Question about Sony KP-61HS10 61" Rear Projection Television
Hard time turning on
After moving we have to press the buttons several times to get it to turn on and we have no control over the volume and when you play a dvd in rolls side ways.
  • wererat Dec 22, 2007
    i have a problem with my 61hs10 that is close 2 what i read ur problem was...
    i can use the buttons on the set 2 turn the tv on/off and change chnls and volume... but my remotes doesnt work ... i went to be 1 night the next it wouldnt work...
    checked the batteries.... not the problem...
    President:
  • 4,402 Answers
Sounds like you have a loose connection
Posted on Dec 20, 2007
SOURCE:
How to hard reset prestige eliet visual land tablet
Hard Reset To hard reset your Visual Land Tablet, you need to follow the instructions below carefully.
1. Turn off the tablet.
2. Press and Hold Volume Up and Power button at the same time.
3. Keep holding the buttons till you see the start up screen.
4. Press Volume up five times when you see the android with an exclamation to reveal the recovery menu.
5. Since touch screen doesn`t work on this mode use Volume and down to move on the menu and power button to select.
6. Select Wipe Data/Factory Reset.
7. Select Yes- Delete all user data.
8. After the wiping select Reboot System Now.
Apr 01, 2017 | Tablets & eReaders
Lg g4 reset
To perform a master reset:
1. Back up all data on the internal memory
2. Turn off the device
3. Press and hold the Power and Volume Down buttons until the LG logo appears on screen
4. Quickly release and the resold the power button while continuing to hold the volume down button.
5. Factory data reset appears
6. Use volume down to highlight yes
7. Press power to confirm
8. Volume down again to highlight yes to erase all user data and restore default settings
9. Press power button to reset device
May 14, 2016 | LG G4
Hi do you know how to hard reset PM-0510-BV
From the home screen, press Menu - Backup and reset - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
if you can not access this area you can proceed with the following.
This will remove all data from your device and set it back to factory defaults.
While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select
Your phone will restart and may take several minutes to come back up.
Nov 21, 2014 | Office Equipment & Supplies
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Oct 29, 2014 | Tablets & eReaders
How do i turn on my Polaroid Shuffle 4GB MP3 player?
There is a led light in the upper right corner of the front. The controls are on the large round button in the center. To turn in on, press in the center of the button; the device will turn on and playback will begin. To turn it off, press AND HOLD the center of the button until the LED light flashes several times and then turns off.
To play, press the center of the button and the LED should come on and stay solid. To pause, press the center and the LED will blink once a second Press again and playback will resume.
Think of the big button as a clock face. Press at 12 for volume UP. Press at 3 for next track; HOLD for fast forward. Press at 6 for volume DOWN. Press at 9 for previous track; HOLD for rewind.
For shuffle, press at 12 and 6 together and hold for 2 full seconds. The LED will flash 4 times to show you are in shuffle mode. To go back to normal playback, press at 12 and 6 together for 2 full seconds and the LED will flash 2 times to show you are back to normal mode.
Jul 15, 2014 | Polaroid Audio Players & Recorders
Locked out of my tablet by my child entering a new pass word...
To unlock your tablet, you will have to perform a factory/hard reset of the device.
Performing a hard reset will DELETE ALL DATA from internal device storage and reset the tablet back to the state before you turned on the device for the first time. Resetting the tablet does not erase any system software updates you have downloaded or any files on your SD memory card, such as music or photos.
To perform factory/hard reset please follow those steps:
1. Turn the power off.
2. Press and Hold the Volume Up and Power button at the same time.
3. When the start up screen show (Samsung logo displays on the screen), release all the buttons.
4. Use the Volume Up/Down button to navigate to "wipe data/factory reset", select with Power button
5. Select "wipe data/factory reset"
6. Select "Yes -- delete all user data"
* Allow several minutes for the factory data reset process to complete.
7. Select "reboot system now"
* Allow several minutes for the reboot process to complete.
Oct 10, 2013 | Samsung Xe700t1a-a05us Tablet
How do you set the clock on sony xplod 100db+?
The clock uses a 12-hour digital indication...... Press and hold the select button...... The setup display appears...... Press the select button repeatedly until “CLOCK-ADJ” appears...... Press (DSPL...... The hour indication flashes...... Rotate the volume control dial to set the hour and minute...... To move the digital indication, press (DSPL...... Press the select button...... The setup is complete and the clock starts......
Jan 28, 2010 | Car Audio & Video
Don't know how to turn off the alarm. Bought this used (made in 1995) so there were no books with it. It comes on every day at 2. The system is on 'standby' all the time. I just don't seem to find the...
Setting the ON time (Example: AM 10:15).
1. Press the TIMER button on the Unit for more than
two seconds.
The Timer indicator lights up and the hour digit of the
current ON time blinks on the display.
• When the clock is not set, “CLOCK” and “ADJUST”
appear alternately on the display. Set the clock first.
Press the ¢ or 4 button on the Unit to set the
hour you want the Unit to come on.
Pressing the ¢ button moves the time forwards and
pressing the 4 button moves it backwards. Hold
down the button to move the time rapidly.
2. Press the TIMER button.
The minute digits of the ON time blink on the display.
Set the minute you want the Unit to come on, using
the ¢ or 4 button.
2 Setting the OFF time (Example: PM 1:30).
1. Press the TIMER button.
The hour digit of the OFF time blinks on the display.
(The same time as the ON time will be automatically
set.)
Set the hour you want the Unit to be turned off, using
the ¢ or 4 button.
The minute digits of the OFF time blink on the display
Set the minute you want the Unit to be turned off, using
the ¢ and 4 buttons.
3 Selecting the music source.
The “TUNER” or “CD” blinks on the display.
2. Press the ¢ or 4 button to select the music
source you want to listen to.
The display changes as shown below.
TUNERôCDô(back to the beginning)
4 Setting the volume level.
The current volume setting blinks on the display.
2. Press the ¢ or 4 button to select the volume level.
-- :The current volume level will be used.
0 to 50 :When the timer is turned on, the Volume
will be automatically set to the selected
level.
5 Press the TIMER button.
The timer setting is completed and the display returns to
the display before you set the Timer. The Timer indicator
remains lit.
6 Before turning off the System, prepare
the music source selected in step 3.
TUNER: Tune in to the desired station.
CD: Insert a CD. (Playback will start from the first
track at Timer on.)
7 Press the % button to turn off the System.
In standby mode, you can see the Timer indicator ( )
on the display.
• When the timer turns on, the Timer indicator starts
blinking and the prepared source in step 6 will be
played.
To cancel the timer, press the TIMER button. The
Timer indicator ( ) goes out on the display.
To re-activate the cancelled timer, press the TIMER
button to light the Timer indicator ( ).
At this time, you can see the current timer settings. Each
setting appears on the display for two seconds in the order
of ON time, OFF time, music source and volume.
To change the timer setting, repeat the setting procedure
from the beginning.
Oct 31, 2009 | JVC KD-G210 CD Player
Reprograming my tv remote
Hi chevry,
universal remotes vary with respect to button options. For a Sanyo TV you can try these codes. (This is manual mode).
0098, 0066, 0091, 0023, 0017, 0027, 0080.
Press the TV button on the remote. Than press & hold the set button until the LED stays on. Enter the four-digit code. When the remote control recognizes the correct code the LED will turn off. If the code is not correct the LED will flash several times & stay lit. Enter the next code. (You'll have less than 25 seconds to try another code) or the remote will exit the programming mode.
How to use the auto search. (One code at a time). This will take some time.
Turn on the TV. Press & hold the set button until the LED comes on, point the remote at the TV & press the volume + once (This moves the remote through 1 code at a time. Continue to press the volume + (Do not do this very fast or you'll miss the correct code), until the TV turns off or changes channel. Than press the set button again & the LED will go off. The remote should now be programmed for the TV. Test TV by turning the on/off button on remote. Check volume up & down.
Good Luck!
Mike
Jul 04, 2008 | Televison & Video
Universal Remote Control codes
Most universal remotes have a search mode. They work like this. Most want the TV turned off. Than press the button (TV) than press & hold the set button till the led comes on. Point the remote at the TV than press the volume + to increase. This will take you through the codes one digit at a time. Each time you press the + the remote moves up to the next code. This may take several minutest. Once the TV turns on press the set button again & the led will go out. That's it.
Feb 23, 2008 | Televison & Video
Sony KP-61HS10 61" Rear Projection Television Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
