Mitsubishi electric air conditioner MSE24JN-S1
The AC cooling is not working well
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
SOURCE: not working probly two flashs then pause
The two flashes are telling you what's wrong with the unit. Take the cover off of the unit inside(evaporator) and there should be a guide on the panel with the wiring diagram. On this diagram there should also be a solution to what each blink means. One blink means this, two blinks mean that, etc... Hope this is helpful.
Posted on Mar 14, 2009
TheMobilian
  • 8220 Answers
SOURCE: AC is set on cool & furnace comes on blowing hat air
My first thought is a bad thermostat or control board or maybe something is wired wrong. If all that seems to be working I would look at the outside unit. if that condenser fan motor is not operating then you wont get any cooling. look for a swollen capacitor. Read more
Posted on Jun 06, 2009
  • 70 Answers
SOURCE: how do you change the air filter on a mitsubishi
the front of the unit will lift up and they shoul pull right out.
Posted on Jul 18, 2010
heatman101
  • 43501 Answers
SOURCE: MMy Mitsubishi Mr. Slim Air conditioner is
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Posted on Aug 20, 2010
Preset heat stuck at 63. I want to lower the temperature for a vacation
[PDF]PAR-30MAA - Mitsubishi Electric Australia
https://www.mitsubishielectric.com.au/.../IB_PAR-30...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote Controller ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F). Auto. 19 ~ 28 ?C (67 ~ 83 ?F). Fan/Ventilation. Not settable. 13 ...
[PDF]PAR-31MAA - Mitsubishi Electric Australia
www.mitsubishielectric.com.au/.../par-31maa_ib_en.p...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F) .... Preset cooling temperature is higher than preset heating temperature.
My air recycle button just blinks. Also when i turn on the - Fixya
www.fixya.com/support/t26081705-air_recycle_button_just_blinks_also
6 hours ago - Not sure the heat pump is producing enough heat. Nov 04 ... Preset heat stuck at 63. ... Feb 05, 2016 ' Mitsubishi Electric Mr Slim E12C26426.
[PDF]MA Remote Controller Mitsubishi Electric PAR-21MAA ...
planetaklimata.com.ua/.../Mitsubishi_Electric/Mitsubishi_Electric_PAR-2...
Easy Maintenance Function (Only for Mr. SLIM PUHZ series) . .... 4.4.3 Automatic Cooling/Heating Display Setting . ... Monitoring the Operation Data by the remote Controller (for Mr. SLIM) .......... ..............48 . How to .... 63. 4.2 How to set rotation function(back-up function, 2nd stage cut-in function) . ... Preset temperature (. °C. ).
Feb 05, 2016 | Mitsubishi Electric Mr Slim E12C26426...
Air conditioning system freon
You'll need to have a mechanic check the system to see if it is low on freon, or if you have an electrical problem.
Jun 09, 2013 | 2008 Mitsubishi Galant
Mi heater no calienta pero enfria mitsubishi montero 2001
Air Temperature Control Blend Door Failure No Heat or no AC (dependes on where door sticks)
In all modern cars there is a tiny DC electric motor driven gear drive that moves a plastic door that blends heated and cooled air from the AC and the heater core, this is called (interestedly enough) the air temperature control blend door actuator. The motor that moves this door fails because the door starts sticking from warping, most common complaint is no heat but it can be no AC as well. To replace these parts (blend door and blend door actuator) you must remove the entire dash from the car. Always have this problem confirmed by a dealer or qualified repair shop as it is a very expensive repair.
Other causes of no heat in the cabin are engine thermostats that are stuck open (engine runs cold) or air bubbles in the cooling system.
Nov 08, 2012 | Mitsubishi Cars & Trucks
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
Wiring diagam for spit system mitishabishi airconditioner
S1 and S2 is the 220vac S3 is the commuicating connection to the outside airhandler. The solution is on the control board that handle the remote funtions
Jan 21, 2012 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Mitsubishi ductless mini-split AC unit (model MSY-A17NA) and a Mitsubishi Electric remote (type KM07L 0029445). Could you please tell me what some of the mode symbols mean - in particular, the...
google ( mitsubishi air conditioner ) you should be able to get all the help you need .. dont forget you need your modal and serial number when you call it will give them the help they need to give you the right answers you are looking for .. once you google mitsubishi , there should be some numbers under what you are lookin for . may even be a picture of your unit .. just tryin to lead you in the right direction ..
Aug 17, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Wiring
Yes, S3 is the comm wire and it needs to be connected.
S1 Is Active
S2 Is Nuetral
S3 Is your talking wire if that makes any sense
Dec 31, 2008 | Mitsubishi MSZ09UN Air Conditioner
Air conditioner
1.check thermostate switch
Aug 29, 2007 | Mitsubishi MSH09TW Air Conditioner
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
