000, 0000, 000, 1. Many are available at shaveroutlet.com
How to fix the switch on my oster 76 classic clippers
Check out My Video on how to replace Oster 76 Switch at Mannys-Sharpening.com Service You can Trust Since 1990
Jan 06, 2011 | Oster 76076-010 Hair Trimmer
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
Simple question: Are the Oster 76 2-speed, the Oster Crewmaster 2-speed, and the Oster A5 2-speed all the same clipper with different detachable blades?
well the 76 and the golden a5 are almost the same the name plates are different and the 76 uses a toggle switch but the a5 uses a rocker switch. not sure about the crewmaster sorry.
Oct 03, 2009 | Oster Golden A5 2-Speed Universal Motor...
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
Oster clipper blades get red hot and won't cut.
see this link, its for the A5. The A5 is the animal version of the 76.
I dont know what model you have, but if you need schematics for YOUR model see this link.
http://www.clipperrepair.com/parts.htm?brand=8
Jan 10, 2009 | Oster 76076-010 Hair Trimmer
Replacing a cord on an oster 76
Oct 28, 2008 | Oster 76076-010 Hair Trimmer
Temp too high
lamgrimes9,
Welcome to Fizya.,
You said, your Oster wine refrig won't lower its temperature below 76 degrees. I have it for about 5 months, and it worked fine all this time with a setting of 50 degrees. Now it refuses to lower its temp. It reverts back to 76 everytime. Can someone give me any ideas about what is wrong? FYI Mine did not come with an owner's manual.
Sounds like the Thermostat is bad.
http://www.oster.com/CustService.aspx?content=manual
The tel # in your Oster Manual is a recording and will not help you!
But New appliances are under Factory warranty and are fixed or replaced no cost to the customer!you are under
http://www.oster.com/CustService.aspx?content=center
Let me know how it goes.
Huuum
Please leave a rating.
Oct 05, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster clipper parts
www.clipperparts.com
This is a factory authorized repair shop in the USA. They will sell you repair parts. I wish I had seen your post earlier. Don't throw away or sell your old clippers. I repair Oster 76 and T-Trimmers for a living.
Aug 28, 2008 | Oster 76076-010 Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
195 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
