Question about LG KG800 Cellular Phone
Downloading music I really luv my phone but the problem is i don't know how to get my music from windows media player transfer it on my phone :-(. please please please please help me out .xxxx. fom xrachelx
Re: downloading music
I had the same problem, & also the phone didn't show in My Computer as a removable disc. LG told me there was a software problem on the phone & I had to get a replacement. The replacement, however, did exactly the same. Try downloading via a Bluetooth adapter (they only cost a few quid on ebay) - this works fine for me.
Posted on Aug 31, 2007
  • 30 Answers
You dont need to use media player. when u connect ure phone to the pc a new drive should come up on my computer then just go in it and drag and drop ure music in the mp3 folder :)
Posted on Aug 28, 2007
0 characters
3 Points
Can't tranfer songs using my windows media player
Windows Media Player is not compatible with iPhone, you have to use iTunes to manage iPhone songs. If you want to know how to transfer songs from WMP to iTunes, this guide will help you.
Hope it helps. Contact me if you have any other question.
Dec 24, 2013 | Cell Phones
I need driver called mtp usb device for my c2-03 mobile
Many devices use Microsoft's Media Transfer Protocol to synchronize with computers. Unlike standard USB mass storage devices, MTP devices don't behave like USB flash drives. Windows Media Player includes built-in support for MTP devices and can synchronize media files to and from them. You can download MP3s to your portable music player, cellphone or other MTP device using Windows Media Player's sync feature. The device appears in Windows Media Player when you connect it to your computer.
Read more: How to Download a MP3 to MTP '
May 29, 2012 | Nokia C203
I tried downloading mp3 music on my nokia 5230 it doesnt work
you might want to check your java scripts, also try master reset see link below -->
May 03, 2011 | Nokia 5230 Cell Phone
How do i install itunes onto my samsung omnia 2
You cannot directly install iTunes on a Windows based phone - you do have various options, however. You can install iTunes on your PC and download music to your PC and then transfer the tunes to the phone using either file transfer, Windows Media Player or Windows Media Centre, or you could copy the music onto a microSD card and insert that directly into your phone.
Note that if you transfer music from iTunes, you may need to "translate" the file format into WMV or MP3 format befoer transferring it to your phone.
Apr 07, 2010 | Samsung Omnia II I8000 Smartphone
When i put wripped music onto the phone a small
It could be that the music you transferred has a DRM (Digital Rights Management) protection.
if that's the case, open Windows media player on ur Pc then open the music files yoou transferred. If it's on the media player window, right click on the music then choose properties - go to the 3rd tab(Media User rights)
then disable the protection.
Hope that'll help you..
Happy Holidays...
Dec 16, 2009 | Motorola Mobility ROKR E8 Cellular Phone
I have albums in my pc and want to transfer the albums to my nokia 97?
Not sure if you meant photo album or music album??? Here is the steps for both, music first:
Transfer music from a
You can use the following methods to transfer
● To install Nokia Music to manage and organise
your music files, download the PC software from, and follow
the instructions.
● To view your device on a computer as a mass
memory device where you can transfer any data
files, make the connection with a compatible USB
data cable or Bluetooth connectivity. If you are
using a USB data cable, select Mass storage as
the connection mode.
● To synchronise music with Windows Media
Player, connect a compatible USB data cable, and
select Media transfer as the connection mode.
To change the default USB connection mode, select
Menu > Settings and Connectivity > USB > USB
connection mode.
This works for music, photos, or video:
Select Menu > Settings and Connectivity >
To have the device
ask the purpose of
the connection
each time a
compatible data
cable is connected,
select Ask on connection > Yes.
If the Ask on connection option is turned off or you
want to change the mode during an active
connection, select USB connection mode and from
the following:
● PC Suite — Use Nokia PC applications such as
Nokia Ovi Suite, and Nokia Software Updater.
● Mass storage — Transfer data between your
device and a compatible PC.
● Image transfer — Print images with a
compatible printer.
● Media transfer — Synchronise music with Nokia
Music or Windows Media Player.
Here is the link for your manual online:
Oct 22, 2009 | Nokia N97 Cell Phone
I have a pc with music loaded onto windows media
go to your window media player on the home ribbon it will say now playing, play list, etc plug your i phone up to your computer. go to the settings on your phone then it will say connection turn it music sync, then open your media player up again then press the sync button. i am not familiar with apple computers so if you have an apple computer sorry i can not help you . hope this was some help to you.
Jun 14, 2009 | Apple iPhone 3G Black Smartphone
What music source do you use to upload music on Motorola VE 240 ?
Windows media player should work as long as your computer can reconize the device(Phone) just use the sync function on the wmp and locate your phone on the list of devices. Also make sure you have a media card in your phone.
Dec 27, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Downloading music from pc to phone
Have you installed and tested the drivers? Are you able to copy pictures across? If you're using the bundled software to copy files across, try opening the phone's folder using Windows Explorer and copying them straight over. This uses the obex drivers - USB mass storage and file transfer.
Otherwise, there may be a problem with the file you downloaded. Check it's size - if it's of an unusually small size (under 300 KB, unless it's a REALLY short song!) it may be corrupt. Try ripping a song from a CD with Windows Media Player, then copying that across. Be sure to change the rip settings to MP3.
Hope this is of some help...
Mar 10, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Lg k800
U have to follow this process.
Install Any USB drivers which are needed for your cable. Then connect your phone to the PC. Open Windows Media Player and click on the sync tab in Windows Media Player. Now on your phone hit MENU->Get It Now->Option 1 Music and Tones->6 Sync Music and the phone should show up under the devices in Windows Media Player. Now add the songs you want transfered to the sync side of Windows Media Player. Click Sync in Windows Media Player. and finally enjoy your music.
Oct 16, 2007 | LG KG800 Cellular Phone
LG KG800 Cellular Phone Logo
37 people viewed this question
Top LG Cell Phones Experts
Scott Fryer
Steve Sweetleaf
Steve Sweetleaf
Jeremy Murray
Jeremy Murray
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
