Question about Cutler Hammer Eaton Dpf222rp 60a 240v Fusible Outdoor Pullout Disconnect Air Ac
Size fuses used - Cutler Hammer Eaton Dpf222rp 60a 240v Fusible Outdoor Pullout Disconnect Air Ac
What is the difference between a ATC fuse and a ATM fuse ?
ATC Fuse
  • ATC fuses were created before ATM fuses. An ATC fuse will be larger than an ATM fuse in physical size. This is considered to be the regular size. An ATC fuse will be found in late-model electronic devices.
ATM Fuse
  • An ATM fuse is considered to be a mini fuse and it came out in the early 1990s. The only difference is it is smaller than an ATC fuse in actual size. It generally cannot be used in a fuse block that is made for an ATC fuse, as it will not fit in properly.
Apr 24, 2015 | 2002 Mazda Protege
Why does my radio fuse keep popping in my 1992 bmw 735i?
Do you have the correct size fuse as listed in the manual or on the fuse cover? If so do you have an after market alarm system? Many times the after market installers will use a wire that they know is hot. often an always on radio memory wire? If you bought the car new and did not install an alarm or change out the radio out then you may need to bring it into a shop that traces wires. if you bought it used and you have the correct size fuse there is no telling. Caution do not in cress the size of the fuse beyond the recommended size or you could have a fire.
Sep 14, 2014 | Max American Terminal 30 i Fuses
I'm hooking up my connex4600 turbo to batteries
The fuse size will protect the wiring depending on its size but the question is what amperage does the system draw/use and therefore what size wire is needed and the fuse will be the size of the system amperage draw and the wire size also determined by the amperage draw because if the amperage draw exceeds the capacity of the wire the wire will melt so the fuse should project the wire by cutting the current flow when it exceeds the wire siaze but the system needs the cureetn flow, amperage it is designed to use.
Sep 08, 2014 | Car Audio & Video
Oster microwave model ogf41101 all works but dont
you can use a 250vac 20 A ceramic fuse but the right size is engraved in one end of the fuse any radio shack or electronic store will have it make sure it is disconnected.
Aug 29, 2014 | Microwave Ovens
Im looking for replacment fueses for my jbl tr225 and was wondering if something that can handle more power would be safe
I would only increase the fuse size by 5 amps if I could not find the right size.... If you have a direct short it will blow the fuse if it is a little over sized. If you use the range alot for a long period of time and if the wire size is matched real close to the fuse size then you could run the risk of getting the wire to hot and cause a fire hazard if you use a larger fuse then is needed..... Hope this helps.
Feb 05, 2011 | Kitchen Ranges
My interior dome lights do not work and neither do my power locks, i am sure this is the same fuse, i open the fuse box in the engine and there is a fuse missing and it is labeled done, i read my owners...
Are you putting in the right size fuse? Your owners manual should direct you to what size fuse to place in there, and be sure to use this size. don't use a higher size, as it could cause a short and/or fire.
If you are using the right size fuse.. then you have a short in that system... somewhere.
Jan 07, 2011 | Lexus ES 300 Cars & Trucks
Size fuse for blower motor
Fuse sizes in car commonly using color coding. There red, white, blue etc. The color fuse is indicate current rate. So if your blown fuse has color is red ( for example), just change it 'new' red fuse. Fuse size of blower motor normally will not exceed 20 Amps.
Nov 28, 2010 | 1992 Ford Explorer
Fuse Size??????
The fuse size shouldn't matter with the low voltage problem you are describing..Fuse size should be 10A fast blow(AGC). Verify that you have a good 12v power source feeding your unit...your dimming problem is voltage related.
Mar 29, 2009 | SPL Dynamics SDVD7400R Car DVD Player
Size of fuse for Ultimate PA2204
O SO U JUS NEED LIKE A FUSE THAT IS ABOUT 20-40 AMPS
Mar 20, 2009 | Car Audio & Video
Need fuse size for cobra cpi-850
80a fuse should work fine thats the size i have it installed with i used 4 ga. wire
Jan 08, 2009 | Cobra CPI-850 Car Audio Amplifier
Cutler Hammer Eaton Dpf222rp 60a 240v Fusible Outdoor Pullout Disconnect Air Ac Logo
32 people viewed this question
Top Cutler Hammer Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Cutler Hammer Air Tool and Compressor Expert? Answer questions, earn points and help others
