Question about Garden
Bolens 11a 414e765
Rope pulls but fly wheel doesn't turn
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: need repair manual for briggs
After a very extensive cross reference session your engine is model number
10H902-0285-E1 (not provided by you so it took a while)
Your engine is covered in this repair manual:
http://www.mymowerparts.com/pdf/Briggs_&_Stratton_Service_and_Repair_Manuals_Spec_Charts/270962%20Single%20Cylinder%20L-Head%20BRIGGS%20&%20STRATTON.pdf
If there is a problem that your having I can help you if you would just elaborate. I could save you lots of time. The 2 most common failures of this engine is on the carburetor. The parts that fail are the diaphragm (Item 394) and the primer bulb (Item 976) of this link:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=10H902-0285-E1&dn=57160004
Carb data is in section 3 of the first link.
Thanks for choosing FixYa,
Kelly.
Posted on May 10, 2011
  • 640 Answers
SOURCE: BOLENS 11A-414E765: Starts fine, but after a
Sounds like there may be a fuel flow restriction or partial blockage between the tank and the carb. If you have a fuel filter it may be time to change it. If that is not it there may be something in the line. I once found a wasp in the fuel tank. If not in the fuel delivery then you may have to clean the carb.
Posted on Jul 07, 2011
I ran over a rock with my craftman 650 lawn mower and it now makes a funny cranking noise when I try to start it I changed the fly wheel key and it still doesn't start.
When you try to start the engine pulling on the rope, is it easier or harder to pull to turn over the engine? If easier there is internal damage as below, if harder there is internal damage as below. That cranking or grinding sound could be the rope starter or the clutch of the rope start. So when you have the cover off of the flywheel pull on the rope and see if it makes the sound you are hearing and check the clutch that threaded onto the the crank holding the flywheel in place see that it turns in freely in the opposite direction of the engine running.
You may have bent the crank, take the spark plug out, put the mower on it's side with the carburetor on the up side and turn the mower blade by hand and see if you can tell if there is a wobble. While you have the spark plug out, look in the plug hole while turning over the engine to see of the piston is moving up and down. Another possible problem the cam gear could be broken and the valves not opening and closing in time with the crank.
Jan 16, 2015 | Garden
Pull rope will not pull
Remove recoil rope assembly. Ensure rope is properly wrapped around. While recoil assembly is removed use ratchet and socket to rotate fly wheel, remove spark plug first, observe compression and exhaust at spark plug whole during rotation of fly wheel. Clean or replace spark plug. Ensure oil is full. 30w. Set spark plug gap. Always use Stabile in gas. Replace coil rope is required. Purchased by the foot at any mower repair store.
May 12, 2013 | Toro Super Recycler Super Bagger Lawn...
Replacing a pull string on a lawn mower
This can be tricky depending on the brand. Most pull start systems will have 3 or 4 bolts on the fly wheel- puppeteer cover.when you take the cover off, it should all stay together. It will have a plastic wheel inside that the rope winds aroundand in the center of the wheel should have a bolt. Remove the bolt and remove the plastic wheel, but be careful it will have a wind up spring, but most newer models have an enclosed spring.you should see a hole in the side for the pull rope. Insert the rope through the outer sheild first and thenthen in theslot of the wheel(kinda like stringing a yo-yo) then insert the end of the rope on the side of the wheelwheel in the hole, and tie a small tight knot in the rope so it won't slip through.then put the wheel back in the shield, and wind up the rope around the wheel. You should feel the spring tighten up. Don't let go of the spring tensioned wheel and rePlace the center wheel bolt. The handle should sticking out the sheild hole. Now replace the assembly on the mower. Some models you have to wind the spring and hold it tensioned with a wire while you replace the sheild, this tricky. But most wind upwhen you pull the rope out. So when you release the rope the spring will wind it back up. Good luck this task can be tough for first timers.
Jul 31, 2011 | Briggs & Stratton Garden
Good day, The pull cord on my friends coleman powersport 1850 was cut and i have not been able to find any info on how to remove the pulley to repair it.The pulley cover is riveted to the the fly wheel...
Don't drill out the rivets. You have to remove the larger cover as one unit. There are several screws, some of which might be covered by labels. When you go to replace the rope, you have to pre-load the spring. You can do this by winding an extra long rope on the pulley, extracting about half of it through the normal hole (thereby winding up the return spring), and cutting off the extra rope that you have extracted. Be sure to tie a knot in the rope before you cut it so you don't lose the end of it back inside. If the pulley doesn't provide enough room to wind the extra rope, you can also preload the spring by turning the pulley (in the direction that would "push" the rope out through the hole) about 5 revolutions before you put the end of the rope through the hole. Good luck! Al K
Jul 29, 2011 | Coleman Powermate Powermate 5000W...
BOLENS 11A-414E765: Starts fine, but after a minute or so, it throttles down to a low idle. It has no throttle control. Idle does not pick-up when cutting grass.
Jul 07, 2011 | Mtd Garden
Need repair manual for briggs and stratton 4.5 hp on bolen lawn mower model 11a-414e765
Kelly.
May 10, 2011 | Briggs & Stratton Briggs Stratton...
The tiller stalled out and now won't crank. Why?
Was there oil in it? Check and see if a rock or other item is wedge in the tines. Take of the engine shroud, remove the spark plug and see if you can manually turn the fly wheel. If you CAN turn the fly wheel pull on the pull rope. It might just be stuck. If you CANNOT turn the fly wheel then the engine is probably blown.
Good luck hope this helps.
roundo4
May 23, 2010 | Troy-Bilt Pony Garden Tiller
Cannot pull the pull rope. Feels like motor is froze but when I pull the pull rope cover off the pull rope pulls freely and I can turn the fly wheel by hand easily. Put everthing back togeather it will not...
PISTON COULD BE SEIZED DUE TO LOW OR NO OIL MIXTURE,ALSO IT COULD HAVE FUEL IN THE CHAMBER,FIRST REMOVE SPARK PLUG--NOW TRY TO PULL IT--HINT,STICK A SMALL SCREWDRIVER IN THE HOLE AND SEE IF THE PISTON RAISES AND LOWERS,,IF IT WILL RAISE/LOWER BY MANUALLY TURNING THE CRANKSHAFT,THEN THE PROBLEM IS IN YOUR INNER PULL ROPE ASSY.(THERE ARE DOG EARS INSIDE THAT SPIN OUT AND GRAB THE FLYWHEEL WHEN IT TURNS)
Sep 08, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
I want to change the pull crd on my 6.5 hp craftsman lawnmower
remove the engine shroud. Pull the cord all the way out. Put a screw driver into the fins so it does not unwind. Cut new cord and install through hole in shroud and the rewinder. Reattach handle to cord and hold onto rope and pull screw driver out. Slowly let cord rewind. Pull a couple of times to make sure it is working. While engine shroud is off us a piece of emery cloth or fine sandpaper to clean off the magnets on fly wheel and the two little prongs close to the fly wheel.
Good luck let me know if this helps.
roundo4
Aug 14, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
How to assemble pull cord
Remove engine cover. Try turning the inside where rope goes counterclock wise then let go (watch your fingers so you don't get pinched. If it spins back remove the rope and and turn the inside till you get some good tension. Put a screw driver through the fins to hold the inside in place so it doesn't unwind. Make sure you line up the hole in the inside so the rope will go straigh through the hole on the shroud and the inside wheel. Tie off the rope and hold the rope and remove the screw driver and slowly let rope back in. Pull a few times to check before reinstalling. Also check the inside wheel. There should be in the center of the wheel a bolt that holds on a flat piece of plastic and under that directly across from each other is two little tabs that engage the fly wheel. Make sure they are both properly seated. If it recoils when you test it reinstall and try starting mower.
Good luck and let me know if this helps
roundo4
Aug 13, 2009 | Mtd Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
