Question about Sewing Machines
Pfaff hobby 1042 manual
Feed dog is hardly working and when it does, it is feeding in the wrong direction
  • 29 Answers
SOURCE: feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
Posted on Jul 14, 2007
  • 106 Answers
SOURCE: feed dogs
If the machine has a 'darn' facility and this is selected the feed dogs 'will' stay down.
Other than that(without looking) i would guess a good clean and a dose of lubrication would not go amiss.
Try removing the needle plate to see of there is any compacted "fluff/lint" or indeed anything else stopping the dogs rising. Take off the bottom access cover have a good clean out and oil.
Best of luck
Rob
Posted on Mar 28, 2008
  • 192 Answers
SOURCE: feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Posted on Nov 01, 2008
  • 2976 Answers
SOURCE: Feed dogs do not come back up after lowering
Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
Posted on Jan 03, 2009
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Posted on May 01, 2009
The feed dog on my Pfaff Hobbylock 784 broke in half. Are there any replacements?
Hello, Mary -
I am having no luck in finding a replacement feed dog for your specific model of Pfaff sewing machine. I suspect a replacement feed dog is available your model and other Pfaff models.
If you can locate an authorized Pfaff sewing machine repair business in your area, someone there can probably tell you what the right part number is for the feed dog and may be able to sell you one.
This is the link to the Pfaff Machine Support web page:
http://www.pfaff.com/Support-and-Updates/Support
Best wishes.
Feb 12, 2018 | PfaFF Sewing Machines
Given Pfaff 297-1 sewing machine for charity work everthing seems to be right but it does not feed - the feedogs seem to be too low. It's sewing steadily on the spot.
Could be the feed dogs are lowered to do darning. Here's a manual:
PFAFF 294 Instruction Book Page 11
See if the A/B switch makes any difference in the feed dogs.
Sometimes these old machines haven't been oiled like they should and it's possible the feed dogs are stuck in the lowered position. Also, if it was used a lot the feed dogs get worn and no longer work like they should.
Jul 16, 2017 | PfaFF Sewing Machines
How do I raise and lower the feed Dogs on the PFAFF hobby 1200 Grand quilter
According to the following web site, the feed dogs do not drop on this machine, Instead, there is a plate that covers the feed dogs:
Fluffy Sheep Quilting Do you have one of these Do you like it
Also thought this was interesting:
Oiling the PFAFF Grand Quilter 1200 Bernina Sewing Center Tampa
Dec 10, 2015 | PfaFF Sewing Machines
Pfaff quilt expression 4 0
Not sure what the problem is but you might try this:
Remove the top thread completely from the machine.
Make sure the machine is cleaned under the needle plate, the hook/bobbin area, the feed dogs, etc.
If your manual instructs oiling, do so as described.
Confirm that the feed dogs are in the raised position.
ALWAYS RAISE the presser foot then rethread the top thread from the beginning.
Verify the thread path is correct.
Confirm the needle is installed correctly (does the flat part face the right direction?). Is it the right needle for your machine.
Set the top tension to the midway point.
Check that the stitch length is set to at least #2.
Re-test your machine. Tweak the top tension until the top and bobbin threads meet in the middle of the fabric.
Some machines have a presser foot pressure adjustment that increases or decreases the amount of pressure the presser foot applies to the fabric and the feed dogs. You may need to increase this pressure.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjUwYDwuKjVAhULwFQKHRLIA1YQFggmMAA&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2Fexpression-line%2FManual%2Fexpression-3-2-4-2-manual-EN.pdf&usg=AFQjCNFFR0YpgCUh8R92wNbPzlJpuzWVNw
Jul 26, 2017 | Sewing Machines
Pfaff expressions 3 feed dogs will not raise when switch is moved right
If the switch feel very easy to move then the linkage to the feed dogs is off somewhere. The machine will need to be opened and checked where and what.
Jan 13, 2013 | Sewing Machines
My pfaff will not feed fabric forward
Check to see if you've accidentally lowered the feed dogs.
Jul 06, 2012 | PfaFF Sewing Machines
Pfaff 1229 feeder dog too low
if you have a manual to see where the feed dog lever is, to see if it's
in the up position, if not have the machine checked to see if the
feed dogs need to be adjusted
Jun 12, 2012 | PfaFF Sewing Machines
Heavy material feed dog
To the very best of my knowledge (and I've been full time as a manager / owner in my family sewing machine sales / service business for almost 30 years (with many more part-time before that), I know of no "heavy material" feed dog that has been available for the Pfaff 130. Please keep in mind that the 130, while pretty heavy duty (especially compared to many of today's machines), was never manufactured or intended to be heavy duty in the sense of sewing heavy items such as uphaolstery fabrics (canvas, nagahide, etc.). It was produced with the intent of being a reliable household (non-commercial / industrial) machine with the purpose of sewing light-to-moderate heavy metrails. What exactaly are you trying to sew that leads you to the request of using "heavy material" feed dogs or that you feel Pfaff produced / manufactured such an item?
Best regards,
Dave
May 06, 2009 | Sewing Machines
Lowere feed dogs - false error message
There is alot of information here, and the folks there know your machine best.
I just looked and there was another question like this asked.
Mar 26, 2009 | PfaFF Creative 7570
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
