I have a proline logic washing machine it spins but the washing is soaking wet, checked pipe think i found filter at bottom of machine unscrewd it but has another bit under it so cant get to it
fanny
  • 146 Answers
SOURCE: Clothes wet, doesnt spin fast
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
Posted on Oct 31, 2007
  • 107 Answers
SOURCE: My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Posted on Mar 13, 2009
  • 86 Answers
SOURCE: tricity bendix BIW103W spins badly, clothes still too wet.
Hi, Your problem is very common and very easy to fix. You will first need to strip the machine down and remove the motor. Once you have done this then take off the motor carbon brushes, These are the little things in cases on the side of the motor casing. These should be at least 1" long! you will find that this is not the case and they will need replacing to resolve your problem. The parts should not cost anymore than around £20 for the pair.
Good luck any problems get beck to me............................
Posted on Mar 18, 2009
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: Clothes are soaking wet after the entire wash cycle.
The motor controller is likely bad - not getting to the HIGH spin.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
What does Err4 mean on proline PFL510W-U1 washing machine
proline pfl510w u Washing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > proline pfl510w u
Washing Machines proline pfl510w u questions and answers. ... need user manualfor proline logic on line need user manual for proline logic ... PROLINE LOGIC 6 KG AA WASHING MACHINE- It is stuck on "error2" what does this mean and ...
Washing machine PROLINE PFL510W - Manual.com
https://www.u-manual.com/...manual.../washing-machine-proline-pfl510...
On this page you can get: Washing machine PROLINE PFL510W manual - is available for free download. All information such as file size, preview picture, ...
Anyone know how to reset a Proline washing machine ...
forums.moneysavingexpert.com/showthread.p...
MoneySavingExpert.comApr 3, 2010 - I can't find the manual, either at home, or online. Our washing machine(PFL 1466W-U) is showing off today. We've managed to take ... Does anyone know how to stop it from running this programme, so that we can select the empty/spin cycle. We have .... Ok it's a cover not written but you know what I mean.
Dec 16, 2015 | Washing Machines
Wont spin
have you cleaned the filter
if you have
change the motor brushes
Mar 10, 2014 | Hotpoint Aquarius WD63 Front Load...
Front loader spins at high speed, clothes still soaking wet? why?
I think the water is syphoning back from your waste outlet make sure the waste pipe is installed correctly
Jan 22, 2013 | Washing Machines
Spin not working properly, sounds ok but clothes are too wet once complete and the independent spin cycle leaves clothes soaking!!!
Sounds like a small blockage in the outlet pipes, possibly just in the filter but check all outlet pipes. Just done one the other day and it was a clothes button that had passed out of the machine through the pump to the outlet pipe but had turned sideways inside the outlet pipe.
Jan 25, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Will not spin in final spin
there is likely a blockage in the pump/bottom water feed hose. check out the filter and if clear you will have to clean out the bottom hose.
Apr 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Spins but is soaking wet
There is something impeding the outlet of water. Could be a pipe blocked, a pump filter needs cleaning, the spigot, the point at which the washing machine drain hose connects to the sink, is blocked. Definitly caused by,'slow' release of water.
Apr 04, 2009 | Washing Machines
Wd865 spinning problems
PUMP IS BLOCKED OR PIPE LEADING TO IT ROMOVE FRONT BOTTOM PANEL AND YOU SHOULD SEE A ROUND THING WITH A SCREW IN IT REMOVE SCREW TWIST AND PULL OUT REMOVE DEBRIS AND TRY AGAIN IF THIS DONT WORK LAY MACHINE ON ITS BACK REMOVE PIPE FROM PUMP AND CHECK IT NOT BLOCKED WITH ANYTHING ITS QUITE AN EASY JOB TO DO
Mar 04, 2009 | Hotpoint Ultima WF865 Front Load Washer
After washing clothes are still coming out wet
If its a washing machine there going to be wet arent they lol.
right if you mean that they are soaking wet after spinning it could be that the water is not draining away fully, have you checked the filter and cleaned that out, usually at the front of the machine on the bottom right. try draining that, or there could be a blockage in the waste pipe,
hope that this helps
Feb 28, 2009 | Hotpoint WMA30 Front Load Washer
My hotpoint wma56 wont do its fast spin cycle
Have you checked and cleaned the filter on the machine, usually located and the front near the bottom. If so then there is 2 other possibilities, either your water pump at the back of the machine is blocked or faulty, or it's the timer on the machine. A washer won't go into spin mode until it has drained all the water from the machine first. hence the pump has to run. Just remember to drain all the water from the machine before checking your filter otherwise it will end up on your floor.
Sep 22, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
