Question about Coverking 1987 Cadillac Sedan DeVille Ballistic Custom Seat Covers
Trunk release button on 1987 cadillac
Button in glove compartment does not open trunk
Weres the fuse for the gas opener in 99 deville
try looking in the glove compartment press trac/valet button if i press this button my gas flap won't open to also the trunk don't open as well
Dec 07, 2013 | 1999 Cadillac DeVille
My 1987 Cadillac fleetwood D'elegance trunk wont open,even when i push the trunk release button in the glove department
Do you hear a click noise at all? You could try this.. One person sit on the truck lid, (heavier may be better) relieving the lift tension on the lock, while the other person push the button and hold. Sitter then hops off and pulls up on the trunk lid. If not working, Sitter person could try gently bouncing on the trunk lid while you hold the button.
Groceries still in trunk after 3 months???
If no joy, then you need someone to replace or remove the lock and pop it with a screwdriver.
Nov 15, 2013 | 1987 Cadillac Fleetwood
I have a 97 chevy lumina that I cannot find the trunk release button to. Need help!
The trunk release button should be located in the glove box. mine is a yellow button and yours should be too.
Oct 31, 2010 | 1997 Chevrolet Lumina
2002 Toyota Avalon. The trunk release button on the dash does not open the trunk. The key fob does not open the trunk. Only the key will open the trunk.
My avalon 2002 trunk was not opening. The problem was a little switch in the glove compartment was depressed I puched the switch back in and wala everything was just fine again. A lil black switch in the glove compartment. wish u the best.
Sep 22, 2010 | Toyota Avalon Cars & Trucks
My husband and I have a 1994 Cadillac Seville STS with a trunk release malfunction. We have tried to open the trunk by inserting the key in the lock, but the key will not turn. Until today, we were...
Does the key you have open the driver door? Do you have a keyless entry key fob, does it work? you also might try removing the glove box and disconnecting the wires from the trunk button and touching them together with a paper clip or other small wire but before you do that look in your owners manual a determine which fuse is for the trunk release and check the fuse then the last would be to have GM dealer check to see if the key you have is the proper key fror your car and if it may be worn out
Aug 29, 2010 | 1994 Cadillac Seville
Trunk release and fuel door does not work
open the glove box and push the valet button, then try the trunk release,,,good luck....
Mac..........
Feb 13, 2009 | 1999 Cadillac DeVille
Truck release 2005 Infiniti G35
We finally flipped the glove compartment trunk switch (found on the left side inside the glove compartment) to 'on' then the trunk switch by the driver seat worked. We could not tell the trunk switch in the glove compartment was an on/off switch, we just kept searching and finding,
Dec 13, 2008 | 1998 Audi A4
Coverking 1987 Cadillac Sedan DeVille Ballistic Custom Seat Covers Logo
43 people viewed this question
Top Coverking Electronics - Others Experts
terry stevens
Richard Warren
Richard Warren
Are you a Coverking Electronics - Other Expert? Answer questions, earn points and help others
