Carrier air con model 38rq033900-21
Just bought a house and it has this model air con. how old is it and is it work servicing
bobotfel
  • 236 Answers
SOURCE: Can't get airconditioner to work
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If wont work then there are some safety device that work or defective. Try counting the blink of your green light so that I can convert the error code.
Posted on Jan 08, 2009
tborn6
  • 700 Answers
SOURCE: Carrier Furnace Model 58STA/STX not firing
Have you checked the gas valve on the unit.. is it set to on? also check the gas valve going to the unit on?
Posted on Jan 21, 2009
jumptrout51
  • 3361 Answers
SOURCE: air not going cold its staying hot
Set the thermostat to COOl and lower the temperature control.
Posted on Mar 10, 2009
james3751
  • 614 Answers
SOURCE: carrier air con. expansion valve 5 problems and 5 solutions
1. Mid to late 90's problems on Carrier coils leaking. 2. Problem with lication of TXV's on air handlers. When welded in they were located to close to the fitting where the suction lines were welded in to unit. The heat would cause them to fail.
Posted on Mar 25, 2010
wise_jf
  • 66 Answers
SOURCE: wiring diagram needed for carrier air con unit
Here ya go:
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/38ckc-c2w.pdf
Posted on Jun 30, 2010
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
Replacement air filter
I'll let you know if the parts are available..
Jun 02, 2008 | Carrier XCA141D Air Conditioner
Air conditioner model # 38ckc 42..350 not working, keeps tripping the breakers, had electrician check out and stated it was the fan or the compressor, i bought the house in 2009, was built in 2005, what do...
Hi, if that is a 2005 carrier condenser, it may still have a warranty on the compressor. You need to copy down model and serial #, call the local Carrier rep and ask. That is your right to do so. The fan is probably not in warranty, but it is definitely worth replacing if it is bad. I sold carrier for 15 years, and sold many with 10 year parts warranty. First thing you need to do if you haven't done so is check on your warranty! If you can explain what it is doing a little more in detail I could probably tell you exactly what is wrong. Hope this helps.
Jun 23, 2011 | Carrier 38CKC042 Air Conditioner
Wiring diagram needed for carrier air con unit
Here ya go:
May 27, 2010 | Carrier 38CKC036 Air Conditioner
Air not going cold its staying hot
Jan 13, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
REMOTE WON'T WORK WITH AIR CON UNIT
First turn off all the power inside and out then back on and change your batteries in the remote. And look on the remote for an extra switch that may have been moved during the outage and you don't ordinarily see it. If neither of these solutions work its most likely a service call. to tell you more.
Dec 12, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Product # 38BRC042320
This unit was manufactured 1/8/00 and is a 4 1/2 system
Sep 30, 2008 | Carrier 38CKC036 Air Conditioner
Carrier 38CK036330
The model numbers change.You have a 3 ton system.The make and model that you replace it with is not nearly as important as a quality install.Do your homework on picking a contractor that you can trust.Have them do a load calculation to make sure a 3ton system is right for your house.13 seer is the minimum you can get.You need to weigh the projected annual savings of higher seer units against the added cost of having them installed.Again,get a contractor you trust and go with the best warranty.None were stupid questions.
Jul 08, 2008 | Carrier 38CKC060 Air Conditioner
Changing filter
The filter should be located in the return air flow duct either inside the furnace or in the ductwork
you should have it inspected by a service contractor
as far as when it should be replaced depends on the condition of the heat exchanger and overall condition of the rest of the parts it could start to nickel and dime you
Dec 31, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier air conditioner
Need the model no. It will be on the unit somewhere, on a plate on the back area, or if it's a unit with seperate condenser, the no will be on the condenser outside, or wherever it is.
Dec 30, 2007 | Heating & Cooling
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
