Question about Car Audio & Video
Craftsman electric lawnmower model C935-35516-3
How do I hook up the wires to the transistor/diode?
5 Suggested Answers
  • 138 Answers
SOURCE: Craftsman riging mower will not charge. Son hooked
if it is a briggs engine it is in the wiring harness coming off the alternator, where it plugs into the main harness coming out of the dash area. it will appear as a lump in the wire [sometimes there will be two diodes]. if it is a kohler, it will be in the wiring harness under the shroud covereing the flywheel
Posted on Sep 01, 2009
Testimonial: "Thanks for the help. It saved me much needed $$$"
mickey813
  • 472 Answers
SOURCE: HOW DOES THE CABLE ON A SEARS CRAFTSMAN RIDING
ON TOP OF THE SMALL IDLER PULLEY THE BOLT IS LONG AND IT HAS A HOLE IN THE SPRING GOES ON THAT BOLT AND THEN A WASHER THEN A PIN THAT HOLDS IT IN PLACE
Posted on Nov 19, 2009
  • 11 Answers
SOURCE: craftsman model 536270211 13.5 hp ride on lawnmower won't start
check for water and debrie in float bowl and spark at plug
Posted on Jun 07, 2012
BAMOUT
  • 2478 Answers
SOURCE: oweners manual for craftsman riding Lawnmower lt1000
Try www.managemylife.com
Posted on Oct 09, 2012
Craftsman model 944-364350 lawnmower with electric start. How do you replace the battery?
1) Find the battery.
2) Unhook the terminals using the appropriate tools.
3) Disconnect the battery from the battery hold-down, using the appropriate tools. You may need a good light to see what you are doing.
4) Lift the battery out of the holder.
God bless your efforts.
Feb 13, 2017 | Craftsman Garden
I need to wire a 3/4 HP electric motor for 110. Problem is I have a old craftsman motor that has cloth wires labeled 1 through 4 and Im not sure how to hook this up
Please take another picture, or draw info. I cannot read your photo! Also, make, model manufacturer, voltage, amperage, horsepower..., etc.
Jan 20, 2016 | Craftsman Pool & Spa
Craftsman riding lawnmower, model #917 259012 hydrostat stopped working
Check belts. Check transmission fluid level if possible. Check linkage between shifter and transmission. Check belt tensioners under unit above deck.
Jun 15, 2014 | Peg Perego My First Craftsman Tractor...
Spark plug wire came off the lawnmower and it will not start again just keeps turning over
with out the spark plug wire hooked up it will not start i assume that it wasn't the spark plug end so take the cover off the top of the engine a mouse might have chewed it off and you would need to replace the coil
May 21, 2012 | Craftsman Garden
My craftsman lawnmower dies when i let out on the clutch
make sure your not in reverse with the blades on. if so turn the key left to mow in reverse mode. else check pullies.
Jul 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My lawnmower won't start. WHen I turn the key it
Check battery cable for correct hook up. Red positive to starter and black to ground. If battery connected backward starter rotates in opposite direction and can burn up starter. If correct battery hook up check plastice gear on starter for wear.
Mar 11, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
HOW DOES THE CABLE ON A SEARS CRAFTSMAN RIDING LAWNMOWER LT2000 17.5 HOOK INTO THE DECK
Nov 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riging mower will not charge. Son hooked cables up wrong and most likely blew the diode. Where is the diode located?
Sep 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Transistor lost.
if you are replacing 7402
also replace diode 6404 this diode even thou it test goo will in long term overheat 7404 and caus it to go bad by leakage.
and if 7402 gose bad it is regulating the 15v stanby volts that is 7412 is also going to be bad so replace 7412 also
now
the part numbers are:
7402 = # 932211676682
7412 =# 932210514682
thanks,
daniel.
Jan 13, 2009 | Philips 19PR19 19" TV
Car Audio & Video Logo
44 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
