Question about Pool & Spa
Balboa 25501 Heater Test Good But relay wont kick on Hot Tub Wont heat
IFIXALL
  • 868 Answers
SOURCE: teledyne laars pool heater wont kick on
The safety valve isn't opening .It's very possible that a spider is trapping the opening of the orifice.
Posted on May 26, 2008
SOURCE: new (used) hot tub filled with water now it wont stop running
I replaced the upper control panel, and that was the problem.
Posted on Sep 14, 2009
  • 37 Answers
SOURCE: How to Get Hot tub off sleep mode
press temp button and then the light button in sequence.
Posted on Dec 10, 2009
  • 366 Answers
SOURCE: I have a 2004 great lakes hot tub with a balboa
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Posted on Feb 09, 2010
Coastsider
  • 331 Answers
SOURCE: looking for Balboa 2000 LE
Try this link for the M7 Series controls, which covers the 2000 LE series.www.sunraynorge.no/pdf/balboa%2050hz_eng_m7.pdf
Posted on Aug 30, 2010
My Balboa 300F hot tub will not heat up. I am not able to get it out of economy mode. What can I do?
First, balboa does not manufacture hot tubs! They make control systems for hot tubs. If you are no longer able to switch between modes, then your topside control panel buttons are dead or falling. But... Even if you are still in economy mode, spa should still heat up. Once a demand for heat is recognized, you have a "Heat Call" and heater should come on. Is the "heat on" light, illuminated? If so, water should be heating, if not heater element may be bad? A multi meter would be good here: is there proper voltage at terminals on circuit board to heater? If so, bad element! If no voltage, then heater is not necessarily bad, probably just fine, I would then look at sensors? Good luck
Feb 23, 2015 | Pool & Spa
I have an older Jaccuzzi hot tub w a balboa h136 board and single button topside control. The hot tub will not heat. The LED lights up on low speed and goes off on high speed. I just replaced the heater a...
You have voltage across the element but no heat....
Disconnect one element connection and do a resistance/continuity test. Or use a clamp to measure running current.
Feb 13, 2015 | Jacuzzi Home
Hot tub heating
If your hub is in warranty so you can replace it it can be hardware problem.
Sep 28, 2013 | Balboa Water Group Temp Sensor: External...
Hot tub just get hoter wont shut off when it reaches its temp on thermo
It sounds like your heater relay is stuck. You can test this by unplugging the pump that is supplying the water to the heater. If your heater is still getting voltage then replace the heater relay on the circuit board. If you don't have a volt meter, with in a few seconds of unplugging the pump you will start to hear the water boil inside of the heater housing. DO NOT let the water boil for very long. This late in the year you shouldn't be experiencing any connectic heating issues.
Sep 13, 2013 | Dynasty Leisure Bay Dynasty Spas
I have a HS200VS heater in my hot tub. We bought it used. It always had an error code and would stop working in Standard mode, but worked fine in econo mode. Now we have no heat, but still have power. Need...
Not enough to go on...
what error code did you get?
How do you know you have power? Is it proper amount of power?
Did you use a multimeter to test this?
Just lights on the control box, is insufficient way to tell for proper power.
Jul 30, 2013 | Balboa Instruments Garden
Balboa vs500
Your economy spa is equipped with a hot stick. This "hot stick" is nothing more than a PVC manifold that forces the water through multiple 1/2" ports that creates enough friction for the water to heat itself. YOUR HOT TUB HAS NO HEATER. The benefit is that there is no heating element to corrode and replace. The down side is that it takes quite awhile to heat the water. If you start with water that is 55-60 degrees it will easily take 48 hours to hit 100 degrees. Keep in mind that is dependent on the outside air temperature. Good luck with that!
May 02, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hot tub wont come on
What do you mean "Jump it"?
Check with a meter, ACROSS both hot wires to get a reading of 220-240 volts. do not test across 1 hot and the meter lead on ground! You probably are not getting proper voltage to the hot tub. Or you may have a burned system fuse normally 20-25-or 30 amp fuse, which is found within the control box of the spa.
Jan 06, 2013 | Balboa Instruments Duplex Digital Panel 2...
Balboa 52502 val 5m7
have you cleaned your filter recently. Sound like there may be a low flow error in low speed
either that or the start capacitor on your pump is bad and the pump will not come on in low speed unless you first give it a boost in high speed
anytime you ask for heat with insufficient flow there will be an error message
Jun 21, 2012 | Balboa Instruments Pool & Spa
Pool & Spa Logo
21 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
