Question about Tools & Hardware - Others
How do i reload an Arrow Electro-Matic staple gun model FT-50
2 Suggested Answers
SOURCE: refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Posted on Dec 05, 2008
Craftsman 68514
The replacement pack for this gun say the staples are compatible with "Craftsman 68514 and 68517; Arrow Brand T50 Staplers T50 and T55; and Stanley/Bostitch TR110 and BT110 staple guns", so I assume they are also backwards compatible. That's just an assumption though.
Mar 22, 2013 | Arrow Tools & Hardware - Others
Loading staples into a Stanley sharpshooter staplegun
There are 4 staplers in the Stanley SharpShooter family. You drop the staples on top of the "slide out loader," then slide it into the gun. See models and staple sizes below:
TR150HL Stanley Sharpshooter
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples
TR150 SharpShooter
PHT150C SharpShooter Heavy Duty Hammer Tracker
  • TRA700 series or Arrow T-50 heavy duty staples (1/4"-3/8")
TR250 SharpShooter Plus Heavy Duty Staple/Brad Nail Gun
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples and 1/2", 9/16" and 5/8" Brads
More information on the Stanley SharpShooter and a quick loading demo can be found here: http://www.expotv.com/videos/reviews/12/134/StanleyTR150HLSharpShooterHeavyDuty/185661
Sep 11, 2012 | Stanley Proto Stanley TR150HL SharpShooter...
My t 50 does not shoot staples although chamber is loaded
Hi, Dayne here
Well, it might sound too easy, but did you check for jambed staples. I also lightly oil all mine. Sometimes the actual plunger that drives the staple will break internally.
Thanks
Dec 12, 2010 | Arrow T50P ARROW STAPLE GUN
How do I open a model T-50 staple gun?
On the rear of the stapler (if you look at the picture on this web page, the lower right) there is a metal piece that you push in, then down slightly, to unlock. When you release it, a spring loaded bar and follower will come out. You will see where the staples slide in. Put the follower back in the grooves and reinstall.
Aug 10, 2010 | Heavy Duty Arrow T50 Staple Gun
I have an Arrow T-50 which is missing the staple pusher needed to reload. Can it be reloaded without the staple? If not, where can I get that part? Thanks!
You need the staple loader to keep the tension on the staples. The part is usually not sold separately. Your only chance is to find a used T-50 and cannibalize the part. You can get a new T-50 online for $25.
Dec 09, 2009 | Arrow T50P ARROW STAPLE GUN
How to repair jammed arrow electo matic staple gun
You'll have to disassemble it. There is probably a staple lodged in the "hammer" mechanism on the business end of the stapler.
Often, these staple are very difficult to remove -- a very small flat-tip screwdriver and needle-nose pliers usually work best.
After you get all the jammed staples out, lubricate all moving parts with something akin to 3-IN-1 machine oil. This should prevent future jams.
Charlie
Aug 20, 2009 | Heavy Duty 648967 Arrow Electric Staple...
I have a staple stuck in my Arrow model #ETN-50 staple gun. How do I get it out? There is not enough staple exposed to pull it out and I don't see any way to take the nose apart. Thanks.
Unplug it. If you can see the driver jammed against the staple, take a screwdriver end and try to push the driver back in and the staple should be released. If you can't get the driver to go in and release the staple, you'll have to disassemble it to clear the jam, If you need help with that, see the instructions for the current model here, page three, diagram 3, cleaning the magazine.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 18, 2009 | Heavy Duty 648967 Arrow Electric Staple...
Is the Ace Hardware #22084 Staple Gun the same as Arrow T-50 ?
Found a friend who had an Arrow T-50 stapler and compared staple sizes - not the same.
Feb 17, 2009 | Arrow T50P ARROW STAPLE GUN
Piece of staple stuck in the trigger section of arrow t-50p
First, remove the magazine pusher / spring and any staples loaded in the magazine.  Then try firing the gun to clear the staple.  Use a small jeweler's screwdriver and small needle nose pliers to get the staple out.  Reload and test.       These are relatively inexpensive staple guns.  If the problem persists it might be less trouble to replace the gun.     Best of luck and I hope this solution works for you.   Michael Mittelsdorf
Jan 11, 2009 | Arrow T50P ARROW STAPLE GUN
Hi can't seem to reload stapler
All you do is open the end peice and slide the staples in on the two rails, point down. You should be able to see in the end to make sure nothing is blocking the rail with a flashlight. You probably have the wrong size staples. You can only use # 214, 215, 276.
Nov 26, 2008 | Arrow T50P ARROW STAPLE GUN
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
