Question about Music
Soundtech 306D can u send me a user manual for my 300watt soundtech 306D pa.amp mixer
2 Suggested Answers
fred_license
  • 350 Answers
SOURCE: Where's to find the user manual for Power Mixer SoundTech model MM10SD
This manual is not available online for Free, and the website has no info
Although I know most of the specs for this p.a.
So I could probably answer any questions?
It's a basic system with High and low impedance inputs, an eq section, some effects, multiple aux inputs and outputs,
etc... and I have had to service this amplifier and many similar types...
Hope this info helps?
Posted on Mar 21, 2015
I have a Kustom KPM8420 PA mixer and the monitor channel comes through both the monitor and main speakers and vice versa. The two channels are not separate.How do I fix that?
On the back panel there is a section labelled Patch Bay
There are 2 small switches which assign each Power Amp to either Monitor or Main Output.
It would seem you have them both set the same at present. Set one to Monitor and one to Main, and use the corresponding Power Amp outputs direct to speakers.
Note you can send signal to external amps or powered speakers from the preamp outputs. This is really handy.
Download and print the manual from https://www.manualslib.com/manual/90516/Kustom-Kpm-8420t.html
and keep it with the mixer.
( Of course don't send speaker outputs to other amps or powered speakers )
Sep 11, 2017 | Kustom Music
How do I plug mixer into pa speakers, monitors, instruments
Without knowing what make and model of the gear you're looking to connect, I can't give you a definitive answer. However, in general, if you have a powered PA mixer, meaning it has both a mixer section and a power amp section in a single box, the main speaker outputs will be on the rear panel of the box and marked as such. There will also be a jack for monitors, but some mixers have an amp for monitors, some just have an output for the monitor mix, but not an amp for them, and on some you can switch the main outputs to feed either a Left and a Right speaker, or a front mono speaker and a montior speaker. Instruments will go into the individual channel inputs.
Feb 08, 2015 | Music
I am in a ukulele ensemble of 8. We all have electric pick ups in our ukes. what is the best way to connect to one amplifier, eg; using a mixer ?
It can plug into a guitar amp or PA system both. If you use an amp, you could hear yourself alone through that, then output jack "power amp out" to PA or put a mic in front of it from the PA. If you don't use an amp, it can plug into the PA but, you would only hear the 8 pieces together and have no way to hear yourself seperately.
Mar 29, 2014 | Music
How to use an amp with the powerpod 820 mixer
you always keep your sound in line. what i mean by this is if your powerpod is a PA then you would want to run your instrument-pedals-amp-PA. Not saying this is the only way but it is the standard way to configure your components.
Jan 11, 2013 | Music
The power supply blew and I need the schematic for the power supply.
Soundcraft USA
8500 Balboa Boulevard
Northridge
CA 91329
TEL: 818.920.3212
FAX: 818.920.3208
EMAIL: soundcraft-usa@harman.com
WEB: http://www.soundcraft.com
Sound Technology plc
Letchworth Point
Letchworth
SG6 1ND
TEL: 01462 480000
EMAIL: info@soundtech.co.uk
WEB: http://www.soundtech.co.uk
Mr Jorg ter Veer
Audio Pro Elektroakustik GmbH
Pfaffenstrasse 25
74078 Heilbronn
TEL: +49 (7131) 2636 400
FAX: +49 (7131) 2636 430
EMAIL: info@audiopro.de
WEB: http://www.audiopro.de
Soundcraft Homepage
Nov 04, 2011 | Soundcraft Epm6 6-channel Multi-format...
Where (on-line) can we find download for advanced manual for Behringer PMP 4000 16 channel powered mixer? What we found on-line was the exact manual that came with the mixer.
There really ISN'T and "advanced" manual... Everything you need to know is in the user manual that comes with it... Service manual with schematics will not give you much you can use unless you are into electronics detail.
PLEASE read my tip about Behringer PMP mixers on here regarding a hazard if you use Speakon to 1/4 inch cables or adapters. Essentially, the sleeve, NOT the tip is the HOT lead for a speaker on channel A. Ground it inadvertently and goodbye channel A amp.
Be VERY careful of speaker leads with this amp as it is easy to pop a channel IF a speaker comes loose or shorts. Loop cables through the handlesto avoid cables being yanked out or breaking plugs.
Feb 09, 2011 | Behringer PMP4000/B212XL Mains & Monitors...
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
I have speakers plugged into my phonic powerpod 820 right now but I want also to have the output of the mixer to go through an instrument amp, is this possible? If so, where do I connect the instrument amp...
Yes it's possible. I'm assuming you'd like to use the keyboard amp as a "monitor". In which case, take a 1/4inch TS (instrument cable) jack out of "Aux Send" into the input of your keyboard amp. Make sure the keyboard amp is turned up to a good level and that the Master SEND is turned up on the Desk.
Now you can make your own "monitor mix" for on stage use without effecting the F.O.H mix by turning up the aux pot (knob) on each channel you use.
You can use the CTRL ROOM output also, but make sure it's not giving a "Powered Output" from the internal amplifier in the mixer as you will damage the keyboard amp.
Jan 16, 2011 | Phonic Powerpod 820 / S712 PA Package
Music Logo
335 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
