Question about Yamaha Portable Keyboard with 61 Touch-Sensitive Keys and General MIDI
Yamaha PSR-6 Keyboard with dead notes - Yamaha Portable Keyboard with 61 Touch-Sensitive Keys and General MIDI
robocop
  • 90 Answers
SOURCE: Instruction manual for a Yamaha PSR 195 keyboard.
Try going to http://www.yamaha.co.jp/manual/english/index.php. There, you can try to find your owners manual for free.
Posted on Jan 22, 2009
SOURCE: How do I take apart Yamaha PSR-280 keyboard to clean keys.
There are 17 screws on the underside of the keyboard that need to be removed. The base cover can then be removed. This gives access to the keyframe assembly which can be removed.
Posted on Feb 08, 2009
SOURCE: Yamaha PSR-510 Keyboard
There is no need for a manual. It is so easy to operate because it is designed for easy opeating. If you need a manual to operate the PSR-510 then you really won't be able to operate it even after studying the manual. But here it is just in case you can by some miracle!
http://www2.yamaha.co.jp/manual/pdf/emi/english/port/PSR510E.pdf
Posted on Feb 10, 2009
SOURCE: Yamaha PSR-280 : AC power instead of DC power
An answer, but likely not a solution. I believe all Yamaha PSR series keyboards use the same 12 VDC adaptor, so I looked at the electrical schematic for another model I have. There seems to be no fuse on the power input. There are two components shown on the positive and negative wires off the power socket, but the symbols do not look like anything I have seen for fuses - they may be resistors. Power goes directly to a 5 VDC voltage regulator, which powers all of the solid state componenents. Too much voltage of the wrong type could have easily ruined many of the sensitive components.
Your only hope is to check the power socket area for the possibility of having fuses. My drawing shows the power socket, voltage regulator, and audio power amplifier being on one circuit board. That may not actually be the way it is in your model.
(your English is fine)
Posted on Mar 14, 2009
SOURCE: Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Posted on Feb 14, 2010
Manual for PSR 270 KEYBOARD
Yamaha has the manual for the PSR-270 keyboard on the product site: http://usa.yamaha.com/products/musical-instruments/keyboards/digitalkeyboards/portable_keyboards/psr270/ . Click on the support tab. The direct link to the manual (in English) shows in my history as: http://download.yamaha.com/api/asset/file/?language=en&site=usa.yamaha.com&asset_id=35052 .
I hope this helps.
Jun 03, 2016 | Music
Install PSR E413DRIVER
What driver do you want to install?
Jan 14, 2014 | Yamaha PSR-E413 Portable Keyboard
Yamaha psr 1000
Hi
I'm not sure I completely understand your problem but......it sounds like you might be in "Fingered On Bass" mode. This means if you play a chord like F using the notes FAC- if you play them in 2nd inversion (so the order is CFA) the psr-1000 will make the note "C" the bass note. In this mode if you played ACF then "A" would be in the bass part. Change to "Fingered Chord"-this will enable you to play any chord with the tonic (the name of the chord) F whether you play FAC, ACF or CFA in the bass part. I don't have access to a psr-1000 but often with Yamaha instruments this can be changed by pressing and holding the "Auto Accompaniment" button. I hope this helps.
Musicwez
Aug 04, 2013 | Music
How to fix Yamaha PSR 400 dead keys?
Normally this would be from dirty or broken key contacts.
Apr 19, 2013 | Yamaha YPT400 61 Key Portable Keyboard...
Dead keys yamaha psr e413 keyboard
Dead keys on Yamaha PSR e413 keyboard: Flip keyboard upside down, remove cover screws (use marked cardboard template to remember where they came out), spray suspect key-contacts with fast-drying contact cleaner, (usually a PCB with a matrix of contacts under keys), re-assemble base cover, wiggle faulty keys as far as possible to 'scrub' any dirt or oxidization. If this cleaning trick doesn't work, get a pro to check it.
Dec 08, 2012 | Yamaha PSRE413 Keyboard
The keys are broken and some at no sound can I order the notes and sound kit. Yamaha PSR-295 . Regards Elias
Hi, i think you can. You can go to any of the Yamaha companies around you area and explain to them the problem of the keyboard. They will give you good and quality replacement part for your Keyboard.
Make sure you go to only Yamaha company to avoid getting a wrong part for your Keyboard.Avoid road siderepairsforissue like this,it's more complicated to handle
I guess that will do.
Thanks for using fixya...
Jan 12, 2011 | Yamaha PSR-295MS Portable 61-Key...
Yamaha psr s900 screen/display gone bad
MR SATISH IF YOU WANT TO SOLVE THIS PROBLEM CONTACT:9887070565,94136768(ANAND NARWAL)FROM RAJPUTANA ENTERPRISES
Jul 22, 2010 | Yamaha Full-Size Keyboard
Feb 12, 2010 | Yamaha Full-Size Keyboard
Yamaha Portable Keyboard with 61 Touch-Sensitive Keys and General MIDI Logo
76 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
