Honeywell thermostat flashing cool on - Heating & Cooling
  • 252 Answers
SOURCE: need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
Posted on May 16, 2009
  • 252 Answers
SOURCE: HONEYWELL T87N 1000 ROUND THERMOSTAT
the power for that stat comes from the furnace - if you have no display on the stat you have a furnace problem
Posted on Sep 28, 2009
heatman101
  • 43501 Answers
SOURCE: ac unit will not cool.
Yes, that is normal operation if you have the fan setting to "on"
heatman101
Posted on Jul 12, 2010
duane_wong
  • 6826 Answers
SOURCE: I changed the batteries on
Check the connection between the thermostat and the two leads that lead to cooling for the AC at the wall.
Posted on Oct 13, 2010
  • 16 Answers
SOURCE: On my honeywell thermostat cool on keeps on
On a Honeywell thermostat the flashing means that the system is in a delay to turn on the compressor. This is used to protect the compressor from coming on and off too often. The normal delay is about 5 minutes. After that the system should come on. If not there is s problem.
In order to help us help you we will need a little more information. What happens either at the inside unit or at the outside unit after the thermostat stops flashing "Cool"? Any fans come on? Do you hear a "KLUNK"? Any sparks? Please let us know so we can help.
Posted on Nov 20, 2011
What does the snowflake mean on a Honeywell thermostat in cooling mode. Also had the problem in the heating mode.
The snowflake means it's cooling. If the outdoor unit is not running then the problem is likely outside.
May 21, 2017 | Honeywell Heating & Cooling
I have a Honeywell RTH6580WF Wi-Fi Thermostat that has "Cool On" or "Heat On" flashing in an endless loop. Could there be a major issue?
Pull the power red wire off the thermostat and batteries out if it has battery backup, then reinstall...much like a computer restart. If this doesn't work, then replace your thermostat.
Jan 21, 2016 | Honeywell RTH6580WF Wi-Fi Thermostat
On my honeywell thermostat cool on keeps on flashing but ac dosent come on
Nov 20, 2011 | Honeywell Heating & Cooling
My Johnson Control Thermostat is just blinking AC not the snowflake or cooling. I can't see the temperature or anything like that? It' just flashing AC.
I recommend you go to Honeywell site and type in your thermostat model etc. It will give you step by step procedures and may provide the answers you are seeking.
Aug 03, 2011 | Honeywell Electronic Programmable...
Heat not woking purge light flashing
The flashing light is giving you a code as to what is work... have you tried to recycle the power???
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Jan 15, 2011 | Honeywell Electronic Programmable...
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
The thermostat is not cooling to set themperature. The cool on light is flashing.
ok, your thermostat doesn't do any cooling! your a/c does the cooling. is the equipment running? is your air filter clean? is your refrigerant charge ok?
Aug 09, 2009 | Honeywell Programmable Thermostat Heater
Honeywell thermostat display has flashing snowflake /ac not working
the flashing snowflake is it telling you its in % min delay if it doesnt stop flashing within 5min it may be a bad tstat. if it goes solid and the unit is still not working its probably not the stat
Jun 13, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
