Question about Husqvarna 562xp Auto-tune Husky Xp 562
Wont start when hot
Clutch cover assembly 562 Xp auto tune
chain brake has been triggered, must disengage so the brake band will fit over the clutch drum.
Oct 04, 2014 | Husqvarna Garden
Why is intake very dirty?
The gas isoil base and collect fine saw dust
May 25, 2014 | Husqvarna 562xp Auto-tune Husky Xp 562
562xp leaking gas
Where does it leak gas? There is a tank vent that should only flow "in" if this vent is faulty it could leak. If the fuel cap is faulty this could be the leak. Lastly, the fuel lines could be leaking. Clean the saw and see if you can determine the location of the leak.
May 20, 2014 | Husqvarna 562xp Auto Tune 20" Chainsaw
Hesitation on acceleration rough idle
There is a Service Bulletin to address the stumbling off idle. Your dealer can perform the SB for you and will prevent the problem.
Apr 18, 2014 | Husqvarna 562xp Auto-tune Husky Xp 562
What is correct method for removing clutch cover on Husqvarna 562XP? Owner's manual does not state.
Always start with the brake loaded, if in doubt fully pull the hand guard back to the top handle, now use a 13mm spanner to loosen the two nuts, turn the chain adjuster screw so as too loosen the chain, now fully remove the two nuts ( the nuts are captive in the cover ) now pull the cver away from the saw
Sep 18, 2013 | Husqvarna 562xp Auto-tune Husky Xp 562
562xp backfire loss power
There were some issues with the fuel hose becoming kinked under heavy load, there is a later hose to stop this happening, the hose has a grommet which pulls into a recess in the plate under the carb, you can try removing it from the recess which gives it less bend as it comes up to the carb.
Jul 13, 2013 | Husqvarna 562xp Auto Tune 24" Chainsaw
Someone help me!
A relatively straightforward answer is that the AT4 is not VISTA compatible.
AT4 is not VISTA Compatible and has issues with XP 64bit. It is only guanteed to work with
Its compatibility list is as follows
DirectX
on Win 98, ME, NT, 2000, XP
@ V4.3.9
VST Mac
on Mac 10.2.6 or later
@ V4.3.9
VST PC
on Windows XP
@ V4.3.9
Oct 16, 2009 | Antares Auto-Tune 4 TDM Production Suite
Motorcycle engine stalls when cold.
fresh battery, turns over but wont start. 1995 gixxer 1100. chone on full then half then almost none still wont start.
Jan 09, 2009 | 2004 Sym Husky 125
Husqvarna 562xp Auto-tune Husky Xp 562 Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
