System initializing xerox 3428 - Office Equipment & Supplies
How to get the Factory Reset code for Xerox Workcentre M118
Enter diagnostics by pressing and holding the 0 button, then press the Start button. Then Press the login/out button, select System Settings, then CE Settings and then press enter button. Go to P-ESS and then select NVM Initialize.
Feb 21, 2016 | Xerox Office Equipment & Supplies
Tip
Xerox system error
If you are using a Xerox printer, you might have faced a system error problem, similar to "System error 09.038.46:113334" or something within that line.
I faced a similar error message like this a few months ago and i solved it using the following steps.
The ink count sensor flags were stuck.
Verify that the ink is correct and genuine and then reset the system and error message by performing the following steps:
1- Turn on the printer
2- Wait for the xerox logo to begin moving across the display
3- Before the logo is centered on the display (stops moving) press and hold the "back" and "help" buttons on the control panel.
4- Hold both buttons until the display reads "beginning service mode initialization".Release the buttons and the printer reboots into service mode with the "Service Diagnostics" menu displayed
5- Then scroll until you find function menu then click "OK"
6- Scroll until you find "Clear ISC" fault and press "OK"
7- Click back several times and then reboot the machine.
If you follow these exact steps your problem should be solved.
Thank you for using Fixya,
Kenneth.
on Apr 07, 2010 | Office Equipment & Supplies
Initilize system xerox
Turn the device off and unplug. Reseat the memory. Turn device on again.
Oct 26, 2014 | Xerox Office Equipment & Supplies
Xerox 8860 stuck at Test Complete Initialize
The Hidden Service menu provides access to information pages and tests for diagnosing and correcting system malfunctions and accessing special features.
Access the Hidden Service menu as follows:
1. From the System Setup menu, go to Information --> Troubleshooting --> Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu
Reset the NVRAM:
Resets the system back to default settings and clears all network settings. If possible, print the Configuration page before resetting NVRAM.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 23, 2011 | Xerox Phaser 8500/DN Printer
Changed cartridge and still the print is very dim why?
Laser unit on the printer is dirt. Must be cleaned with cloth and alcohol, but first have to disassemble.
Dec 31, 2010 | Xerox Phaser 3428 PS
Xerox Work Centre C2424 System Error
Hi there
I found some thing maybe do for you it may not be rhe right code you have at this moment but it come in handy for you.
31,004.40:6909: it's a mechanical initialization jam error. Pull out the paper tray to make sure it doesn't have a jam. Try also to manually feed some heavy paper or card stock through the printer to make sure the sensor in the preheater isn't stuck.
39,002.40 : DRAM test failure.
39,012.40:56208: "Cycle the power" and if that does not work replace the document feeder.
39,012.41: Document Feeder Optical Failure. Replace the document feeder.
4,0XX.6x: Process Control Software Fault.
· Reset NVRAM and then retest.
· Ensure ground integrity for the system
· Replace the EEPROM chip.
· Reboot the system.
· From the System Setup menu, go to "Information", "Troubleshooting"
· Service Tools menu.
· With the cursor at the top of the Service Tools menu, press both the Up Arrow
· and Down Arrow buttons to display the Hidden Service menu.
· Reset NVRAM is in there.
Also may be handy is this.
4,0XX.6x Process Control Software Fault
Error 04,041.66
Solution 1:
a. Reset NVRAM and then retest.
b. Ensure ground integrity for the system.
c. Replace the EEPROM chip.
d. Reboot the system.
Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
Solution 2:
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display, press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads “Beginning Service Mode Initialization”. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. Hope it will help you in some way of finding the fault. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 03, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
XEROX Phaser 8560MFP won't go past "initializing?"
Disconnect the data cable between the Electronics Module and the Printhead to see if Power On Self Test (POST) gets further, to the point where it displays a system failure code relating to the Printhead being disconnected. If so, replace defective printhead.
Dec 12, 2009 | Xerox Phaser 8560MFP Laser Printer
System error on xerox 8560dn 09 038 46 8515
ink count sensor flags are stuck.verify the ink is correct and genuine and then reset the error by doing the following
1- turn the printer on
2- wait for the xerox logo to begin moving acroos the display
3- Before the logo is centered on the display (stops moving) press and hold the back and help buttons on the control panel.
4- Hold both buttons untill the display reads beginning service mode initialization.Release the buttons and the printer reboots into service mode with the Service Diagnostics menu dislayed
scroll untill you find function menu then click ok
scroll untill you find Clear ISC fault and press ok
click back several times and then reboot the machine.
Good luck and let me know.
May 07, 2009 | Xerox Phaser 8560MFP Laser Printer
XEROX PHASER 6180 LASER ERROR 061-370. WHAT IS THIS?
Chain Link 061-370 An error was detected in the Laser Unit.
Initial Actions
? Cycle printer power.
? If the problem persists, follow the procedure below.
Sep 04, 2008 | Xerox Office Equipment & Supplies
24 people viewed this question
k24674
jasbo
jasbo
